HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 6, 2020 at 3:27 PM
    #5901
    OVTune
    OVTune Well-Known Member
    OVTune
    There are way too many factors, just giving it a quick glance.
    because there are
    $00:Unused,$01:OL,$02:CL,$04:OLDrive,$08:OLFault,$10:CLFault
    and code sections for different bit flags on this ram.
    it would take me a while sorry.
    Murphinator and nd4spdbh like this.
  2. Mar 6, 2020 at 3:34 PM
    #5902
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I appreciate you looking into it anyways :cheers:
    ebuyaer2002 likes this.
  3. Mar 7, 2020 at 8:43 AM
    #5903
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Sounds like I’m going back to the stock T stat...
  4. Mar 7, 2020 at 5:59 PM
    #5904
    garciav
    Houston, TX
    TRD SC,HPTuners
    What aftermarket wideband setup are y’all using to be able to log with HPtuners? Time to throw more money at the truck
  5. Mar 9, 2020 at 8:00 AM
    #5905
    garciav
    Houston, TX
    TRD SC,HPTuners
    Is anyone in here currently logging AFR in HPtuners with an aftermarket wideband set-up ?
  6. Mar 9, 2020 at 8:05 AM
    #5906
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I've been considering it myself... As I still see an all time (on this t stat) high of 191* while freeway cruising. OE has shown me 194* at worst.
  7. Mar 9, 2020 at 8:30 AM
    #5907
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    which tstat are you running? a 160* tstat should definitely run cooler than essentially the stock 182-185* tstat.
    EDIT - Also FINALLY got around to flashing my "v13" trans tune, (actually similar to yours @12TRDTacoma but not quite as aggressive). A few very minor changes to upshifts to make things more linear, but TONS of changes to upshifts later in the throttle which should make things more lively! On the 10 mi drive to work I am liking what im feeling. Gonna do a week or so worth of testing and will release it when I can.
    Kind of a nerve racking flash tho... the "parsing flash data" phase right at the beginning timed out with "argument null" EEK! Got on a better internet connection and it worked like a charm.
  8. Mar 9, 2020 at 8:49 AM
    #5908
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I run the 160. It does run cooler normally except on the highway when giving it some juice going up inclines. I still see it go up to 191*... the 160* opening is just when it opens. The coolant can still get hotter than it's opening temp by quite a bit. Which is why I may just go back to OE. It may be redundant for me running the cooler opening one.
    I've gotten the argument null message once or twice. I think it legitimately is an internet connection issue thing. It still is nerve racking though huh!
    Hawk373 likes this.
  9. Mar 9, 2020 at 8:55 AM
    #5909
    OVTune
    OVTune
    There is a big misconception about T-stats, a thermostat does not change the capacity of the cooling system. It will not change how effective the system is.
    garciav likes this.
  10. Mar 9, 2020 at 9:29 AM
    #5910
    nd4spdbh
    SoCal
    Exactly. Only thing it will do is give you a little more time before reaching an overheating condition under extreme load. Like stated, for a DD, you wanna get the motor hot nuff to evaporate out moisture out of the oil so you dont have sludge problems.
    If one was to have cooling problems, a bigger radiator / fan setup would be first on my list. Personally on an NA motor i have never had issues with cooling, including slow moving in the desert with ac blasting in 115*F temps.
    zippsub9 likes this.
  11. Mar 9, 2020 at 10:01 AM
    #5911
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I never said I was running mine to increase it's capacity and I never said it would increase it either. I actually just ran it because it was a quickly accessible alternative to the OE version which needed immediate replacing so I ran it for experimental purposes.
    nd4spdbh likes this.
  12. Mar 9, 2020 at 10:03 AM
    #5912
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    If you have pro version you just pick your choice of wbo2 and wire directly to the tuner. AEM makes an wbo2 that allows logging through ecu to tuner but not sure if compatible with the Tacoma ecu but should be since it's a newer ecu.
  13. Mar 9, 2020 at 10:22 AM
    #5913
    OVTune
    OVTune
    I didn't mean it that you personally did for that purpose. I meant in general. sorry, it was just your post quoted
  14. Mar 9, 2020 at 10:30 AM
    #5914
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't mean to come off as an ass either if that's what I came off as. Lol. All good Matt. :thumbsup:
  15. Mar 9, 2020 at 11:28 AM
    #5915
    garciav
    Houston, TX
    TRD SC,HPTuners
    From reading in HPtuners and other gm forums, its seems like certain widebands have issues with lag, sampling rate, ect when logging in hptuners. I'm asking if anyone on here has got a set-up going that works on their tacoma.
    I have seen the AEM X-series OBD2 Wideband, it seems like the easiest set-up for logging with HPtuners. one thing i cannot figure out is if you need the prolink version to log with this OBDII wideband. You would think that you dont since the MPVI2 would be picking up this signal thru the canbus... Wish there was a dual AFR gauge that did this
  16. Mar 9, 2020 at 11:35 AM
    #5916
    nd4spdbh
    SoCal
    Mech_Eng and henryp like this.
  17. Mar 9, 2020 at 1:22 PM
    #5917
    JayRolla
    Colorado Springs
    I dont think you need pro with that AEM you mention. But yes real life experience will be hard to find since new application. On my gm application I would log through the ac input with a switch to go between logging and when using AC to avoid buying pro. I found in my many years a tuning that a camera that shows gauge and tachometer is most accurate easy way to log. Lol
  18. Mar 9, 2020 at 8:01 PM
    #5918
    nd4spdbh
    SoCal
    Doing some looking around in a newly added Cal for a 2008 FJ cruiser.... 6100rpm revlimit.... wtf!
  19. Mar 9, 2020 at 8:16 PM
    #5919
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    I didnt know they had released support for the FJ yet.
  20. Mar 10, 2020 at 7:16 AM
    #5920
    nd4spdbh
    SoCal
    Interesting. Dont see why not. I read my buddies truck, HPT didnt have it in the software, sent the HPT and VCM info to them and they updated the beta to support most of the tuning parameters. Still missing some.
    Ill have to go for a drive in my buddies FJ and really see if it does rev past the standard 5600rpms of a taco. 6100rpms seems EXCESSIVE!
