HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 12, 2019 at 8:31 AM
    #741
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    o ive been meaning to ask can u use a mac? for a laptop
    12TRDTacoma and loginfailed like this.
  2. Apr 12, 2019 at 8:31 AM
    #742
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It makes sense regardless. As the boost pressure against the fuel coming out of the injectors, needs to be compensated for. Thus a 1:1, to balance the equation.
    12TRDTacoma, 05Taco4x4 and JustDSM like this.
  3. Apr 12, 2019 at 8:36 AM
    #743
    ThomasMore66
    Dallas/Fort Worth & Durango
    If you turn that off, will the guy at the inspection station see that its turned off?
    loginfailed[QUOTED] likes this.
  4. Apr 12, 2019 at 8:37 AM
    #744
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    exactly how i think sir!! our lord and savor torspd has spoken!
    Roostfactor and Torspd[QUOTED] like this.
  5. Apr 12, 2019 at 8:38 AM
    #745
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I 100% agree to this, however it’s going to throw off the fueling calculation as the TRD cal was developed around not having a 1:1 regulator setup.
    I’d still recommend doing the Mod, but it should be noted that traditional reasons for doing it are no longer present as one has the ability to fuel the motor to their desire without manipulating external systems.
    That was the point I was trying to make. Not whether it was a good idea or not. Just so we’re all on the same page.
  6. Apr 12, 2019 at 8:42 AM
    #746
    JustDSM
    Justin
    Ogden, UT
    PC only.. booo I’m a Mac guy
  7. Apr 12, 2019 at 8:42 AM
    #747
    ThomasMore66
    Oh you've asked, nobody has answered. I'm looking at my box (it came in one day! Prime FTW!) and there is no mention of what computer will work. Maybe on the website?
    loginfailed likes this.
  8. Apr 12, 2019 at 8:43 AM
    #748
    JustDSM
    Justin
    Ogden, UT
    According to @loginfailed no. Assuming a Geberic OBD2 scan protocol is used.
  9. Apr 12, 2019 at 8:43 AM
    #749
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    So got a question in this. I have the UCON with a unmolested ecu. NO TRD tune. Will this work with the UCON cam gears if left installed?
    loginfailed and JustDSM like this.
  10. Apr 12, 2019 at 8:44 AM
    #750
    JustDSM
    Justin
    Ogden, UT
    Yes.
    5thGearPinned and loginfailed like this.
  11. Apr 12, 2019 at 8:44 AM
    #751
    HPTuners
    HPTuners Well-Known Member
    You do not require a license (using credits) to Read or Save files, only when you Write the first time.
  12. Apr 12, 2019 at 8:44 AM
    #752
    ThomasMore66
    Is that a word? Geberic
  13. Apr 12, 2019 at 8:46 AM
    #753
    JustDSM
    Justin
    Ogden, UT
    LOL damn phone.. Generic
  14. Apr 12, 2019 at 8:46 AM
    #754
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    So i would only need the 4 credits to write both ECUs?
  15. Apr 12, 2019 at 8:47 AM
    #755
    ThomasMore66
    You could have lied and I would have believed you. Ha.
    Simple question, can I adjust the speedometer for tire size with this thing?
  16. Apr 12, 2019 at 8:47 AM
    #756
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    on the same page. trd cal is also only for 3.0 pulley lol seems like just yesterday tuning was if u were rich- add smaller pulley. if lean- add fpr mod. it was a simpler time. lol
  17. Apr 12, 2019 at 8:48 AM
    #757
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    yes but no one will buy ucon with out cam gears
  18. Apr 12, 2019 at 8:48 AM
    #758
    JustDSM
    Justin
    Ogden, UT
    Not currently, but that is supported in other applications. I bet we could get it added with a support ticket to HPT
  19. Apr 12, 2019 at 8:49 AM
    #759
    BassAckwards
    That would be awesome if i could use this on my 2TR to adjust this
    05Taco4x4 and JustDSM[QUOTED] like this.
  20. Apr 12, 2019 at 8:49 AM
    #760
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Just to clarify, I need the trd tune on my ecu to be able to do this (sc'd 6spd). Currently have ovtune and don't really want to buy another ecu if I can avoid it.
