HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 4, 2020 at 8:06 AM
    #7061
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yes it can. I worked with HPTuners some time ago to get that sorted out.
  2. Dec 4, 2020 at 8:43 AM
    #7062
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Seriously worth it!
    Norton likes this.
  3. Dec 4, 2020 at 8:44 AM
    #7063
    Tbertrand
    Tbertrand Well-Known Member
    Travis
    Reno, NV
    2011 dclb
    Help!!!
    I borrowed an old pc, I started uploading the new file into the truck, looked at power, 20% so I grabbed the charger, by the time I could plug it in, the laptop died! I got it fired back up on the charger and tried restarting the transfer, and it says transfer failed....
    Truck will not start.
    Just84 likes this.
  4. Dec 4, 2020 at 8:45 AM
    #7064
    SurviveToRide
    SurviveToRide Lover of anything on wheels
    Elijah
    2009 Access Cab V6 6MT TRD Sport
    17" TRD Pro Wheels 265/70/17 A/T’s Jason Topper
    Thanks guys! I'll definitely add that to the list of things i need sooner rather than later. I think i wanna get that stupid throw out bearing sorted out first though.
  5. Dec 4, 2020 at 9:03 AM
    #7065
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    try re-sync'ing the interface, that worked when I was getting that msg
    ...hoping that didn't brick your ecu...
  6. Dec 4, 2020 at 9:44 AM
    #7066
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am sorry to tell you this but it sounds like you have probably bricked the ecu.
    Your options now would be to find a used ecu of the same model year and trans truck, which then you may have to buy more hptuner credits, or if you can get in contact with @OVTune I believe he has a way to unbrick ecus. I imagine getting ahold of him right now may not be easy since it is holiday season.
    Norton and Tbertrand[QUOTED] like this.
  7. Dec 4, 2020 at 9:45 AM
    #7067
    OVTune
    OVTune Well-Known Member
    OVTune
    We do not provide un-bricking services anymore unless it's to one of our customers.
    Torspd and Tbertrand like this.
  8. Dec 4, 2020 at 9:58 AM
    #7068
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not sure what you've tried, but I would also try to read the ecu. Truck not starting doesn't look good, and if you can't read or write it, looks even worse, sorry to say.
  9. Dec 4, 2020 at 10:05 AM
    #7069
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Interestingly enough, I'm getting the same error as @Tbertrand. I can start my vehicle, however.
  10. Dec 4, 2020 at 10:09 AM
    #7070
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    From what I experienced, you get it if you have just assigned your credits to your ECU and you try to write a tune before you resync the interface. Once you assign your credits and sync it again, it writes.
  11. Dec 4, 2020 at 10:12 AM
    #7071
    Biscuits
    So I initially did as you described with assigning the credits. However, I've resynced multiple times and I'm still getting the same error.
  12. Dec 4, 2020 at 10:12 AM
    #7072
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Then you sir are beyond me...
  13. Dec 4, 2020 at 10:12 AM
    #7073
    JustDSM
    Justin
    Ogden, UT
    Do you have WiFi at the truck when attempting to flash?
  14. Dec 4, 2020 at 10:13 AM
    #7074
    Biscuits
    Yes, I'm in my truck now.
  15. Dec 4, 2020 at 10:25 AM
    #7075
    Biscuits
    @JustDSM should be on the shortlist for Time's Person of the Year. Thank you again for your help.
    For future reference, do not have your truck running when attempting to write to the ECU. That was my mistake. Just have the key to the on position and follow the instructions.
    About to check out this goodness.
  16. Dec 4, 2020 at 10:30 AM
    #7076
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Highlighted!
  17. Dec 4, 2020 at 10:31 AM
    #7077
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I am curious if @JustDSM has had a chance to play with the ovtune stuff. Since he is now only repairing bricked ecus if you own his products that does give him a bit of an advantage to hptuners. Unless someone else here knows how to unbrick ecus?
  18. Dec 4, 2020 at 10:32 AM
    #7078
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Looks like you have a 4cylinder. Does HPTuners support the 2TR-FE now?
  19. Dec 4, 2020 at 10:34 AM
    #7079
    SurviveToRide
    Elijah
    Just upgraded to my dream truck with the 4.0 V6. The old 5 speed in my other truck had almost no rev hang, so it’s a big difference going to a tranny where I push my clutch in and the revs stay where they are for two seconds.
    TireFire[QUOTED] likes this.
  20. Dec 4, 2020 at 10:43 AM
    #7080
    JustDSM
    Justin
    Ogden, UT
    I have looked at the VFTuner software in it's initial release form for the 3rd Gen, however I have not (yet) had a chance to see what it's like for the 4.0L. I've had a chat with Mat, and once it's available I will be giving it a whirl. I do intended to support all 4.0L platforms with VFTuner and will also continue to offer HPTuners support.
