HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 13, 2020 at 11:26 PM
    #6581
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Me
  2. Jun 13, 2020 at 11:33 PM
    #6582
    garciav
    Houston, TX
    TRD SC,HPTuners
    Not sure if you figured this out but vcm picks up the x-series wideband as a stock sensor since it’s coming off the canbus stream. Check this video out on how to set it.
    https://youtu.be/ozJz-pNFCuo
  3. Jun 14, 2020 at 4:37 AM
    #6583
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    At the time I asked that question, I had the wrong AEM part number.. 30-0300 was intended for use with AEMNet CAN, not OBD2 CAN. AEM 30-0334 is the same gauge, but with a different firmware and it works perfectly.
    garciav[QUOTED] and BillDaCat8 like this.
  4. Jun 14, 2020 at 7:14 AM
    #6584
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Maybe not just the IPT trans. I was getting pretty bad knock on shifts too but I have the ratiotek kit. Justin corrected it but it was a process. Mostly in the "optimum torque" tables
  5. Jun 14, 2020 at 8:19 AM
    #6585
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Thank you sir! Makes sense to hear what you are saying.
    The low octane table has more ignition in it in my picture simply because I copied the HO table into the LO table and compared it to the original LO table to see any difference.
    Holy knowledge dump sir thanks a bunch! That makes sense as to what is going on and how the fact that the "base" tables are used. Still dont understand why there are two identical table but sounds like there is lots of random junk in the code of these ECU's hahaha. Either way, good to know that altering the base tables will change the lookup and allow me to get KCL values in line for a rpm at different zones.
  6. Jun 14, 2020 at 10:36 AM
    #6586
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Almost makes you wonder why they got rid of Carburetors huh.
    nd4spdbh[QUOTED] and Norton like this.
  7. Jun 14, 2020 at 11:01 AM
    #6587
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Emphasis on ALMOST
    12TRDTacoma[QUOTED] likes this.
  8. Jun 15, 2020 at 9:36 AM
    #6588
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    I also realized this after recently purchasing the 30-0300. I probably could just get the cable and flash the other firmware though? It's all good either way, I would rather just hard wire it though the analog in on the pro link than daisy chaining those silly pass-though connectors. I really wanted to go with the Innovate DLG-1 for dual bank but seems like the MPVI2 expansion hub is still in vaporware status?
    loginfailed[QUOTED] likes this.
  9. Jun 15, 2020 at 10:50 AM
    #6589
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well, I have two of the 30-0300's... Hmm.. some creative work could be done on one of them for it to accept the prolink. Not that I need it at this point but it would still be cool to have and use.
  10. Jun 15, 2020 at 11:09 AM
    #6590
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    You wouldn't need anything especially creative, the 30-0300 still has 5V output. Pages 3 & 10: https://www.aemelectronics.com/files/instructions/30-0300.pdf
  11. Jun 15, 2020 at 4:53 PM
    #6591
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    There is a guy on the HPTuner forum that will flash the 0300 for you so you can log it over CAN. User name dr.mike:
    https://forum.hptuners.com/showthre...AN-integration-W-VCMScanner-Need-beta-testers
    You can definitely use the 5v output with the ProLink cable. The reason I wanted to log AFR over CAN is so I can also log my boost and fuel pressure gauges over the ProLink. I've been waiting for their hub forever. I think vaporware is a good description, so far at least.
  12. Jun 15, 2020 at 5:44 PM
    #6592
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Ouf that thread but lots of good info. He also says the 30-0300 will work on the CAN input on the pro link too. That would keep the other two 5v free for boost, etc.
  13. Jun 15, 2020 at 6:30 PM
    #6593
    nikolasmor
    nikolasmor Well-Known Member
    Finally received my MPVI2 today, however I'm not seeing Channel A and B, only USB Serial Converter so I'm trying to work through that. I can manually install the drivers and choose HP Tuners CDV, HP Tuners MPVI Channel A, or MPVI Channel B but I understand that I need to be able to see both Channel A and B in device manager for this to work properly....grrr. Any tips?
  14. Jun 18, 2020 at 4:41 PM
    #6594
    nikolasmor
    So now I've been in the truck for 2 hours getting these messages. Unable to detect the vehicles diagnostics protocol and Detect Protocol Failed. I can see the ECU and Host lights flashing so it's trying to communicate. My OBD II reader sees the ECU just fine, as I just cleared codes again. Using the latest software versions and checked all the fuses which are fine....ugh Seen this before? It wont read the ECU with the Detect Protocol Failed message. Since I can connect with Torque I know it's not a bad ECU. :/
  15. Jun 18, 2020 at 4:48 PM
    #6595
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    In device manager under "Universal Bus Controllers" there should be "USB Serial Converter" do you see that? Did you download the HPTuners MPVI2 drivers or MPVI drivers?
    05Taco4x4 likes this.
  16. Jun 18, 2020 at 4:54 PM
    #6596
    nikolasmor
    Yup, drivers are good (shows USB serial connector) . Latest software is loaded and latest firmware pushed to device. Internet is good. Key in on position and lights flashing as they should on the MPVI2. I can see my credits and the device info when clicking the ! Button on the software.
  17. Jun 18, 2020 at 5:45 PM
    #6597
    nikolasmor
    Thanks for your post, on a whim I removed the device in device manager and the drivers as well. Plugged back in, ran the CDM21228 setup and BOOM! It worked. Drivers seem to have been the issue after all.
  18. Jun 18, 2020 at 6:55 PM
    #6598
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I was just spit balling. Glad you got it sorted!
  19. Jun 22, 2020 at 7:16 PM
    #6599
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    When installing the pro ad on do you connect the canbus option? i got for streaming AFR but curious if supported i should connect the canbus high/low and what i get out of it?
  20. Jun 24, 2020 at 9:14 AM
    #6600
    Joker8824
    Joker8824 Well-Known Member
    2014 MGM DCSB TRD Sport
    Would you suggest this for someone with a basic stock truck just looking for some improvements in drivability, and more response out of the truck?
    JustDSM[QUOTED] likes this.
