HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 8, 2020 at 5:20 PM
    #6121
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    You put cam gears on with cams and Gained 4 psi? I thought cam gears are suppose to empty the cylinder more making less boost I would think?
  2. Apr 8, 2020 at 5:35 PM
    #6122
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's moving more airflow, so it's actually creating a restriction if you see boost numbers go up. I have topped out the limits of the 2.5" exhaust with cam gears and a 2.3 pulley officially and the boost pressure rise is an indicator of that.
    Either I need to do headers (which legally I can't because they don't exist for 12-15 models which are CARB certified or I need to up the exhaust at or after the Y to a 3" to attempt to try to move some more airflow and bring boost pressure back down to what it was.
  3. Apr 8, 2020 at 5:58 PM
    #6123
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Do you have cams?
  4. Apr 8, 2020 at 6:02 PM
    #6124
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just gears, not the cams themselves.
  5. Apr 11, 2020 at 7:49 PM
    #6125
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    JBA makes shortie headers that you have to weld your stock cats back on and they have a carb sticker. Not saying it will help your issue. I run them, they definitely gave more low end torque when I installed them.
  6. Apr 11, 2020 at 8:20 PM
    #6126
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You got a link?
  7. Apr 11, 2020 at 8:36 PM
    #6127
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  8. Apr 11, 2020 at 8:56 PM
    #6128
    12TRDTacoma
    Rob
    Concordia
    Boosted
  9. Apr 11, 2020 at 9:18 PM
    #6129
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’m sure they are much alike....jba and DT shorties. I have DT’s welded to high flow cats and love them.
    12TRDTacoma likes this.
  10. Apr 11, 2020 at 9:43 PM
    #6130
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Big change in sound?
  11. Apr 11, 2020 at 9:52 PM
    #6131
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
  12. Apr 11, 2020 at 10:01 PM
    #6132
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Murphinator[QUOTED] likes this.
  13. Apr 11, 2020 at 11:29 PM
    #6133
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    That is correct.
    Same as the FJ.
  14. Apr 11, 2020 at 11:30 PM
    #6134
    Lucario Runner
    Robert
    06 Toyota 4Runner
    That yaw sensor is a bitch.
  15. Apr 12, 2020 at 8:35 AM
    #6135
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I’ve only ran them with a aftermarket y-pipe. URD then jfr custom. So it’s always been loud.....
  16. Apr 12, 2020 at 12:13 PM
    #6136
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Like an overbearing nanny.
  17. Apr 13, 2020 at 6:51 AM
    #6137
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...but is she a cute young thing? :anonymous:
    Torspd[QUOTED] and nd4spdbh like this.
  18. Apr 15, 2020 at 12:44 PM
    #6138
    Flake Boost
    Flake Boost FORCED
    @JustDSM
    Can you use mongoose pro to do the programming? Like buy the licensing etc fro HP Tuners and use the Mongoose for the actual programming so you don't have to get their hardware?
  19. Apr 15, 2020 at 12:46 PM
    #6139
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    No, you have to use the MPVI2.
    Flake Boost[QUOTED] likes this.
  20. Apr 16, 2020 at 3:29 AM
    #6140
    asgardengineering
    asgardengineering Well-Known Member
    Sydney, Australia
    Toyota Hilux SR5
    Random question, anyone have a list of supported PID's from the 2005-2008 ECU as well as what CAN protocol Toyota use for the Tacoma?
