HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 27, 2021 at 1:46 PM
    #7401
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Shoot me a PM.
    Ill bet the 4WD ecu is completely separate from the main ecu thus not tuneable. There are likely shift parameters for stuff in 4low but thats about it that will be tuneable with regards to the 4wd system.
  2. May 27, 2021 at 6:37 PM
    #7402
    slgordon57
    slgordon57 New Member
    Shannon
    2015 Tacoma
    CAI & TRD Exhaust
    I'm hoping someone on this thread will give a newbie a few pointers. I have a 2015 Tacoma with 4.0L V6 and I'm looking to squeeze a little more 'get up and go' out of it. I just purchased an HP Tuner and was planning to make some adjustments but I'm not afraid to admit that I'm in over my head. I know my way around under the hood but I'm brand new to tuning.
    All I really want to do is change the tire size since I recently went up a size and make any adjustments I can to give it a little more pep. The only mod I've made since I bought the truck was to add a K&N CAI and TRD exhaust. I know how this forum feels about the K&N CAI but I'm not motivated to rip and replace it at this point.
    So my question is; What do I need to modify with the HP Tuner to squeeze a little more out of my relatively stock truck.
  3. May 27, 2021 at 8:57 PM
    #7403
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    deeezy likes this.
  4. May 28, 2021 at 5:45 AM
    #7404
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    You can tweak your afr and timing tables to start. A better trans/shifting map is popular too.
    I too would recommend a tune from justdsm as he will get you set up right.
  5. May 28, 2021 at 5:47 AM
    #7405
    slgordon57
    Shannon
    2015 Tacoma
    CAI & TRD Exhaust
    Super!!! Thanks for your input. I'll check out the thread and reach out to @JustDSM.
  6. May 28, 2021 at 9:20 AM
    #7406
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Hey @nd4spdbh, I'm in the process of changing the shift points of my V13 trans tune to the V15 and was wondering if I am supposed to change the "Normal Fault" shift points and not only the "On Power" shift points? Thanks man!
  7. May 28, 2021 at 9:49 AM
    #7407
    nd4spdbh
    SoCal
    Yeah dont touch the fault shift points, those are when the truck goes into limp mode due to over heated trans.
    steezinstangl[QUOTED] likes this.
  8. May 28, 2021 at 9:56 AM
    #7408
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Gotcha that makes sense, thanks again man.
    nd4spdbh[QUOTED] likes this.
  9. May 28, 2021 at 2:34 PM
    #7409
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Ooh my @nd4spdbh top secret super sauce beta tune just came through.
    :spy: Gonna flash that when I get home and test over the weekend. Will report back after testing to see if it’s safe for the general public
    nd4spdbh likes this.
  10. May 28, 2021 at 2:36 PM
    #7410
    nd4spdbh
    SoCal
    I assume no responsibility.... just make sure to send it!
  11. May 28, 2021 at 3:05 PM
    #7411
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Bruh am I the type of guy that really needs a reminder to send it?
  12. May 31, 2021 at 8:17 PM
    #7412
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Sent enough?
    https://www.instagram.com/p/CPjHOqBg_sq/
    But in all seriousness the tune seems to be working great. Put about 200 miles on the new @nd4spdbh super spice trans tune. About 80 road miles and 120 dirt with just about every situation hit.
    For anyone curious, this super spice trans tune technically has a very deceiving name and to some may be the least spicy tune you could do. It pairs the spicy batch 3 upshift tune with the worst downshift tune possible lol. The truck will actually never downshift unless engine rpm goes below 650rpm I believe unless the shifter is moved into a lower gear.
    Big reason behind this is the truck build (seen in video) and where I live. House to off road spot seen here. EA74F96B-FED6-4DE3-A88A-EA373AE867C9.jpg
    Truck sees more dirt than street per year. And no matter how “spicy” @nd4spdbh could make a tune, I was never happy with how aggressive or quick the shifts came and hated the mid throttle gear hunting when I’d be feathering the throttle through sections. So with 25 years of riding motorcycles I said to heck with the auto, let’s try to make a “manual” trans tune. So keeping the spicy batch 3 upshift points for streetability and still making it able for the wife to hop in and drive if she wants. This tune allows me to drive the truck as if it were a manual when off road, using the shifter for limiting up shifts and forcing downshifts, this tune seems to be perfect for me this far.
    For those wanting to try it out, I would say this is only for those that are supercharged. NA just doesn’t have the power to pull when you throttle down on “street” driving. Anyone running bigger tires needs to regear for the same reason. I’m running 5.29 gears on my setup. And lastly, this is specifically for those that think their trucks are “race” trucks. Where I typically drive I keep the truck stuck in 3rd or 4th gear running rpm’s between 3-4K and right in the meat of the power.
    TLDR: thanks @nd4spdbh for finally listening snd helping me get a “race” tune for the race truck. Only been asking for a year or two. This tune is not for everyone and probably only a few other people that would really like this tune.
  13. Jun 1, 2021 at 9:37 AM
    #7413
    dib
    dib Well-Known Member
    Gary
    Escondido, CA
    11 TX Pro
    Camburg LT and Magnuson Supercharger
  14. Jun 1, 2021 at 9:53 AM
    #7414
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  15. Jun 2, 2021 at 12:34 PM
    #7415
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  16. Jun 23, 2021 at 11:53 PM
    #7416
    4runnersickness
    4runnersickness Member
    Jovany
    2009 Black Urban Runner 4x4
    URD Headers, Afe Intake, Pedal Commander, URD MAF Sensor Calibrator, Magnaflow Muffler, URD FUEL Pump conversion Kit
    Where the fuck is the 4th Gen 4runner FML!
    Is this tune similar to UCON?
  17. Jun 24, 2021 at 5:02 AM
    #7417
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Makes me curious. Since ethe UCON can tune it, same plugs as the Tacoma, I wonder why the HPTuner cannot? Possibly because the ecu's have not all been unlocked? @JustDSM
  18. Jun 24, 2021 at 5:06 AM
    #7418
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's probably a calibration ID thing to be honest.
    Torspd[QUOTED] likes this.
  19. Jun 24, 2021 at 10:18 AM
    #7419
    4runnersickness
    Jovany
    But what are the major differences in a UVtune and UCON? I know UCON does ignition timing. I know UVTune does Octane93 tuning as well as transmission. Their website doesnt really say much.
  20. Jun 24, 2021 at 10:40 AM
    #7420
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    I sold my 2nd gen hptuned Tacoma a month or two ago and bought a 4th gen 4Runner last month. I haven't had the time yet, but plan on connecting to it and see what happens if I try to pull down a "stock" file, if it'll match up to a calibration ID or not.
    One of the ideas Justin had that I still need to do more research on, too, is how plug n play a tacoma ECU would be in the 4runner chassis. If it's a matter of just swapping around a few pins might be worth it.
