HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 11, 2019 at 6:10 PM
    #681
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't forget the block-off plate .
  2. Apr 11, 2019 at 6:11 PM
    #682
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I got a note on my door that says I need to sign for the tuner :(. That’s ok tho. Truck won’t be out till next month anyways. Just got snow this week and they salted the crap outta the roads again.
    05Taco4x4 likes this.
  3. Apr 11, 2019 at 6:52 PM
    #683
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Ok peeps. How many people have bought the hp tuner? Anyone else have one with a supercharger and 6 speed?
    BillDaCat8 and Norton like this.
  4. Apr 11, 2019 at 7:16 PM
    #684
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    That's my combo, but I'm spectating for a while before I jump in.
  5. Apr 11, 2019 at 7:28 PM
    #685
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I’m close to jumping
  6. Apr 11, 2019 at 7:30 PM
    #686
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Ditto
  7. Apr 11, 2019 at 7:52 PM
    #687
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Dont we all!
  8. Apr 11, 2019 at 8:04 PM
    #688
    Roostfactor
    TX panhandle
    When you try to load a tune initially into the ecu, the software charges your 4 credits and uploads the tune. From this point you have unlimited access to read and write to that ecu (with the HPT interface).
    For example, I have already loaded two different tunes in my truck today. No extra charge. @loginfailed has probably loaded 15 different tunes already. Its amazing!
    I have now nicknamed @JustDSM "Neo"
  9. Apr 11, 2019 at 8:08 PM
    #689
    Roostfactor
    TX panhandle
    Have you always wanted the consistency of the TRD tune but with the ability to fully adjust and control just about every useful parameter to dial in your tune to your truck?
    If your answer is even close to saying yes then you have your answer. :D
  10. Apr 11, 2019 at 8:21 PM
    #690
    Roostfactor
    TX panhandle
    Some features already fully functional:
    1. SAI delete
    2. Secondary O2 cels disabled
    3. Injector calibration for 61lb injectors (thx @JustDSM for all the math work and @Hacktacular for the injector specs)
    4. Full control of electronic throttle.....Sprint booster cant even dream of the tuneability.
    That is not even getting into the meat of the tune.
    bijick, Biscuits, Norton and 9 others like this.
  11. Apr 11, 2019 at 8:34 PM
    #691
    ThomasMore66
    Dallas/Fort Worth & Durango
    6 speed? Wtf?!
  12. Apr 11, 2019 at 8:44 PM
    #692
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I bought my MPVI2 cable on Amazon today ($270 w/o credits) but says it comes with a discount code on any amount of credits. It was the best deal I could find today.
  13. Apr 11, 2019 at 9:10 PM
    #693
    Roostfactor
    TX panhandle
    Better than my deal. I bought the Pro full price the day after I found out about this.
  14. Apr 11, 2019 at 9:12 PM
    #694
    Roostfactor
    TX panhandle
    Some drivers still choose to have full control over the gears, not their coffee cup. :rofl:
    bijick, jfoster92, BillDaCat8 and 8 others like this.
  15. Apr 11, 2019 at 9:33 PM
    #695
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @Roostfactor I'll take a set of JFR block off plates. Add it to my tab for the ypipe or I can PayPal you now.
  16. Apr 11, 2019 at 9:36 PM
    #696
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    For the SAI delete, how involved is disabling it from the ECU in the software after physically removing the system.
  17. Apr 11, 2019 at 11:20 PM
    #697
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Un-check a bunch of boxes and then upload it to the ECU. If you need help, I can guide you through it via TeamViewer.
  18. Apr 12, 2019 at 3:17 AM
    #698
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
  19. Apr 12, 2019 at 3:25 AM
    #699
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Those are the ones I’m running. Yes there’s a harness adapter needed for them to be plug and play. They are 14mm.
    I got them from URD, but you can get them cheaper elsewhere.
    https://www.urdusa.com/injector-harness-adapter-denso-to-boschlucas-ev1/
    https://www.urdusa.com/61lb-mulit-fuel-fuel-injector-for-1gr-fe/
  20. Apr 12, 2019 at 3:29 AM
    #700
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    awesome news i keep getting a o2 sensor code. havnt taken time to dio it. i have 02 simulators never got a cat code. relaced the o2 sensor and still have the same code. but if the hptuner can get rid of the 02 sensor codes then f it. sell the 02 simulators. making money back
