HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Nov 29, 2020 at 11:24 AM
    #7041
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Welcome to the pack. Says the guy without it. ;)
  2. Nov 29, 2020 at 11:32 AM
    #7042
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Yep, this was 1.2 with the test vvti. I also made the couple of changes to the trans tuning to bring that up to v14. I had to get a new laptop over the summer and was very lazy about being hptuners installed again. I shouldn't have waited so long, but version 1.1 was so good it was easy to wait.
    Are you generally going with the test vvti for most people at this point?
    The slower off the line response could also be chalked up to all my junk loaded up for the trip. Looking back at your pm you mentioned the changes would likely be seen above 4400rpm, which I may have never even hit!
    JustDSM[QUOTED] likes this.
  3. Nov 29, 2020 at 11:42 AM
    #7043
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I added some advance down low in the test file which should have helped the low end. Perhaps see how it feels without the extra ballast and see?
    Yeah, there were some changes made above 4400 which should help top end, but I gather you weren't playing around in that region much on a trip. You should note some improved top end. Nothing "OMG" like, but some extra pep. If you want to leave the test file in for now, see how it does without the ballast and let me know.
    The VVTi test file that you're running is pretty much standard on most S/C setups now as I had feedback from a number of folks that it was a step in the right direction so I've elected to use that data as standard fare on appropriate setups.
  4. Nov 29, 2020 at 1:27 PM
    #7044
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You make up for it in “other” ways. :thumbsup:
    Torspd[QUOTED] likes this.
  5. Nov 29, 2020 at 5:06 PM
    #7045
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Just did a 700ish mi round trip with my "v15" trans tune that I have been testing to try and get rid of the 4th gear hang.
    Most of this trip however was loaded with 4k lbs of trailer n gear so I can't give it a fair test result... That stated I averaged ~10mpg towing with lots of wind and LOTS of elevation gain at 65mph so can't complain.
    I got a 1100ish mile round trip unloaded trip planned next weekend where I'll really be able to see if "v15" has fixed issues. I will report back.
    PhoS, BassAckwards, 05Taco4x4 and 8 others like this.
  6. Dec 1, 2020 at 1:52 PM
    #7046
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
    I bit the bullet and got one ordered up!
    rmepilot, 1slow4.0, ARoman83 and 5 others like this.
  7. Dec 1, 2020 at 5:59 PM
    #7047
    TheSupremeReader
    TheSupremeReader Well-Known Member
    Andrew
    TRD OR DCSB
    Bit the bullet and just got my tuner over the holidays. About to drop some cam gears in and then get some tuning done. What's the overall process for jumping in on the trans and engine tunes discussed here?
    1slow4.0 likes this.
  8. Dec 1, 2020 at 6:42 PM
    #7048
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Congrats! Unless you have a local tuner, recommend you contact @nd4spdbh for transmission tune info and @JustDSM for your engine tune.
  9. Dec 1, 2020 at 6:51 PM
    #7049
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    It's pretty simple.
    Grab your tune file. Always a good idea to save the stock file somewhere safe.
    Contact @JustDSM and pay him. Email him your tune file. Wait and he will send a tune back that's both engine and trans.
    Upload tune file.
  10. Dec 2, 2020 at 2:14 PM
    #7050
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    MPVI2 arrived in the mail. Looks nifty.
    There is a problem though, and it seems pretty significant:
    It won't fit into the OBD port.
    The cardboard and plastic keeps getting in the way.
    Wat gives?
  11. Dec 2, 2020 at 5:31 PM
    #7051
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Check the intelligence of the box. If box intelligence > your’s, then get significant help. :thumbsup:
    Your welcome in advance. :D
  12. Dec 2, 2020 at 7:23 PM
    #7052
    Biscuits
    My man. I knew I could count on you, Rod.
    Torspd and Lurkin[QUOTED] like this.
  13. Dec 2, 2020 at 10:14 PM
    #7053
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    You must've gotten the obd1 box. You need the obd2 box.
    Biscuits[QUOTED] likes this.
  14. Dec 2, 2020 at 10:32 PM
    #7054
    Biscuits
    Dang it. I thought I ordered the OBD2. This is what happens when you cannot read, folks.
    rmepilot likes this.
  15. Dec 3, 2020 at 2:54 PM
    #7055
    djtacoma
    djtacoma Active Member
    2014 Tacoma TRD Off Road DCSB
    Magnuson Supercharger, Cam gears, King 2.5 Coilovers and shocks, SPC UCAs, Icon progressive add-a-leaf, Wheelers u-bolt flip with Superbumps, Tom Woods one-piece driveshaft, TRD Pro wheels, 265/70/17 KO2s, air freshener
    If anybody is having weird off-idle stumbles or hesitations take a good look at your oil control valves. Had a very slight intermittent hesitation I couldn't figure out for a long time but it was never a huge deal to me until I installed my tune. The tune somehow amplified that hesitation to the point where I decided to reinstall the stock tune. The only code my truck ever had was a P0022 and it happened only once which was my only hint that the oil control valves could be going bad. After installing new OEM valves, that hesitation went away completely. Testing the old valves, I saw the passenger side one would occasionally stick when activated. The valves also have small filters that are installed on the side of the heads but I haven't replaced them yet. I'm planning a supercharger install so I'll replace them then when I'll have better access.
    Was talking with JustDSM and he mentioned that I should post up my findings so it's out there for anybody running into the same issue.
  16. Dec 3, 2020 at 3:17 PM
    #7056
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    djtacoma and JustDSM like this.
  17. Dec 3, 2020 at 8:20 PM
    #7057
    Biscuits
    The software needed is the main VCM Tuner suite or the Beta?
    JustDSM and 1slow4.0 like this.
  18. Dec 3, 2020 at 10:15 PM
    #7058
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Beta
    JustDSM, Norton and Biscuits[QUOTED] like this.
  19. Dec 3, 2020 at 10:16 PM
    #7059
    Biscuits
    Thank you sir
    JustDSM and 1slow4.0[QUOTED] like this.
  20. Dec 4, 2020 at 8:05 AM
    #7060
    SurviveToRide
    SurviveToRide Lover of anything on wheels
    Elijah
    2009 Access Cab V6 6MT TRD Sport
    17" TRD Pro Wheels 265/70/17 A/T’s Jason Topper
    has anyone figured out if this can fix the rev hang?
    its really annoying having to wait two seconds between shifts.
    TodayWasTHeDaY and JustDSM like this.
