HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 10, 2020 at 5:00 PM
    #5941
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I unchecked p0128 and changed several of the coolant temp related values. Been running that way since around the time I posted that with no I’ll effects yet.
  2. Mar 11, 2020 at 2:13 PM
    #5942
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I believe we all are. I'm logging boost as well.
  3. Mar 11, 2020 at 7:39 PM
    #5943
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Not sure for the HPtuners but on my x1 on my race truck (auto) to get high rpms you need to manually shift it to get anything above the stock rev limiter.
  4. Mar 11, 2020 at 8:10 PM
    #5944
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    well yeah, if you are in D the stock shift lines will shift the auto to make it to where it doesnt hit revlimiter.
    I got a little to agressive one test tune and raised the shift line of WOT 1 to 2 shift by a bit too much and ended up in certian load situations actually shifting right at revlimiter. Actually had one that was PERFECTLY timed that ran through first, and hit revlimit RIGHT as it shifted to 2nd.... talk about a CRISP shift.... and way to much driveline shock. Reduced that line down a bit (only 20ds rpm over stock at WOT, but thats ~150-200 rpms with gear ratios and torque converter slippage)
    hemitruk likes this.
  5. Mar 11, 2020 at 8:28 PM
    #5945
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    What wb setups do y’all have
  6. Mar 12, 2020 at 1:51 PM
    #5946
    BillDaCat8
    Jake
    PHX
    Mine is an AEM 30-4900 wired to the Prolink.
    "failsafe" gauge can be set up to pulse a ground in the event things happen outside of the adjustable parameters. For example, too lean under boost can trigger an ignition kill. Or, it could be set up to trigger a meth injection setup. Gauge has AFR, Boost/Vac, and Rpm inputs. So, imagine a trigger that can be based on those three things. I tapped into the tach signal at the instrument cluster.
    JustDSM likes this.
  7. Mar 12, 2020 at 5:06 PM
    #5947
    Kapncam
    Kapncam Well-Known Member
    Adam
    West Virginia
    SC 2015 Black Tacoma
    Super Charged, TRD exhaust
    Any coupon codes for these tuners? Where’s the best deal?
  8. Mar 12, 2020 at 5:11 PM
    #5948
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    500 give or take $10 is where it’s at. eBay has it prop 65 free if you are Cali, otherwise Amazon.
    you can just get the credits separate for the same price from HP, and if you aren’t sure about Pro, you can add it later at the same cost
    nudavinci64 and JustDSM like this.
  9. Mar 12, 2020 at 10:26 PM
    #5949
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Who can point me to how I can get the base TRD tune using HP Tuners. I discussed it a bit with @JustDSM before but wanted to check in if its still possible. Just started tearing down the truck for the S/C setup and figure I should get that squared away.
  10. Mar 12, 2020 at 11:21 PM
    #5950
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    @JustDSM can get you squared away. He can bench flash your MY trd cal. Just have to send him your ecu. I would recommend getting a backup ecu if you have not yet thought about it.
    12TRDTacoma likes this.
  11. Mar 12, 2020 at 11:22 PM
    #5951
    nudavinci64
    Robert
    Ive thought about it just haven’t found one yet. That’s def an option, I figure I could also do it myself Incase I need to do it on a backup.
  12. Mar 12, 2020 at 11:29 PM
    #5952
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Other option is using Techstream and getting a two day license and flashing the trd cal yourself. You would also need a tactrix cable to do the flash as you can’t use HPtuners software or cable to go from n/a to the trd cal. I highly recommend having @JustDSM do the initial flashing of the trd cal.
    12TRDTacoma and sbchero like this.
  13. Mar 13, 2020 at 9:17 AM
    #5953
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    agreed.
    @JustDSM set up my spare ECU with my vin and base trd tune for me to then put his HP tuner tune onto it. great work and quick turnaround.
  14. Mar 13, 2020 at 10:53 AM
    #5954
    Mthee88
    Mthee88 Member
    Hi folks,new to TW.
    Recently purchased a 2015 M/T Base with less than 20,000 miles. I was so stoked to own a manual truck again except I discovered it suffers from high fluctuating idle while coasting in neutral. Would guru JustDSM's rev-hang Tune remedy this?
    1slow4.0, BillDaCat8 and JustDSM like this.
  15. Mar 13, 2020 at 11:01 AM
    #5955
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    First off, Welcome!
    Any chance you could post up or send a video? In a few instances there are situations where it’s normal to expect some fluctuation. Under normal conditions however, it shouldn’t surge or fluctuate when coasting.
    With a video, we as a collective can help.
    1slow4.0 likes this.
  16. Mar 13, 2020 at 11:35 AM
    #5956
    Mthee88
    Mthee88 Member
    Yes, Hello.
    Sure, can I send?
  17. Mar 13, 2020 at 11:36 AM
    #5957
    JustDSM
    Justin
    Ogden, UT
    You can email it to me. justdsm@hotmail.com
    1slow4.0 and Mthee88[QUOTED] like this.
  18. Mar 13, 2020 at 1:44 PM
    #5958
    Mthee88
    Mthee88 Member
  19. Mar 13, 2020 at 1:50 PM
    #5959
    nd4spdbh
    SoCal
    Looks like classic "rev hang". HPTuners has the throttle cracker adjustments for this that will allow you to tune this to your needs.
  20. Mar 13, 2020 at 2:05 PM
    #5960
    Mthee88
    Mthee88 Member
    Ok thanks, as I mentioned it to JustDSM in an email, it got a whole lot worse after I tried disconnecting the battery as prescribed in other forums as a possible fix. Now it idles at 1500rpm.
    JustDSM likes this.
