HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 12, 2019 at 8:51 AM
    #761
    HPTuners
    HPTuners Well-Known Member
    No each PCM will require a separate license
  2. Apr 12, 2019 at 8:51 AM
    #762
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You don’t need the Stock TRD cal to be on the ECU. HPT will provide you a stock TRD cal of your ECU version when you read the truck the first time. You’ll essentially start with a fresh TRD tune to develop your own tune.
  3. Apr 12, 2019 at 8:52 AM
    #763
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thank you for clarifying that
    12TRDTacoma and JustDSM like this.
  4. Apr 12, 2019 at 8:54 AM
    #764
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Can you walk me through how this works? I have a MPVI2 cable on order but also have two 2nd gen Tacoma's I would like to tune. Thanks
  5. Apr 12, 2019 at 8:56 AM
    #765
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Should not see it since TX obd inspection is generic OBD. The codes will still show in the Toyota protocol though.
    Me too!
    YES!
    I've heard (through the grapevine) that there's someone working on changing that!
  6. Apr 12, 2019 at 8:56 AM
    #766
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Awesome, thanks for the response. I just sold a condo I owned today so I'll most likely buy this once I see cash in the ol bank account.
    Sounds so worth it for everything. Looking forward to proper pedal response and emissions delete. Any idea if rev hang can be reduced? Does improved throttle response reduce rev hang at all?
  7. Apr 12, 2019 at 8:57 AM
    #767
    HPTuners
    Our license is based on the PCM itself, so even if you change PCM in the same vehicle we will consider it new and requires a license
    Biscuits, Roostfactor and Torspd like this.
  8. Apr 12, 2019 at 9:00 AM
    #768
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I use a Mac, but I have boot camp installed with Windows 10. HP Tuners works only on Windows. :(
    5thGearPinned and BassAckwards like this.
  9. Apr 12, 2019 at 9:01 AM
    #769
    BassAckwards
    Know what the requirements are for windows? Considering picking up a laptop exclusively for the truck
  10. Apr 12, 2019 at 9:02 AM
    #770
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have exactly that. There are several guys running the APR/URD gears with a stock TRD tune and have been running that for a long time. I think @TRON maybe one of them.
  11. Apr 12, 2019 at 9:02 AM
    #771
    JustDSM
    Justin
    Ogden, UT
    What if you register a N/A cal and update the truck to a TRD cal at the dealer when adding a supercharger? Will the original license remain valid or will you need to purchase 4 more credits at that point?
    Roostfactor and loginfailed like this.
  12. Apr 12, 2019 at 9:03 AM
    #772
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s on their web page somewhere, but it does not have to be a high spec machine.
    BassAckwards[QUOTED] likes this.
  13. Apr 12, 2019 at 9:07 AM
    #773
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Did t say I would sell it
  14. Apr 12, 2019 at 9:21 AM
    #774
    BassAckwards
    Ive run this as well @wrmathis no issues running cam gears with the trd tune
    loginfailed[QUOTED] likes this.
  15. Apr 12, 2019 at 9:21 AM
    #775
    HPTuners
    You will require a new license for the TRD cal
    Hacktacular[OP] likes this.
  16. Apr 12, 2019 at 9:28 AM
    #776
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can confirm that running SAI delete via block off plates and software cleans everything up incredibly. If your ultimate goal is maximum flow then deletion of the SAI system is crucial. It can be a large contributor to unnecessary pinging across the RPM spectrum.
    This is very important. Being that all the Taco's after 2007 require expensive dealer only replacements, up to this point us California guys were royally screwed. Not anymore! ;)
    It has always made sense to me. There are so many other vehicles out there that run vacuum to the fuel pressure regulator in factory configuration. I never understood why these yahoos at Toyota and TRD decided against doing so being that they had the opportunity to run and calibrate the PCM to compensate for such changes and since they ran the blueprints for getting the blower setup CARB certified.
    :thumbsup: this right here. FPR mod will no longer be necessary, but should still be run to maintain a proper safety net in place. Boost referenced fuel pressure is always a good thing with proper ECM management.
    That was always my philosophy with any overly rich setup. It worked, and it worked well. Tuning via mechanical manipulation. Since we didn't have such sophisticated tuning software like we do now. Lol.
    In HPTuners I (we) trust!
  17. Apr 12, 2019 at 10:17 AM
    #777
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    5 years strong :thumbsup:
  18. Apr 12, 2019 at 10:39 AM
    #778
    wrmathis
    Bonaire, GA
    parts and stuff
    Not interested in a TRD tune tho. My UCON has been flawless since I’ve had it. Before that I had the apr x1. My ecu has never been flashed to anything and that’s why I was wondering
    5thGearPinned likes this.
  19. Apr 12, 2019 at 10:43 AM
    #779
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Not sure if its been asked....but can it manipulate airbag/SRS?
    loginfailed likes this.
  20. Apr 12, 2019 at 10:54 AM
    #780
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    will trade o2 simulators for cam gears...:thumbsup:
    JustDSM likes this.
