HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 18, 2020 at 9:46 AM
    #6361
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I have been watching this thread for a few weeks now and it seems like the latest transmission tune has really woken up the truck's response. I've tuned my last vehicle to my liking and would like to do the same with my truck but I might wait until more time and revisions have been made to refine things since, from what I remember, each flash requires payment in addition to the initial cost of the hardware/software.
    Any opinions on the current/latest tune(s) and usefulness for a DD with occasional overland duty?
    JustDSM likes this.
  2. May 18, 2020 at 9:47 AM
    #6362
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If you buy the MPVI2 and 4 credits, you can flash till your hearts content, I have flashed easily 50+ times.
    With a JustDSM engine tune and my v13 trans tune.... you wont want to go back to stock (even on a stock truck like mine!)
  3. May 18, 2020 at 10:25 AM
    #6363
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    I second this. also fully stock, and love the engine and v13 tune. trans mapping is much smoother, throttle is much smoother, feel more power (butt dyno) and even gained ~1mpg (~6-7% increase)
    12TRDTacoma and JustDSM like this.
  4. May 18, 2020 at 10:58 AM
    #6364
    GrundleJuice
    Michigan
    2016 TRD Bro
    Oh great! I was under the impression that is cost credits for each flash. Good to know.
    The throttle/pedal mapping and transmission shifting is really poor stock, figured that was to help gain some mpg by keeping the engine rpm down. I'm surprised you have seen increased fuel efficiency. Is that just from calculations made at fuel fill ups or other data?
  5. May 18, 2020 at 11:52 AM
    #6365
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Definitely collective data from all of the tuned crew at this point. Even heavily.modified folks have seen a bump from .8-1 MPG. Just goes to show you how suck the OE tune is.
  6. May 18, 2020 at 12:07 PM
    #6366
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Pretty common for factories to make motors rich for longevity. JustDSM just how rich are these 4.0s from the factory?
    I see there are large CSF radiators out there. Pointless for NA applications unless you can improve power/mpg by leaning the mixture significantly. Not sure if any of you cracks looked into this?
  7. May 18, 2020 at 12:21 PM
    #6367
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Looked into CSF?? Yes, quite a few running dual core for the taco and some running single core for the FJ.
    Torspd likes this.
  8. May 18, 2020 at 12:36 PM
    #6368
    TireFire
    Olympic Peninsula
    No, not looked into CSF. I meant the tuning thing, i.e., leaning the mixture more in NA applications. The extra heat then could be compensated for with one of those radiators. Just thinking out loud
    zippsub9[QUOTED] likes this.
  9. May 18, 2020 at 12:57 PM
    #6369
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I am away from my laptop today but the factory TRD calibration targets 9.78:1 at the highest loads/rpm and the N/A cal targets 10.57:1 IIRC.
  10. May 18, 2020 at 1:04 PM
    #6370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It isn't just leaning. It is also ignition timing, throttle mapping, cam tuning(possibly from cam gears for the exhaust), and all with regard to the octane that you normally use. That octane grade and cam gears can quite significantly move that knock threshold, which means more or less timing. Which can also translate to improvements in fuel consumption.
    All inclusive. Not just any one thing.
  11. May 18, 2020 at 1:06 PM
    #6371
    TireFire
    Olympic Peninsula
    So that’s pig rich, isn’t it??
    Also @12TRDTacoma have a PM thread going about shorty vs real long tube headers, particularly the equal tube length ones. He says you have data logs that prove that on NA trucks the shorty headers improve drivability more than the LT ones. Is that true?? If so, I find that very surprising actually. Knowing what I know from motorcycles, long and equally long primary tubes (depending on crank setups of course) yield the best scavenging which produces the most torque at low RPM even though long tubes of course flow less than short ones. But with low revving motors like these I was pretty certain that long tube headers will be beneficial, whereas the results of shortys of the OEM log style manifold would be slim to none.
  12. May 18, 2020 at 1:10 PM
    #6372
    TireFire
    Olympic Peninsula
    I already have the cam gears but no tune yet. Leaner means hotter. Less fuel to cool cylinder walls. I wasn’t sure if heat was a concern with respect to how lean you can go on NA motors to improve power and when diminishing returns begins to tilt the scales
  13. May 18, 2020 at 1:28 PM
    #6373
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm pretty sure that was your findings unless I'm all bassackwards right @JustDSM ?
    A quick Google search netted me the same exact thing I was telling HX. So it sort of further solidified what my initial feelings were. Of course I could always be wrong. It wouldn't be the first time.
    Also, I sent you an email this morning with my log brother. :thumbsup:
  14. May 18, 2020 at 1:28 PM
    #6374
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Even going 12:1 for N/A, your cooling system will handle just fine. 12-12.5 would be far more optimal for N/A.
    If you were driving and someone changed that AFR on the fly, it would be instantly noticeable. As if the sluggishness were taken away.
    12TRDTacoma likes this.
  15. May 18, 2020 at 1:32 PM
    #6375
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Around 12.5 is optimal as indicated above for NA.
    10.5 and definitely 9.78 AFRs are considered pig rich and will foul up your plugs very quickly.
    As I said, the factory tune is trash and is the epitome of lazy tuning passed off as good to go by Toyota to compensate for the lean conditions in play in order to appease federal and California emissions regulations. Those are just my personal feelings though.
    Torspd likes this.
  16. May 18, 2020 at 1:34 PM
    #6376
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    fill-up calculations.
  17. May 18, 2020 at 1:51 PM
    #6377
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I can attest to this. At a point in time when I was between tuning, and no turbo, the AFR's were at such. Which prompted me to lower my fuel pressure on my regulator, until in the mid 11's.
  18. May 18, 2020 at 2:13 PM
    #6378
    TireFire
    Olympic Peninsula
    Do power benefits trail off after 12.5? As in, there’s no benefit to be had going leaner with NA?
  19. May 18, 2020 at 2:14 PM
    #6379
    GrundleJuice
    Michigan
    2016 TRD Bro
    Does the truck come with an oem wide band O2 sensor? Has anyone checked actual AFR with a calibrated stand alone O2 sensor/controller?
  20. May 18, 2020 at 2:19 PM
    #6380
    TireFire
    Olympic Peninsula
    No, just the O2 sensors
