HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 9, 2019 at 11:37 AM
    #581
    ThomasMore66
    Dallas/Fort Worth & Durango
    Wow! I'm not that rich. I see 11's WOT with the 2.5. Now part throttle I can see some quick dips in the 10's. You running the stock throttle body?
    12TRDTacoma likes this.
  2. Apr 9, 2019 at 11:37 AM
    #582
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    We need to start a go fund me to get @JustDSM a supercharger
  3. Apr 9, 2019 at 11:39 AM
    #583
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    76mm. I need to swap out my bosch afr sensor for the denso sitting on my bench and see if it reads any different.
    12TRDTacoma and JustDSM like this.
  4. Apr 9, 2019 at 11:47 AM
    #584
    ThomasMore66
    OMG! I made it through all the pages. I'm so excited and I don't know the first thing about tuning. I had my credit card out a couple of times staring at Amazon, but I'm holding off until I really understand what I need to buy. I've got to get with the mechanic that helps me with all things and see what tuner he recommends. We spent some time thinking Haltech was the answer and then the world changed. Awesome. Can I change my settings to only get alerts from this and the supercharger thread? I mean, what else is there? Ha. Maybe that 9" dif thread...
    Biscuits, Torspd, Roostfactor and 2 others like this.
  5. Apr 9, 2019 at 11:50 AM
    #585
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    I thought you liked dropping in on the 3rd gen performance threads :D
  6. Apr 9, 2019 at 11:53 AM
    #586
    ThomasMore66
    Yeah...about that. I've stopped doing that because I don't want to lose access to the information here. Don't drink and go to a 3rd gen thread, that's my motto.
  7. Apr 9, 2019 at 12:19 PM
    #587
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You mean the 322 g/s thing? Shouldn't be a problem since I stepped down to 2.5" exhaust and stock air cleaner (both more restrictive than I was running before). The highest I ever logged with the UCON was 340-ish.
    DesertRatliff likes this.
  8. Apr 9, 2019 at 1:11 PM
    #588
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Yowza! Does that mean what I think it means (340 g/s x 1.18 ~ 401.2hp)? That's impressive but looking forward to what you'll pull soon!
  9. Apr 9, 2019 at 1:12 PM
    #589
    ThomasMore66
    I run the TRD exhaust. I hit 322 and immediately get a code which I clear and ignore.
  10. Apr 9, 2019 at 1:30 PM
    #590
    ThomasMore66
    Which HP Tuners MPVI2 should you buy on Amazon? I see different numbers after them and I don't know what this means.
    Norton and loginfailed like this.
  11. Apr 9, 2019 at 1:36 PM
    #591
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Don’t know. I went straight to the source.
  12. Apr 9, 2019 at 1:40 PM
    #592
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, several guys saw 340 g/s or more. I think with good tuning mine could still hit that even with more restrictive items installed. The UCON wasn’t perfect by any means. At least on my truck.
    TRON likes this.
  13. Apr 9, 2019 at 1:59 PM
    #593
    ThomasMore66
    You mean you’re not?
    loginfailed likes this.
  14. Apr 9, 2019 at 2:15 PM
    #594
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So does this mean you placed your order?
  15. Apr 9, 2019 at 2:25 PM
    #595
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Okay, just finished some online chatting it up with HP Tuner authorized dealer. If you are not sure, the MPVI2 in the Amazon link below is a legit deal and you just download the software for data logging (I know there was some questions earlier over wideband). Any of the Pro Features that come with the more expensive package can be added later with a simple firmware upgrade for the same price it would cost you to buy in the beginning. There is also another Amazon deal for $270 with a $5 discount per credit coupon (not sure if that is a one time coupon, but 4 credits would merit a $20 saving). Once you get the MPVI2 device then you register and create an account to which you can then purchase Universal Credit associated with YOUR specific interface device #.
    I personally don't know jack, but I am ordering some basic tuning interface books and a basic MPVI2 device to which I will log data and figure it out with this group or admit failure and send my data to some of you for interpretation and improvement.
    All of the this could be trumped with a big FAT group by, but not sure who can/will head that up.
    Here is the other one I referenced....
    https://www.amazon.com/dp/B07D42T5G...olid=1X59JMAD2UEFU&psc=0&ref_=lv_ov_lig_dp_it
  16. Apr 9, 2019 at 2:27 PM
    #596
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Good to know that the ones on Amazon are legit.
  17. Apr 9, 2019 at 3:56 PM
    #597
    ThomasMore66
    Not yet. And damn you people! You might recall that I’m supposed to be devoting my resources to my 80. Bought step sliders from Bump It Offroad. Bought my BFGT from Cruiser Brothers (waited months because of Chinese and Russian orders and probably Trump’s tariffs). Got the paint all buffed out. Working on the LS swap details. Now this comes up and I have FOMO, so...back to the Tacoma.
  18. Apr 9, 2019 at 3:57 PM
    #598
    ThomasMore66
    Is there a cable that I need too?
  19. Apr 9, 2019 at 4:11 PM
    #599
    zippsub9
    Halfmoon, NY
    14 DCLB
    Nope. The mongoose and tactrix stuff is for Techstream and nothing to do with this.
    JustDSM likes this.
  20. Apr 9, 2019 at 5:42 PM
    #600
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    What the hell ... Amazon won’t ship to California ! Lol
    Anyone in Cali purchase from amazon ?
