HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 30, 2020 at 1:08 PM
    #6061
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Well nvm that then. I didnt put the effort into looking
  2. Mar 30, 2020 at 1:43 PM
    #6062
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maybe @Au1gr didn't notice it either?
    zippsub9 likes this.
  3. Mar 30, 2020 at 1:47 PM
    #6063
    OldManTacoFeels
    OldManTacoFeels The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    What kind of gains can a stock 4.0L get with a tune safely
    asudevil likes this.
  4. Mar 30, 2020 at 1:52 PM
    #6064
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Power gains at WOT not much. But driveability gains are huge (especially if automatic due to the ability to tune the transmission). Mpg gains under load are pretty darn good as well.
  5. Mar 30, 2020 at 2:28 PM
    #6065
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    That's what I'm looking for.
  6. Mar 30, 2020 at 2:49 PM
    #6066
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The question posed was how to tune without paying for credits.
    Au1gr and zippsub9 like this.
  7. Mar 30, 2020 at 3:39 PM
    #6067
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    Apparently it took a rocket engineer to figure this out. No matter, ill let you know how i go. For those interested, we cracked the Tacoma/Hilux immob issue. And shortly Audm cars will be Taco ecu friendly and tuneble
    Torspd, garciav and nd4spdbh like this.
  8. Mar 30, 2020 at 3:57 PM
    #6068
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Maybe a rocket engineer can figure out it's not publicly accepted to circumvent an honest company's revenue stream on a thread that that company replies and follows. C'mon man. Head outta yer arse.
    Lord Helmet, 1slow4.0 and nd4spdbh like this.
  9. Mar 30, 2020 at 4:06 PM
    #6069
    Au1gr
    Daniel
    Perth, AUS
    Vin changes on spare ecus seems to be prettty publicly accepted no?
  10. Mar 30, 2020 at 4:09 PM
    #6070
    nd4spdbh
    SoCal
    For use on the same truck. sure.
    DesertRatliff and 1slow4.0 like this.
  11. Mar 30, 2020 at 4:22 PM
    #6071
    Au1gr
    Daniel
    Perth, AUS
    Im sure if i owned two 1gr’s instead if a truck and a 200 itd be fine too....
  12. Mar 30, 2020 at 4:36 PM
    #6072
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Actually, no. It wouldn’t be ok. One set of credits for each truck. Now, if you get a spare ECU for a single truck and want to swap it out, then I wouldn’t have an issue. I would wonder what @HPTuners would think of this.
    DesertRatliff likes this.
  13. Mar 31, 2020 at 8:10 AM
    #6073
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Can you share this with me? I've asked around before and people must think I am going to go on a grand theft auto spree or something because they won't pass the knowledge on.
    I'd just like to disable immo so I can run any key, as well as swap between two ECUs without doing the 30min immo handshake.
    Thanks,
  14. Mar 31, 2020 at 8:30 AM
    #6074
    nd4spdbh
    SoCal
    I think they cracked the kline / canbus problem... IMMO still is in use.
  15. Mar 31, 2020 at 10:49 AM
    #6075
    Flake Boost
    Flake Boost FORCED
    https://www.digital-kaos.co.uk/forums/forum.php
    Used to have an
    IMMOBILIZER off Free for everyone thread.
    There are a couple other forums around the flashing, files, tuning, software, etc. If you are really interested. I can post them up tomorrow. I'm working on the top end right now.
  16. Mar 31, 2020 at 10:56 AM
    #6076
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    You will notice an improvement on the butt dyno, don't expect neck breaking gains though. Still worth every penny imo.
  17. Mar 31, 2020 at 11:23 AM
    #6077
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I'm looking for that switch. The switch that says I just drove 500 miles pavement now I'm in the dirt, give me throttle response. Then 100 dirt miles later, I'm back on pavement, give me the switch for fuel economy on the pavement. What am I looking for (tuner wise)?
    My best example is driving Sacramento to Baja on I5, first tank mpg is under 15, 2nd tank is about 19 mpg, then over grapevine and thru LA, 22 mpg. Give me the switch in sac to get 22 mpg. Is there such a device?
    henryp likes this.
  18. Mar 31, 2020 at 12:05 PM
    #6078
    Sacrifice
    KS
    DCSB OR 4X4 LT
    your right foot. honestly this is just landscape that is effecting your mileage. a tune isnt going to do a whole lot to that and itd be more of a hassle to swap between tunes on the road.
    OldManTacoFeels likes this.
  19. Mar 31, 2020 at 12:33 PM
    #6079
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    I honestly think if I had found a manual I wouldn't be considering a tune but it's really hard to enjoy this truck coming from a manual
  20. Mar 31, 2020 at 12:45 PM
    #6080
    nd4spdbh
    SoCal
    Its simply a mater of load. A tune is going to make the truck not run nearly as rich under load which should net better under load mpgs. That stated with areodynamics of a brick there is no secret sauce to get good mpgs other than simply slow down. You will see +2mpg going 65 vs 75.
    Manuals suffer from revhang and all the same throttle mapping "issues" that the autos do.
    TodayWasTHeDaY likes this.
