HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 2, 2020 at 11:18 AM
    #6781
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s worth a try if you have the desire/time/resources. I’m sure there are several guys who would benefit, which is one of the reasons I was willing to try it myself.
    12TRDTacoma[QUOTED] and SUMOTNK like this.
  2. Aug 2, 2020 at 11:22 AM
    #6782
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I believe I do have the resources to flash the odometer to my mileage. I'd have to toss my tool on my truck to see if I can do it to my speedo first to confirm.
  3. Aug 2, 2020 at 11:41 AM
    #6783
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Hey @loginfailed what is your PCM part#?
    The 2012-2015 cluster is a part # 83800-04G40 and there is no deviation amongst the years according to the Toyota parts catalog.
  4. Aug 2, 2020 at 1:12 PM
    #6784
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    The table is simply a 3d table with air load on one axis and rpm on the other for guestimating purposes. These guestimation a are referenced for component protection fueling mainly.
    1slow4.0 likes this.
  5. Aug 2, 2020 at 1:37 PM
    #6785
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Original (2014) 89661-04G60
    Current (2011) 89661-04E30
    Torspd likes this.
  6. Aug 2, 2020 at 1:53 PM
    #6786
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh so you switched to a 2011 cluster after all? If you did that explains the return of full functionality.
    Torspd likes this.
  7. Aug 2, 2020 at 3:27 PM
    #6787
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    No. I only swapped the engine control module. Did not change clusters. I do have a 2011 cluster but I did not even try installing it since cruise indicator and temp gauge are working.
    You asked for the PCM part number.
    12TRDTacoma[QUOTED] likes this.
  8. Aug 3, 2020 at 8:17 AM
    #6788
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Hey guys looking for specific table numbers id's I know they have been added for 3ywg2700,2800,2900 but currently not available for my version.
    Can someone with one of those versions post the tables id numbers for decel fuel cut and long term fuel trims disable?
    JustDSM likes this.
  9. Aug 3, 2020 at 8:37 AM
    #6789
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Sent you those stock calibrations. Check your email buddy!
  10. Aug 3, 2020 at 8:45 AM
    #6790
    mightytacoman
    Kel
    4.5L 1grfe
    you the man buddy! :cheers:
    nd4spdbh and 12TRDTacoma like this.
  11. Aug 4, 2020 at 10:59 AM
    #6791
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I went the route of a tuned ECU from JustDSM. Came in yesterday and installed it last night. Of course after installing it I took it for a drive around town and up and down some long stretches. There's definitely a change in driving the truck and how it responds. On the engine and throttle side, it seems more responsive and more sensitive to input. Power wise, it's hard to tell if there's more HP, but I know that wasn't full the intent here. For those that knew how the earlier Tacoma's drove, it's more reminiscent of that. Which I like.
    On the transmission side the shifts seem quicker and sharper. They also happen sooner which helps give you the power when you want it. For example, when making a right turn at a green light, the truck accelerates nicely out of the turn. There's a quick downshift from the trans tune and much better pick up with the engine tune compared to stock.
    There are a couple things that I need to observe longer before I make further judgement on. One is the truck seems to stay in gear longer when under load or encountering a hill. Which I do like in most cases, like around town. I also did my usual commute home from work last night and loved it. On the longer stretch drives uphill, because the shifting is more aggressive, it'll tend to hold 3rd gear a bit long and in some cases I wasn't sure if it would shift to 4th. So I'd do the D-4-D to get it to up shift. I'm going to test it more this weekend when I make my long commute over the mountain. I'm hoping it'll learn its way out of this, but we'll see.
    The second thing I noticed was every now and again I'd hear this rattle at the engine, like it's knocking (or maybe it's something else). I used to hear something similar back before I did the TSB for the engine knock. It comes and goes and it's hard to pinpoint, but I think it happens in a higher gear, going uphill and engine lugging a bit. Anyway, I want to give this more time to see what happens. It's nothing like it used to be prior to the TSB, but something I notice with the new tune since I haven't heard it in a while.
    I've only driven a short while on this setup, so these are only my initial observations. Overall I really like how the truck drives around town and on my commute route back home. So I want to say a BIG thank you to @JustDSM and @nd4spdbh for working so hard on the tunes and everyone else who has provided feedback to get the tunes where it's at today.
    nd4spdbh and jojotoo like this.
  12. Aug 4, 2020 at 11:24 AM
    #6792
    nd4spdbh
    SoCal
    Thanks for the feedback!
    Yup give the trans some time to figure out its AI. I really wish i could tune the AI trans functions on top of the shift points but alas.
  13. Aug 4, 2020 at 11:40 AM
    #6793
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I wish you could too! I like the shifting best after a new flash/ecu reset and it seems to get worse over time.
    BJR and mightytacoman like this.
  14. Aug 4, 2020 at 11:53 AM
    #6794
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Who remembers the brake pedal TSB? I think it was done on my truck before I bought it. It also involved a computer reflash that makes the ECU ignore the gas pedal above 1/3 of travel if the brake is applied simultaneously.
    Can this be undone via HPTuners?
  15. Aug 4, 2020 at 11:57 AM
    #6795
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Looking to do some brake stands?
    12TRDTacoma likes this.
  16. Aug 4, 2020 at 11:58 AM
    #6796
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sounds like it. :laugh:
  17. Aug 4, 2020 at 11:59 AM
    #6797
    nd4spdbh
    SoCal
    One can do full power brake stands with traction control off. You just cant brake boost at speed... not that anyone would need to do that in an NA or supercharged truck.
  18. Aug 4, 2020 at 12:39 PM
    #6798
    TireFire
    Olympic Peninsula
    07 truck so has no traction control
  19. Aug 8, 2020 at 6:47 AM
    #6799
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Finally get some free time to mess with the truck and the tune and ofcorse I can’t get into hp tuners and it won’t let me do anything. Just sent a ticket. I have no god damn luck. Been like 3 weeks since I’ve even be able to touch anything.
  20. Aug 8, 2020 at 6:51 AM
    #6800
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Make sure you go onto the website and reload the beta suite and you should be good. Same thing happened to a few of us.
