HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 9, 2020 at 7:58 AM
    #6821
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you get the extension harness/s?
  2. Aug 9, 2020 at 8:05 AM
    #6822
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    Excellent! Thank you. Free with Boot Camp it is :)
  3. Aug 11, 2020 at 9:33 AM
    #6823
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Another Bootcamp user here. No issues!
    aboftofbeam likes this.
  4. Aug 11, 2020 at 6:23 PM
    #6824
    aboftofbeam
    Karl
    San Diego, CA
    Bootcamp loaded out. VCM Suite downloaded. Impatiently waiting for the delivery ....
    Bonus, found a recovery install file for uTune - maybe I will play with that while I wait.
    loginfailed[QUOTED] and JustDSM like this.
  5. Aug 16, 2020 at 4:25 PM
    #6825
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Truck is getting new gears tomorrow, anything worth tweaking, or just the speedo section?
  6. Aug 16, 2020 at 4:31 PM
    #6826
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You can update the speedo section for the new R&P ratio. Is your tire size staying the same?
  7. Aug 16, 2020 at 4:35 PM
    #6827
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Yes, however, different from stock. I already updated tire size though.
  8. Aug 18, 2020 at 1:24 PM
    #6828
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    Figured I would ask ya'll in this thread....
    No experience in the tuning world. Bought a Volant "CAI" when I bought the truck 6 years ago and sold my stock intake. Found HP Tuners because I need to get rid of some weird CEL codes as well as change the speedo calibration. Just to make sure this unit can do that correct? Also, what intake to you tuner guys recommend for best performance. I have the 4.0 and planned on going to the 76mm throttle body if that makes any difference. Thanks
  9. Aug 18, 2020 at 1:37 PM
    #6829
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    1. You have plenty of intake already unless you are forcing in air with a turbo or supercharger
    2. what CELs?
    3. Cannot adjust your speedo, only hypertech inline system will adjust your speedo.
    Biscuits and mightytacoman like this.
  10. Aug 19, 2020 at 9:03 AM
    #6830
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    SOO, those that have had issues with the truck sticking in 4th gear due to trans AI with the v13 usually when accelerating onto the freeway. I SEE YOU! Finally did a solid long distance drip and had the same thing happen several times, pretty much only when accelerating onto the freeway in the mid throttle inputs and then holding steady around the 70mph mark. Only thing you could do was let off the throttle for some time (and even then that didnt always work) or D-4-D on the shifter.
    Sooo.... i will have to tweak v13 a bit but unfortunately i have NO idea how the trans AI works and interprets everything to make its decisions.
  11. Aug 19, 2020 at 9:21 AM
    #6831
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    D-4-D is by far the easiest solution. ive been doing it when i was on the stock trans tune before but im on 35s so ymmv
    Biscuits likes this.
  12. Aug 19, 2020 at 9:36 AM
    #6832
    nd4spdbh
    SoCal
    Yeah but i dont remember this happening on v12 AFAIK. so it has something to do with where upshifts n downshifts are in relation to what the AI trans thinks should be happening.
  13. Aug 19, 2020 at 12:03 PM
    #6833
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    Try adjusting the app% where the gear is sticking.
  14. Aug 19, 2020 at 12:15 PM
    #6834
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    Mine would do it with stock tune as well.
  15. Aug 19, 2020 at 1:02 PM
    #6835
    nd4spdbh
    SoCal
    Yeah, i gotta look back at my v12 vs v13 documents and see what i changed for the 4 to 5 and 5 to 4 shifts. Just gotta find some time.
    1slow4.0[QUOTED] and ARoman83 like this.
  16. Aug 19, 2020 at 1:22 PM
    #6836
    ARoman83
    Alex
    Wisco
    Only legal stuff
    v14 coming soon... :cheers:
    zippsub9 and nd4spdbh[QUOTED] like this.
  17. Aug 19, 2020 at 2:45 PM
    #6837
    nd4spdbh
    SoCal
    Probably flash on friday some changes im making. After looking at v12 vs v13, upshifts were hardly touched and really only down in lower speeds and throttle inputs, but what changed huge was the downshifts, mostly the 5th to 4th at higher speeds at higher throttle inputs
    This, I am THINKING is the cause of this hang, essentially the trans AI has a predefined range at which it goes, ok, "am i going to be able to hold this gear or will i shift to it and then have to downshift soon into the throttle pedal input"? That drastic change circled above I HOPE is the cause of this hang we are seeing with the 4 to 5 upshift as it seeds that the 5 to 4 downshift is too close.
    Time will tell!
  18. Aug 19, 2020 at 3:00 PM
    #6838
    Turdyota3000
    Round da corner
  19. Aug 19, 2020 at 3:43 PM
    #6839
    nd4spdbh
    SoCal
    Whelp, i made some changes, now to vet this v14....
    also
    9th revision of an engine tune (fuel, spark, torque tables)
    14th revision of trans tune
    5th revision of ACIS
    16th revision of MAF tuning...
    44 MAJOR tune differences over the lifetime of my HPTuner extravoganza... and there have definitely been some sub tunes in there too. Easily flashed 60-70+ times!
  20. Aug 19, 2020 at 5:57 PM
    #6840
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Figured I’ll post some initial impressions. With the caveat that in the 2 weeks since getting tuned I’ve only driven the truck twice for less than an hour of seat time :anonymous:
    Weather has been so nice in the PNW that I’ve been riding the motos as weapon of choice.
    I did notice the 4th gear hang @nd4spdbh is ironing out but other than that I find shifts much improved. stock motor (‘cept for retarded cam gears and Upper intake manifold Spacer) and I feel like the engine feels like my old T4R with the 3.4L and mechanical throttle. So, that’s a good thing in my book because the drive by wire just felt sluggish to me when I first got this truck. Also notice significantly harder pulling from 1,000 to 2,700 rpm where it matters most for me.
    Wife borrowed the truck this week for a Costco run, didn’t know about the tune and asked me what I did to it when she got back. So there, it’s not a Placebo lol!
    Glad I got the tune! Will be interesting to see the effect on MPG once I actually go through a couple of tanks.
