HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 2, 2020 at 5:59 PM
    #5841
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Well a step down pulley size is usually around 20-25 rwhp and nets about 2lbs. So yeah 40-50 rwhp. You do really feel that much more power just on the vvt adjustment tunes? @12TRDTacoma
    I’ve never heard the Ucon or even the APRx1 aggressive tunes back in the day bump up boost before. Hoping @JustDSM chimes in here too
  2. Mar 2, 2020 at 6:10 PM
    #5842
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I feel a lot more power all around. Remember though.. upon changing my cam gears I also went with a 160 t stat which adds the benefit of more timing being run. I also closed up my plug gaps recently so there is more to the story than just cam gears, that being said that was the immediate change before getting retuned. All this other stuff came shortly after the tune.
  3. Mar 2, 2020 at 6:16 PM
    #5843
    420taco
    420taco Well-Known Member
    Justin
    PA
    what’s the most timing advance your seeing at >10 psi?
  4. Mar 2, 2020 at 6:18 PM
    #5844
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not sure.. I haven't looked at PSI in relation to timing advance since boost is not logged in the datalog it's difficult to put a number on a particular boost number. I'd have to film it while driving and then refer back to that timestamp in the log to see where I'm at.
  5. Mar 2, 2020 at 6:20 PM
    #5845
    Gunerbey
    Gunerbey Well-Known Member
    2015 Tacoma
    whats the value in the cam gears for n/a mostly stock setup?
  6. Mar 3, 2020 at 5:13 AM
    #5846
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Nahhh, it was just the cam gears :rofl:
  7. Mar 3, 2020 at 7:26 AM
    #5847
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    If you have your own MPVI2 and an existing BD tune I can speak highly of tuning remotely with @JustDSM. Extremely reasonable cost, good all around person, and he has been tuning most of the supercharged folks in this thread with great results!
  8. Mar 3, 2020 at 7:29 AM
    #5848
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Thats what i figured. Im NA'd but why not properly log and adjust, i have the technology hahah.
    now to round up the couple of gaskets needed for the cam gear job, and find the time / tools to do so.
  9. Mar 3, 2020 at 7:31 AM
    #5849
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I have new OEM valve cover gaskets if you'd like them. I'll do 50% of whatever they cost elsewhere.
    nd4spdbh[QUOTED] and zippsub9 like this.
  10. Mar 3, 2020 at 7:33 AM
    #5850
    JustDSM
    Justin
    Ogden, UT
    Thank you for the feedback and referral! Very much appreciated! It's been a pleasure to assist you guys.
  11. Mar 3, 2020 at 8:12 AM
    #5851
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    Ballpark, how many Tacoma's have you tuned so far? I was gone for a week and forgot how much fun it is to drive!
  12. Mar 3, 2020 at 8:16 AM
    #5852
    JustDSM
    Justin
    Ogden, UT
    Just a tick over 90!
    Mech_Eng, Hawk373, smelly621 and 9 others like this.
  13. Mar 3, 2020 at 10:30 AM
    #5853
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Last weekend i did cam gears and deleted SAI (for off-road use only), got re-tuned by JustDSM... I noticed now I have a very slight hesitation when cranking the truck over on a cold start and a bit longer crank time. subtle but enough for me to notice. is this something i should be worried about ?
    mightytacoman and ebuyaer2002 like this.
  14. Mar 3, 2020 at 11:33 AM
    #5854
    nd4spdbh
    SoCal
    Probably just the truck learning everything on based on the new tune. I wouldnt worry at all. (so long as you got cam gears aligned properly)
    Dude, will you stop being such a class act! haha. Thank you for the offer, gonna have to pass though. Im not sure when ill have the time and if someone can use those gaskets now id much rather have that!
    12TRDTacoma likes this.
  15. Mar 3, 2020 at 11:35 AM
    #5855
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I took my gaskets back to the dealership and refunded the money. Mine were still fresh and pliable when I pulled the covers.
  16. Mar 3, 2020 at 11:39 AM
    #5856
    mightytacoman
    Kel
    4.5L 1grfe
    Could be just the truck relearning. I haven't heard this problem before. Keep me/us posted though
  17. Mar 3, 2020 at 12:22 PM
    #5857
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Which fuel pump are you running?
    fwiw my walbro 255 caused a delay start and it was the check valve in the pump that caused it. Added an inline check valve and havent looked back
  18. Mar 3, 2020 at 12:26 PM
    #5858
    nd4spdbh
    SoCal
    For me. If im in that far, the 15-20 bucks per side is not worth it to have to replace down the road if they do leak. Once those cam gears go in, ill never go back inside haha.
  19. Mar 3, 2020 at 12:33 PM
    #5859
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Our trucks are 2012 and above so it is in our best interest to replace those stupid gaskets while we are in there or suffer the consequences of having to pull off that AIP manifold again. Fuck that thing, and I say that with extreme hatred in my demeanor. Lol.
    nd4spdbh and zippsub9 like this.
  20. Mar 3, 2020 at 12:53 PM
    #5860
    garciav
    Houston, TX
    TRD SC,HPTuners
    did it do it since you first installed it ? I am running the deatschwerks 255 for a couple years now and never had this happen
    BassAckwards[QUOTED] likes this.
