HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jul 23, 2020 at 10:00 AM
    #6701
    12TRDTacoma
    Rob
    Concordia
    Boosted
    4th gear it is then. Today is Dyno day at 4pm and I want to have my junk good to go. Spice it up for me brother.
  2. Jul 23, 2020 at 10:03 AM
    #6702
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is the main reason to lock up the tc in 4th for better dyno numbers? If so, wouldn't this kind of misrepresent real world numbers since you wouldn't drive it like that on the street? Or does it sometimes lock up on the street in 4th? I drive a 6 speed so I'm really just curious and trying to learn here, any info would be appreciated
  3. Jul 23, 2020 at 10:07 AM
    #6703
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    For a dyno you want it in 1:1 gear and locked out so there is no slop between the driveline and engine.
  4. Jul 23, 2020 at 10:10 AM
    #6704
    BassAckwards
    Gotcha, so this would actually provide more accurate numbers for the max hp and tq it sounds like.
    Any idea what would happen if you drove it on the street like that? I guess I don't quite understand how the whole lockup thing works. Im guessing there is a good bit of slip/slop during normal driving?
    nd4spdbh likes this.
  5. Jul 23, 2020 at 10:14 AM
    #6705
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    It locks and unlocks all the time depending on driving conditions. Just the logic in the trans usually doesn’t let you floor it and stay locked I think depending on what gear you are in and when you floor it.
  6. Jul 23, 2020 at 11:17 AM
    #6706
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    shoot me your tune and ill make a dyno 4th gear lockup tune that should work for what you are trying to acomplish.
  7. Jul 23, 2020 at 11:18 AM
    #6707
    nd4spdbh
    SoCal
    You can achieve 4th gear lockup pretty easy, just stick it in 4th gear and get up to ~45mph with light throttle and you will be locked. You will notice you will roll into the throttle and rpms and speed will increase at the same rate. When you are unlocked you will notice that the rpms will move up faster than then speed does.
    The problem comes in when trying to dyno tune and you dont want the truck to shift or be unlocked due to extra heat in the trans / driveline losses / extra variables due to torque converter slip. And a street driveable trans tune will unlock and downshift down to 3rd or even 2nd when you go WOT from low rpms when in 4th and locked.
    BassAckwards[QUOTED] likes this.
  8. Jul 23, 2020 at 11:35 AM
    #6708
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sent you both of my tunes. I explain what is going on in the email. Thanks brother!
  9. Jul 23, 2020 at 12:28 PM
    #6709
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @mightytacoman I think I got it. Rev limiter has been set to 5700 and I'm seeing a peak cutoff of about 5,868 as per my latest log. I think I'll keep it there. However, with saying that, I am still not totally convinced those 12 tables must be changed in order to obtain the results needed to see the your desired redline. They may help the computer stay in control past its OE limits though that way its not blindly just exceeding known limits, similar to the way the MAF was overrunning on the smaller pulley blower trucks. I am out of time today to make changes outside of the TCC lockup file that @nd4spdbh is going to send me. If you want to give it a shot and take logs of the changes which reflect the increase without modifying the the tables today, feel free to do so and let me know. :thumbsup:
  10. Jul 23, 2020 at 1:48 PM
    #6710
    nd4spdbh
    SoCal
    Check you email, and good luck. 4th gear tcc locked wot runs from just above 1500rpms on up will put a HUGE strain on everything. LET US KNOW HOW IT GOES!
    12TRDTacoma[QUOTED] likes this.
  11. Jul 23, 2020 at 2:01 PM
    #6711
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it puts a strain on things do you think I SHOULD run the file while I'm there then?
  12. Jul 23, 2020 at 2:16 PM
    #6712
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    It’s just gonna put a load on the motor. Imagine driving a manual and taking off from 3rd instead of 1st. Same thing. You’ll be safe running it locked in 4th from low rpm
  13. Jul 23, 2020 at 2:16 PM
    #6713
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I don't see how it would be much different than a 4th gear pull in a manual starting from 1500 RPM...?
    Roll into, don't just slam WFO and should be fine
  14. Jul 23, 2020 at 2:55 PM
    #6714
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I mean these are the things I sort of figured, but sometimes it's best to heir on the safe side to ask just in case.
  15. Jul 23, 2020 at 3:11 PM
    #6715
    nd4spdbh
    SoCal
    I would probably log on the chart vs time page engine rpm and trans input rpm with the same bounds you will see slight variances as the sensors dont read quite the same rate but if you start seeing deviations that means the TCC lockup clutch will be slipping. (you could even get fancy and do a custom math parameter comparing the two and give you a % error)
    The trans should be able to handle this, but it was never tuned to be in lockup under WOT
  16. Jul 23, 2020 at 3:25 PM
    #6716
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Gotcha. I got your email earlier BTW. Thank you for doing that for me. I am going to be heading over to the shop I'm supposed to be at in about 5 minutes.
  17. Jul 23, 2020 at 4:16 PM
    #6717
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm FINALLY back from my backpacking trip in Northern NM! Back a day early, but what a trip.. Anyway, I'll be catching up on PM's/emails this evening/tomorrow.
  18. Jul 23, 2020 at 7:15 PM
    #6718
    nd4spdbh
    SoCal
    Glad you took some time for you man! No rush on getting back, we all understand everyone has their lives outside of TW!
  19. Jul 23, 2020 at 8:33 PM
    #6719
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I'll admit I haven't seen a good diagram of how the torque converter lockup works, but in my head I think I was picturing it clamping together inside the torque converter kinda like a clutch and flywheel.
    Is it at all like that? Is damage to the trans less likely while not locked up?
  20. Jul 24, 2020 at 10:51 AM
    #6720
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    When switching the ECU’s and doing the relearning is it normal for the dash to be acting all crazy?
