HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 25, 2021 at 6:13 AM
    #7581
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  2. Sep 25, 2021 at 6:56 AM
    #7582
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lower levels that the 90's, with the population being larger, and still only marginal. All about the money.
    12TRDTacoma likes this.
  3. Sep 25, 2021 at 5:20 PM
    #7583
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Joining the party a wee bit late.
    I made it all the way to page #260 in this thread before skipping forward to see if key players are still in the mix. I'm about to drop $$ on the HP MPVI2+ and credits, and search out a spare "just in case" ECU. I know the 6sp ones are hard to find but I see from past posts it's also possible to run a 2013-2014 auto-trans ECU if necessary. I'm well-advised on ECU flashing risks, rewards, & best practices.
    Just ugpraded from a '99 Taco 2WD 2.4L utility/work truck to a '14 Taco 4L / 4WD / 6spd with 60K miles on it. N/A for the forseeable future but maybe in a year or three I'd put in a S/C. Interested in various off-road only mods, maybe adjusting the SAI setup a bit. Of course I look forward to the rev-hang adjust, improved throttle response curve, etc.
    Am I still good to go?
    Norton likes this.
  4. Sep 25, 2021 at 5:22 PM
    #7584
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yes. You will enjoy hptune. I too am a 6spd. The resident tuner, justdsm, is also n/a and I believe a manual too. He has a couple simple mods making it a sweet setup.
    GilbertOz[QUOTED] and Norton like this.
  5. Sep 25, 2021 at 5:25 PM
    #7585
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Another 6sp HPTUNERS justdsm user here. You’ll really like how it runs after the tune is installed!
  6. Sep 25, 2021 at 5:25 PM
    #7586
    GilbertOz
    GilbertOz Driver
    CA
    Sa-weeet.
    Just placed an order for an HP MVPI2+. Will get a high-quality short USB cable & plan to use my 2019 MB Pro with Windows 10 under VMware Fusion to run VCM Editor/Scanner. I have a NOCO Genius battery minder to use during flash procedures. Probably will pick up that spare ECU & test it out before I try a first flash.
    Norton and JuanitoBonito[QUOTED] like this.
  7. Sep 25, 2021 at 6:00 PM
    #7587
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    It comes with a good quality USB cable, I just got the same kit few weeks back. @JustDSM can help you out getting started with a tune pack. I just got his tune installed yesterday and enjoying the mild tune so far, haven't tested the aggressive tune yet.
    JuanitoBonito likes this.
  8. Sep 25, 2021 at 6:21 PM
    #7588
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I could be wrong but recall someone saying you could no longer run its off a Mac w/ VM setup. That would make things easy. I ended up using an old laptop just for this.
  9. Sep 27, 2021 at 2:26 PM
    #7589
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    You can, however you have to run bootcamp with windows!
  10. Sep 27, 2021 at 2:37 PM
    #7590
    nudavinci64
    Robert
  11. Sep 27, 2021 at 2:43 PM
    #7591
    ARoman83
    Alex
    Wisco
    Only legal stuff
    nudavinci64[QUOTED] likes this.
  12. Sep 27, 2021 at 2:50 PM
    #7592
    nudavinci64
    Robert
    indeed iota an end of an era but sounds like there is a parallel setup you can try but it’s a. Service based software like half that other stuff now.
  13. Sep 27, 2021 at 2:52 PM
    #7593
    ARoman83
    Alex
    Wisco
    Only legal stuff
    HPT, credits, windows cpu... Gets pricey lol
    nudavinci64 likes this.
  14. Sep 27, 2021 at 3:03 PM
    #7594
    nudavinci64
    Robert
    def not for the frugal
    12TRDTacoma and ARoman83[QUOTED] like this.
  15. Sep 27, 2021 at 3:36 PM
    #7595
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    I use a Surface tablet now that my work mac doesn't have parralels. Should be able to use anything that can run recent version of windows if that's all youre using it for.
  16. Sep 29, 2021 at 4:27 PM
    #7596
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Well worth it IMO
  17. Sep 30, 2021 at 6:43 PM
    #7597
    GilbertOz
    GilbertOz Driver
    CA
    I picked up a spare exact-replacement part# ECU for my 2014 AC 4L 4WD 6sp. I can't accept even the remote chance of "bricking" my truck so I'm going to test flash the spare ECU first. I'd rather do this outside the truck to save the trouble of physically swapping ECU's out of the truck until I want or need to do so.
    Can someone point me to a thread or resource on what parts to buy & how to construct a bench-flashing rig for the ECU? I have a suitable computer & will soon have the MPVI2+, so basically I need power supply & data pin-outs, or ideally a place to just buy a pre-made bench-flashing harness.
    (Already tried searching "bench flash" in the forums & found a lot of mentions of doing it, but nothing specific on the bench-flash hardware setup itself.)
  18. Sep 30, 2021 at 6:46 PM
    #7598
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Use a battery charger while you flash and you'll be fine. Most who run into issues are because the battery is less than 12.1 volts when they flash. Disable/pull fuses for all your aux do-dads, lights, bells and whistles when you flash.
    zerotimeouts, Torspd and JustDSM like this.
  19. Sep 30, 2021 at 7:12 PM
    #7599
    GilbertOz
    GilbertOz Driver
    CA
    I want a bench flash setup, thanks. Appreciate it if anyone can just point me to the pre-existing thread covering this, or if there's a place to just buy a pre-made bench-flash harness I'll do that.
  20. Sep 30, 2021 at 9:36 PM
    #7600
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    @JustDSM is the only one I know on here running a bench flash rig. I don't think he's documented it anywhere though, but is usually a fairly helpful fellow. There was an HPTuner update a while back, like months ago, that made an update to the write process and greatly reduced the chances of bricking> I don't think I've heard of one being bricked since. But yeah, it's a possibility, it's happened to several folks here.
    Also of note if you're using a spare ECU, have you reset the vin on it with techstream? Wouldn't want to have to pay for credits twice.
    kasnerd and Norton like this.
