HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 4, 2023 at 3:45 PM
    #7781
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    When you say "already tuned" what exactly do you mean? Are you talking about the pre-packaged tune that comes with the supercharger? Or a custom tune from someone? Just want to clarify your situation to better advise you.
    If you want to flash it back to stock (OEM TRD S/C Tune) I have folks who can help you, we have Q in SoCal.
    TK-421 Tuning
    Coverage Areas: Los Angeles, Santa Barbara, San Diego, Inland Empire
    E-Mail: tk421tuning@gmail.com
    Web: www.tk421tuning.com
    FB: IG: www.instagram.com/tk421tuning
    Keep in mind, flashing (whether custom or stock) will require a credit licensing cost due to the way our software works. Be mindful there are costs associated with these licensing credits/time.
    I can sell you a device with pre installed credits that will allow you to flash the vehicle back to stock yourself. If that's an option you'd prefer. Shoot us an email at info@overlandtailor.com for pricing. With this device we can (at a later time) send you tune files and you can remotely flash/log them.
    12TRDTacoma likes this.
  2. Jun 5, 2023 at 3:50 PM
    #7782
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Depending on how close to Midland you are it looks like Sharue High Performance is also on the list as a OTT tuner. @JustDSM are they set up and ready to tune? I'm in Abilene but make trips to Midland pretty often for work.
    dawsonTRD[QUOTED] and JustDSM like this.
  3. Jun 5, 2023 at 3:55 PM
    #7783
    JustDSM
    Justin
    Ogden, UT
    They should be fully operational this week. You're welcome to reach out and get the conversation started if you have something in mind.
    Rezkid[QUOTED] likes this.
  4. Jun 28, 2023 at 1:32 PM
    #7784
    RocketTaco808
    RocketTaco808 Resident Telescope Expert
    Maui
    08 4wd URD MKIII.1 6-Speed
    Poly bushings all around, URD Headers, Composite Carbon Stage II clutch, TRD short throw, URD Spec U Exhaust, Tow package, Bunny Trails, Fairy Dust, Triple Dynamat Insulated, Blood, sweat, grit and some good old fashion elbow grease.
    Some tofu man magic going on here
  5. Jun 28, 2023 at 1:47 PM
    #7785
    RocketTaco808
    Maui
    Ok, had some significant exhaust issues that I’ve been juggling my time on. My collector weld cracked in the worst location on my equal length headers (driver side). Since resolved. There were many leaks only detectable under pressure with soapy water before the AFR sensors at the manifolds. Since resolved with oem gaskets and elbow grease.
    junction between header and ‘yipe’ (URD mk3 exhaust) has a leak small enough to blow bubbles at a slow rate under vacuum exhaust leak test (vacuum giving tail pipe some blow).
    cant get any better without bending pipes and re-welding flanges. This is the result with permatex copper.
    it’s technically downstream of the AFR sensors. Is a leak between the headers and the y-pipe going to have a Venturi effect that could affect the upstream (by a few inches) AFR sensor readouts (and in turn fuel trims)?
  6. Jun 28, 2023 at 1:48 PM
    #7786
    RocketTaco808
    Maui
    Also, on throttle close, is a lean condition expected, even if DFCO doesn’t kick in? If so, how long are you guys leaning out for?
  7. Jun 28, 2023 at 1:49 PM
    #7787
    JustDSM
    Justin
    Ogden, UT
    How large of a leak are we talking?
    If we're talking pin-hole size, no.
    RocketTaco808[QUOTED] likes this.
  8. Jun 28, 2023 at 1:50 PM
    #7788
    JustDSM
    Justin
    Ogden, UT
    More details? If you've got a significant the delta between on/off throttle, you will get DFCO.
    I should also mention/remind folks that these ECU's aren't the most well equipped hardware/software wise for characterization and control of injectors 2x the size of the OE injectors.
  9. Jun 28, 2023 at 1:53 PM
    #7789
    RocketTaco808
    Maui
    Definitely pin hole sized. Enough to slowwwwly inflate bubbles (from one spot on perimeter of flange interface) with a shop vac taped up to tail pipe.
    JustDSM[QUOTED] likes this.
  10. Jun 28, 2023 at 1:55 PM
    #7790
    RocketTaco808
    Maui
    been trying to learn from the TRD tune direct and NOT waste your time (until I found some proof that I was actually ‘ready’ and things were problem free). Will get you a screenshot showing what I got going on.
  11. Jun 28, 2023 at 1:55 PM
    #7791
    JustDSM
    Justin
    Ogden, UT
    You're not going to adversely (in a meaningful way) affect the measured AFR in the collector to the point you'd experience trims drifting with a leak that size at that location.
  12. Jun 28, 2023 at 1:56 PM
    #7792
    JustDSM
    Justin
    Ogden, UT
    Appreciate you doing your due diligence!! Good on ya!
    We can carry on via email if you'd like. I'll be curious to see what you have going on.
  13. Jun 28, 2023 at 2:00 PM
    #7793
    RocketTaco808
    Maui
    Sounds good.
    I’m sure you’ll have a good laugh at my attempts to tune to the exact injector specs (yes I pulled to ensure each s/n was cylinder matched and further put the calc deltas in for offsets and more).
  14. Jun 28, 2023 at 2:25 PM
    #7794
    RocketTaco808
    Maui
    Had everything setup, realized I didn't take screenshots of timestamps. Corrected and pm'd will continue on there.
  15. Aug 5, 2023 at 9:25 PM
    #7795
    cjm11083
    cjm11083 Well-Known Member
    Anyone out there willing to take a look at and give me some feedback on my latest program/data log. I am pretty happy with the way the truck runs, wondering if my long term fuel trims need to be addressed. Any and all tips and feed back would be appreciated
  16. Aug 12, 2023 at 7:15 AM
    #7796
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Hey Justin @JustDSM, just sent you an email with some questions about going from NA to supercharged on my FJ.
  17. Nov 14, 2023 at 9:48 AM
    #7797
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    It's been a minute since I've been here.
    What's the latest method to flashing these days? Are you using Beta Suite or the tried and tested?
    Thanks!
  18. Nov 14, 2023 at 9:51 AM
    #7798
    JustDSM
    Justin
    Ogden, UT
    The latest full release has everything needed for Toyota. Nothing in the Beta is Toyota centric at this time.
  19. Nov 14, 2023 at 9:55 AM
    #7799
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks @JustDSM !
    Not sure if you got my email last week, but I can re-send it if not. Basically has some questions on the A/T Temp light, idle speed and fueling of my recent manual swapped Tacoma. Please let me know if I should re-send it. Thanks!!
    JustDSM likes this.
  20. Nov 14, 2023 at 10:57 AM
    #7800
    JustDSM
    Justin
    Ogden, UT
    Yes please do. If I did get it, it got buried and I missed it.
