HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 19, 2020 at 8:21 AM
    #5981
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    That stated, i have had the rubber fall off too....
    OK, ill stop now.... but for reals i have had that, and it sucks when its deep down in the hole.
    OK I PROMISE ILL STOP!
    That magnetic snapon one is probably costs an arm n a leg.
    12TRDTacoma likes this.
  2. Mar 19, 2020 at 10:22 AM
    #5982
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How much value does one place on having less headaches and lost time? ;)
    DesertRatliff likes this.
  3. Mar 19, 2020 at 10:24 AM
    #5983
    nd4spdbh
    SoCal
    :rofl::rofl::rofl::rofl:
  4. Mar 19, 2020 at 10:33 AM
    #5984
    dbs1
    dbs1 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    Thanks guy s for all the input and suggestions. As stated a longer socket that I could only find in the 1/2" driver size got past the rubber and did the job.
    The colder plugs were suggested when chasing more ponies and if we are using 150 over the original 236 I think I'm about there. On my last plug change 4 of the 6 electrodes were down to nothing after 60,000 miles and the truck was laying over bad at shift points so I thought I'd try a colder plug.
    I'm thinking the hotter 22's will be fine, give better fuel economy, but those of us running higher boost are just going to have to be prepared to change plugs more often. For me that's going to be once a year to pull the lovely sc off and change em out. I've got it down to just a few hours despite it being just the wrong height and climbing over the front to jack up my back.
    So, 12, what kind of power do you think you are making on yours? I've seen 10lbs of boost at 5000' elevation but never been at lower elevation and cooler temps at the same time to see more.
  5. Mar 20, 2020 at 6:13 PM
    #5985
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    So, try flashing back to the TRD tune and drive it for a week. UUUUUggggh! Fuckin terrible.
    @JustDSM you da man.
    I suppose I should actually get you some logs now eh?
    JustDSM, 12TRDTacoma and TRON like this.
  6. Mar 20, 2020 at 6:23 PM
    #5986
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have no idea. I will say this though, since changing out the cam gears it has made me realize that I have reached the limitations of the 2.5" exhaust and will be changing piping from the Y after the cats all the way to the tailpipe to 3". I went from putting out 12.5-ish PSI peak to 16 PSI peak and these guys made me realize that cam gears while offering a horsepower increase should not increase boost by simply tuning. That alone tells me I have a restriction, and since the only factor which changed was exhaust valve close duration, my money is on the exhaust now being undersized for the mod combo I currently run.
    nudavinci64 likes this.
  7. Mar 20, 2020 at 6:38 PM
    #5987
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The stock manifolds are definitely hurting flow due to design in that the air gets blocked trying to fight through each exhaust port to the collector. Where headers have a more balanced flow to the collector. The stock 4x4 ypipe is definitely restricting from all the pipe bends. Not to mention, air trying to push through all four cats in the process.
    The stock cat-back exhaust on the other hand, has minimal restrictions for flow. And is the least to gain.
    I will say you probably have a great start in acceleration but dies quickly in the higher gears cause the exhaust back pressure is so great.
    BassAckwards and 12TRDTacoma like this.
  8. Mar 20, 2020 at 6:44 PM
    #5988
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm going to say you are pretty spot on. The exhaust manifolds will always be my ultimate restriction and the only thing I could do is the DT shorties (I think those were the ones) which are CARB legal... But right now I'm at a point where I want to make my life in reverting back to OE easier and not harder, especially considering that I have heavy old skids in the way it only adds to the grief if I was doing mods I need to reverse every two years... I'm hoping that by upping the piping to the larger 3" setup it will net me enough increase in airflow to be able to drop some restriction. I suppose we will see.
  9. Mar 20, 2020 at 8:03 PM
    #5989
    Philby
    Philby Active Member
    Cairns Australia
    Hilux SR5 4x4 TRD S/C
    12TRDTacoma..total agree on the standard exhaust manifolds and please correct if I'm not on the same page here but by fitting the retarded exhaust cam gears this would lead to less valve overlap which would contribute to a increase in boost pressure??
  10. Mar 20, 2020 at 9:09 PM
    #5990
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    A good test would be to run an open exhaust from the end of the y-pipe and see what max psi you hit. If its still 16psi, then 3" piping wont really make a difference in the end.
  11. Mar 21, 2020 at 12:10 AM
    #5991
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Precisely.
    The increase in boost pressure is a byproduct of the increase in overall airflow created by the cam gears which is ramping up boost due to a restricting intake or the exhaust setup.
    Basically, there is a bottleneck somewhere in the system and the cam gears are exploiting that.
    That actually wouldn't really tell me much of anything because the Y-pipe is still 2.5" so the restriction is still in the piping. If I widen the pipe to 3" it would probably help due to the added Venturi effect.
  12. Mar 25, 2020 at 12:04 AM
    #5992
    Flake Boost
    Flake Boost FORCED
    never mind- found the answer. "Now that your vehicle is licensed you can flash it an unlimited number of times."
    did that E85 ever get added like you guys were taking about year ago?
  13. Mar 25, 2020 at 3:05 AM
    #5993
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    E85 can be used/tuned, but it’s not a true “flex fuel” setup that can compensate for changes in ethanol content. Any significant shift in ethanol content would require a simple adjustment to the tune.
    Flake Boost[QUOTED] and Torspd like this.
  14. Mar 25, 2020 at 6:16 AM
    #5994
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Also a note for anyone interested in running e85. Make sure you test it if you don’t have a flex fuel setup. Or this is what can happen :D
    https://youtu.be/CJYFRxsfISg
    Torspd and JustDSM[QUOTED] like this.
  15. Mar 25, 2020 at 7:27 AM
    #5995
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Since we’re in the topic of tune/de-tune. How realistic would it be for one to be able to flip between SC tune (TRD vs custom) and NA if one were to travel somewhere without premium gas and have to remove SC belt? At some point I’d like to travel the pan-American highway but I’m afraid the gas situation might not allow with the SC up and running. Sounds like the need for reliable internet might be the limiting factor.
  16. Mar 25, 2020 at 7:29 AM
    #5996
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    carry two ECMs with different tunes.
  17. Mar 25, 2020 at 7:31 AM
    #5997
    henryp
    Henry
    Montana
    Brilliant
  18. Mar 25, 2020 at 7:35 AM
    #5998
    SUMOTNK
    Eddie
    (I know this is a HPT thread but......)
    The old OVTune handheld could do what you're asking. It could hold multiple tunes/maps for different octane gas. I dont see why it couldnt hold a map for NA and one for SC. And if i recall correctly, you dont need internet access to flash 1 map to another.
    But the thing is....i dont think the OVT handheld is supported anymore by OVT. I could be wrong.
    henryp[QUOTED] and Flake Boost like this.
  19. Mar 25, 2020 at 7:41 AM
    #5999
    OVTune
    OVTune Well-Known Member
    OVTune
    Unfortunately not. The company has issues with their software, and on top of that they are in Italy and components of them came from asia, all of which are being affected by the current COVID disaster.
    Torspd, henryp and Flake Boost like this.
  20. Mar 25, 2020 at 8:15 AM
    #6000
    Flake Boost
    Flake Boost FORCED
    I was reading about you mentioning deleting the emission control stuff for "race truck" / "offroad use only" and repurposing a signal 5v etc. didn't know if you guys ever got HPTune to do it
