HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 19, 2020 at 9:14 AM
    #6401
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    4.56, but I know what you meant. Get a real tune on it from @JustDSM with the @nd4spdbh ghost pepper trans tune and it will be a completely different truck. I’m on 37’s with the same gear ratio and it’s great. (Granted I do want 5.29’s since mine isn’t a daily driver anymore)
    1slow4.0 and 12TRDTacoma like this.
  2. May 19, 2020 at 9:16 AM
    #6402
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @nd4spdbh 's Ghost Pepper Chili Habanero Carolina Reaper trans tune really wakes up @JustDSM 's TRD crack tune.
    It drives the way the truck should have driven straight from the factory. ;)
    Torspd and 1slow4.0 like this.
  3. May 19, 2020 at 9:41 AM
    #6403
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOL you guys.... Its just batch 2 of Spicy Taco Sauce.... aka STSB2 .... aint even close to ghost peper / carolina reaper levels cus we could go more extreme, but it likely make for a meh driving experience all around.
  4. May 19, 2020 at 9:46 AM
    #6404
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well... In comparison to OE drive quality plus my extra levels of tweaking I have on my own version of my tunes I call it the Ghost Pepper Chili Habanero Carolina Reaper trans tune. :rofl:
    I just like adding extra spiciness to it because it all sounds great.
    1slow4.0 and TodayWasTHeDaY like this.
  5. May 19, 2020 at 10:22 AM
    #6405
    nd4spdbh
    SoCal
    Haha curious as to what you did on top of STSB2
  6. May 19, 2020 at 11:34 AM
    #6406
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Increased line pressures.
  7. May 19, 2020 at 11:59 AM
    #6407
    nd4spdbh
    SoCal
    ah yes, you had them elevated from mid throttle on.
    12TRDTacoma likes this.
  8. May 19, 2020 at 2:18 PM
    #6408
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Can HPtuners also simulate O2 sensors? For those folks that have long tube headers? Or do you still need the URD simulators or trick the ECU otherwise?
  9. May 19, 2020 at 2:21 PM
    #6409
    12TRDTacoma
    Rob
    Concordia
    Boosted
    HPTuners can turn off rear o2 sensors entirely, so it eliminates the need to run simulators.
    TireFire[QUOTED] and zippsub9 like this.
  10. May 19, 2020 at 2:25 PM
    #6410
    nd4spdbh
    SoCal
    For off road purposes only.
  11. May 19, 2020 at 2:25 PM
    #6411
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yup, you can delete the rear.
  12. May 19, 2020 at 2:46 PM
    #6412
    TireFire
    Olympic Peninsula
    Sweet deal, those simulators are PRICEY!! Makes HP all the more compelling.
    12TRDTacoma[QUOTED] and zippsub9 like this.
  13. May 19, 2020 at 2:53 PM
    #6413
    Navycb1
    Navycb1 Member
    David
    2006 Toyota Tacoma PreRunner- Silver
    Got my ECU back from @JustDSM and all I can say is WOW. Better shifting and power through the whole range. No more hunting for gears. Firm and crisp shifting. If you have been thinking about doing the tune....do it!!! Thanks again Justin!!!!
    Torspd, Norton, 1slow4.0 and 7 others like this.
  14. May 19, 2020 at 3:10 PM
    #6414
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Well I'm super happy with the V13 "ooooh weeee! This ketchup has some zip" tune!* Truck is running and shifting just the way I want it to. Thanks nd4spdbh!!
    *Inside joke. My grandma grew up in North Dakota and thought everything was spicy; even ketchup.
  15. May 19, 2020 at 3:17 PM
    #6415
    nd4spdbh
    SoCal
    haha yeah. for us normal driving folks the v13 has been a pretty sweet trans tune. The Hot Boiz on the other hand like their spicy.
  16. May 19, 2020 at 6:34 PM
    #6416
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    Just so your clear, HpTuners will only turn off the sensor, it does not act like a 02 sim. You will not pass emissions with hptuners. You will still need 02 sims if you are required to get emissions in your area.
  17. May 19, 2020 at 6:48 PM
    #6417
    zippsub9
    Halfmoon, NY
    14 DCLB
    Can you clarify this statement. Are you speaking to a specific test in the state of Colorado or Washington state? Many states only check ready codes and MIL lights. None of which require sims.
  18. May 19, 2020 at 6:50 PM
    #6418
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think he means that the physical sensor has to actually be there for emissions inspections and you will fail if they are not there, but turning off the code eliminates the need for o2 sims entirely.
    zippsub9[QUOTED] likes this.
  19. May 19, 2020 at 6:50 PM
    #6419
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Hptuners will turn off the Mil but it will not allow the sensor to be in ready status. So if your State does the check ready status it will fail.
  20. May 19, 2020 at 7:07 PM
    #6420
    zippsub9
    Halfmoon, NY
    14 DCLB
    sort of true. First, the ready code is not listed separately for upstream and downstream sensors. They are combined and once turned off the ready code lists as not supported. I will confirm this again but it doesn’t list as not ready just not supported. Even if it does report as Not Ready, this does not necessary fail you. For example in North Carolina, any vehicle prior to 2001 can pass with 2 not ready codes. After 2001, your vehicle is allowed to have one not ready code, so it depends on the state as to whether you would fail or not, but valid point nonetheless that HPTuner cannot manipulate ready codes.
