HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 24, 2021 at 11:20 AM
    #7421
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Should be a really quick test to do what you say. I am curious.
    TacoEspecial likes this.
  2. Jun 24, 2021 at 11:42 AM
    #7422
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    "Tuning for octane" is tuning ignition timing.
    12TRDTacoma and Torspd like this.
  3. Jun 24, 2021 at 12:28 PM
    #7423
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Let's get some terms straight as to not add confusion to the thread.
    UCON is a piggy back type self tuner with 3 levels of generic maps depending on presence of catalytic converters and a 7th injector option, that manipulates and spoofs signals to the oem ECU. Able to use TRD S/C flashed ECU but tends to work better without the TRD flash.
    OVTune is a flashing device to overwrite the oem ECU.
    HPTuner is a flashing device to overwrite the oem ECU with datalogging capabilities. Works better with the expanded tables provided by the TRD S/C flash.
    Please correct any of my errors.
  4. Jun 25, 2021 at 8:02 PM
    #7424
    4runnersickness
    4runnersickness Member
    Jovany
    2009 Black Urban Runner 4x4
    URD Headers, Afe Intake, Pedal Commander, URD MAF Sensor Calibrator, Magnaflow Muffler, URD FUEL Pump conversion Kit
    I don't know anything. I am trying to figure this out. This all sounds good, I called URD and that is how they explained it as well. Their website briefly explains what variables it alters.
    I am the type of guy when I install something in my car I like to know exactly what it is doing and how.
    So I just read, gather some facts, see what people say on here, then I call the manufactures and see what they say.
    I am about to pull the trigger on the OVTune though, just waiting on an email from them with several questions that I have which I am hoping they give me a straight answer.
  5. Jun 25, 2021 at 8:05 PM
    #7425
    4runnersickness
    Jovany
    Thank's for the clarification. Yeah, I don't know shit, just here learning hoping to make my Urban Runner more responsive.
  6. Jun 26, 2021 at 3:07 PM
    #7426
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Just trying to learn a bit myself with my new (to me) 2009 PreRunner. I thought OVTune was putting almost all their efforts into the 3rd Gen platform. I see you have headers and the pedal commander. How effective would you rate them? Does a tune make the pedal commander unnecessary?
  7. Jun 27, 2021 at 1:08 PM
    #7427
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    No dice :pout:
    Specified the hardware to be the same denso 768k (might have those #'s slightly wrong..) as the tacomas and still failed to read. Checked all the other toyota hardware options, too.
    Torspd[QUOTED] likes this.
  8. Jun 27, 2021 at 4:18 PM
    #7428
    Philby
    Philby Active Member
    Cairns Australia
    Hilux SR5 4x4 TRD S/C
    One of the ideas Justin had that I still need to do more research on, too, is how plug n play a tacoma ECU would be in the 4runner chassis. If it's a matter of just swapping around a few pins might be worth it.[/QUOTE]
    Years ago (2009) I swapped my Australian Hilux ECU for a Tacoma ECU to enable reflashing once I fitted the TRD blower. There was a few pin outs to change but all good and I am still running this setup today.
    Torspd likes this.
  9. Jun 28, 2021 at 1:08 AM
    #7429
    4runnersickness
    Jovany
    Out of all the minimal mods that I have done, Pedal Commander is by far the best and first investment into your truck. It changes throttle to hit higher RPMS from the start, hold the RPM's longer, and within the modes (Eco, City, SPort, Sport2) you have 8 sensitivity levels. I currently have mine on Sport with +1 Sensitivity. It actually saves gas if you do not floor. It instantly pulls at 2000 rpm.
    When I installed the aFe CAI barely felt anything, sounds great though! Then I had this mechanic install the headers, and the idiot did half ass job so it was leaking everywhere. Fix the problem, and they are great! Its not an enormous gain, but you can feel it and it also sounds great.
    However, if I didnt have the Pedal Commander, it would not put everything together. The Headers increase toque but the RPM's have to be at 2000 rpm for this. So the Pedal Commander gets that done real good. Holding the gears longer above 2000 rpm so you can feel the difference.
