HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jul 11, 2022 at 2:08 PM
    #7701
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I suspect you'll find the HPTuners (The Tacoma FAQ) thread helpful.
  2. Jul 11, 2022 at 2:23 PM
    #7702
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Oh wow haha yeah that’s getting bookmarked. Many thanks to you and @PhoS
    Norton[QUOTED] likes this.
  3. Aug 4, 2022 at 9:01 AM
    #7703
    Taco4evr87
    Taco4evr87 Member
    2015 4.0L 1GR-FE Taco, DCSB
    King 8" 2.5" Coilover fronts w/Dirt King Upper A arms Archive Garage Hammer Hangers w/ 4.5" shackles, Deaver leaf springs, King 14" 2.5" smoothies in rear, AG shock relocation kit
    @JustDSM I am having the same problem, what was the fix? Just a new ECU? (understand this is from two yrs ago)
  4. Aug 5, 2022 at 8:08 AM
    #7704
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Just to make sure I understand, can you elaborate and tell me a bit more about what happened?
  5. Aug 9, 2022 at 2:10 PM
    #7705
    Taco4evr87
    Taco4evr87 Member
    @JustDSM I’ll try to keep it brief. Had a few trouble codes, including ABS. Did not have a reader that could read ABS, so I tried to see if the HP Tuner software could read them (not really know if it could). It didn’t, so then I thought if I reloaded the tune I received from you that it would reset the ABS. In doing so it read some error (sorry, I can’t remember it), then the truck would not start (would crank but not start). The HP Tuner device started to come up with “failed init: failed to start”, and the other code reader will not connect to the truck.
  6. Aug 9, 2022 at 3:38 PM
    #7706
    JustDSM
    Justin
    Ogden, UT
    Sounds like you’ve bricked your ECU. But without specific details (like battery voltage during flash) or a multitude of other things it’s any ones guess what happened.
    Your ABS issues are unrelated to the tune. You’ll want to have that diagnosed separately.
    Torspd likes this.
  7. Aug 9, 2022 at 3:51 PM
    #7707
    Taco4evr87
    Taco4evr87 Member
    @JustDSM So worst case scenario I’ve bricked the ECU…what are my options in your opinion? Just new ECU and have Toyota reprogram it?
  8. Aug 10, 2022 at 3:37 AM
    #7708
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    If indeed bricked- Toyota can't reprogram and you'll need a new ecm.
    I have an an extra ecm I would part with but we need to confirm compatibility 1st. Mine is for an supercharged 09 4x4 auto
  9. Aug 10, 2022 at 11:09 AM
    #7709
    Taco4evr87
    Taco4evr87 Member
    Yeah, I have a 15 4x4 Man trans. No, worries. Just kinda needed the 2nd opinion so I can buy/find the ecm then will take to Toyota to reprogram. Thanks!
  10. Aug 10, 2022 at 12:23 PM
    #7710
    JustDSM
    Justin
    Ogden, UT
    Id pick up a used one, though '15 Manual ECUs are pretty slim to find on the used market. In a pinch, I can convert an Auto ECU for use in a Manual. As the Auto ECUs are literally a dime a dozen in comparison.
    zerotimeouts, Norton and scootter82 like this.
  11. Aug 19, 2022 at 5:35 PM
    #7711
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    The staff here on TW have come to an agreement that all major tuning threads will remain locked for a while. Why you ask? We get endless reports and messages regarding tuners bickering with other tuners or other unacceptable behavior. We are sick and tired of the immature actions and this is the last straw. The threads will be unlocked in one week. If there is ONE more instance of bickering, shitting on a competitors thread, or any more reports, we will remove all tuning threads and block it from future discussion. This is the last chance.
    Side note: BST rules still apply to tuners. Don’t join TW just to peddle your tunes without actively participating in the community or you will find yourself banned.
  12. Sep 9, 2022 at 10:26 PM
    #7712
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Unlocked now? I haven’t seen this bickering here but maybe I missed it.
  13. Sep 17, 2022 at 8:44 PM
    #7713
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Likewise.... wtf. I have been part of this thread since early on and i dont remember a single time IN THIS THREAD that bickering has taken place.
    Murphinator, vssman and Norton like this.
  14. Sep 17, 2022 at 9:12 PM
    #7714
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    Naw, it was the dweebs in the canned tune threads fighting. There has been a lot of competition in that market.
  15. Sep 18, 2022 at 8:06 PM
    #7715
    nd4spdbh
    SoCal
    Ahhhh ok that makes sense. Typical 3rd gen guys.
    Norton likes this.
  16. Sep 25, 2022 at 2:07 PM
    #7716
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Does anyone have the procedure for the ecu swap? I want to swap my stock one for my hp tuned one.
  17. Sep 25, 2022 at 2:12 PM
    #7717
    JustDSM
    Justin
    Ogden, UT
    You need a step-by-step for the physical ECU removal, or the resync procedure?
    Attached you’ll find the resync procedure to be done after you physically swap ECU’s.
    05Taco4x4, BassAckwards and 1slow4.0 like this.
  18. Sep 25, 2022 at 2:19 PM
    #7718
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Just the re sync. Thanks Justin!
    JustDSM likes this.
  19. Sep 26, 2022 at 12:43 PM
    #7719
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    first step - buy a second ECU with a tune already on it (from me :D )then have your VIN programmed on it (by Justin)
  20. Sep 26, 2022 at 1:53 PM
    #7720
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Anyone need my 2005 xrunner ecu? Make an offer.
    Torspd likes this.