    The UVtune, I read it tunes throttle, but I am not sure if it will interfere with the Pedal Commander. I emailed OVtune 3 days ago with several questions, one which includes the question you just posed. As soon as I get an answer I will let you know.
  10. Jun 28, 2021 at 1:11 AM
    #7430
    4runnersickness
    Jovany
    Years ago (2009) I swapped my Australian Hilux ECU for a Tacoma ECU to enable reflashing once I fitted the TRD blower. There was a few pin outs to change but all good and I am still running this setup today.[/QUOTE]
    I am getting 19 - 21 MPG in the city and 23 MPG on highway. I have OEM 18" wheels and K0'2 265/65/18 rate E. As soon as my RR6-H wheels ship in July/Aug I will be putting lighter tires and further improve gas. These E K02 weigh 54 lbs.
  11. Jun 28, 2021 at 9:09 AM
    #7431
    spencermarkd
    Spencer
    So what the pedal commander does is intercept the throttle position signal and modify it. I.e. if you're in sport mode and pressing the throttle half down, it'll instead show you're pressing it 75% down, but if you're in eco mode, it'd only show 30% down. It doesn't change anything else, nothing in the trans tables, nothing in the actual tune.
    Both OVTune and HPTuners have the ability to adjust the throttle position map, rendering a pedal commander redundant and unnecessary.
    nd4spdbh and SUMOTNK like this.
  12. Jun 28, 2021 at 10:13 AM
    #7432
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    Not necessarily redundant/unnecessary. PC can allow for adjustments on the fly rather than editing tables and flashing a tune to go from eco to sport. There are instances on the trail where you might want more/less throttle response where a PC could be beneficial.
  13. Jun 28, 2021 at 10:37 AM
    #7433
    vettaco
    Vince
    09 AC PreRunner
    Thanks for posting up those observations. Sounds like the pedal commander wouldn't do much for a manual trans model. Considering headers, cam gears, and a tune.
  14. Jun 28, 2021 at 10:46 AM
    #7434
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    The on the fly changes definitely has merit.
    4runnersickness and spencermarkd like this.
  15. Jun 28, 2021 at 10:50 AM
    #7435
    TodayWasTHeDaY
    Russ
    Calgary
    Rev hang can be deleted with Hptuners which is worth the price alone in my eyes. Then the ability to maximize and personalize tuning for mods makes it a no brainer.
    ARoman83, 4runnersickness and Norton like this.
  16. Jun 28, 2021 at 10:51 AM
    #7436
    spencermarkd
    Spencer
    Good point, you might want to soften up the response on the trail, definitely a case for it there :thumbsup:
  17. Jun 28, 2021 at 11:55 AM
    #7437
    4runnersickness
    Jovany
    Correct.
    However,, I am currently getting 21 mpg in the city with my Pedal Commander. I don't know how much this opens the throttle body, but as soon as I step on it it gets me to 2000 rpm without wasting gas to get there.
    And at 2000 rpms and above I feel the Headers pull. If I didnt have the Pedal Commander to give me that instant Throttle Response, having the headers would be a disappointment. I would not be able to feel the increased torque until several seconds, and that is with a heavy foot on the pedal which tends to hold the gears longer when I dont want to. With the Pedal Commander I am instantly in 2000 rpms pulling, and unless I am pushing down heavy, it'll shift according for normal driving.
    I figured that the OVtune would make the Pedal Commander obsolete, I just want confirmation from OV themselves, among with my other 5 questions.
  18. Jun 28, 2021 at 12:29 PM
    #7438
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    OV got banned from TW and your asking them for confirmation on the hp tuner thread o_O
    12TRDTacoma, ARoman83 and Norton like this.
  19. Jun 28, 2021 at 12:32 PM
    #7439
    4runnersickness
    Jovany
    Really? I did not know. It was actually recommended to me on here.
    May I ask why speaking of it is banned from a thread?
  20. Jun 28, 2021 at 12:38 PM
    #7440
    4runnersickness
    Jovany
    Nice. Because I love my PC. So it can still parallel with HP or OV tune huh. That sounds great.
