HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 12, 2019 at 11:00 AM
    #781
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Engine and transmission only
    SUMOTNK[QUOTED] and JustDSM like this.
  2. Apr 12, 2019 at 11:04 AM
    #782
    ThomasMore66
    Dallas/Fort Worth & Durango
    I would like to just buy the gears.
    JustDSM likes this.
  3. Apr 12, 2019 at 11:19 AM
    #783
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Are you looking to tune the Stock ECU you're running with your UCon? sorry kinda confused here
    But i too am running a UCon with a stock ECU and plan to do the same with the HP tuner
    JustDSM likes this.
  4. Apr 12, 2019 at 12:14 PM
    #784
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Just thinking about not running the UCON and just the engine with UCON gears, with supercharger on a stock unmolested ecu with a 6spd.
    Just trying to see what options available
    BassAckwards[QUOTED] likes this.
  5. Apr 12, 2019 at 12:20 PM
    #785
    BassAckwards
    Interesting, as others have mentioned, i'd think you'd want the TRD tune on there just for a good baseline tune so that you can refine it some. Using a stock ECU is going to require a lot more custom tuning to get it dialed in. TRD tune would be 90% there from the start, just tweak what you want
    Norton, 12TRDTacoma and JustDSM like this.
  6. Apr 12, 2019 at 12:22 PM
    #786
    wrmathis
    Bonaire, GA
    parts and stuff
    Yeah that’s what I figured. Like I said. Haven’t had any issues with the UCON at all. Was just wondering out loud mostly
  7. Apr 12, 2019 at 12:28 PM
    #787
    BassAckwards
    So im not sure if this has been discussed, but can you disable the speed limiter with this for track use?
  8. Apr 12, 2019 at 12:28 PM
    #788
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yep, 317mph is the max limit.
  9. Apr 12, 2019 at 12:35 PM
    #789
    BassAckwards
    That should suffice.. for now.. :D
    That's one thing i didnt like about running TRD tune. Will be great for auto guys. now they'll be able to redline in 4th on the dyno
  10. Apr 12, 2019 at 2:21 PM
    #790
    Lthompson
    Lthompson Well-Known Member
    I wanna see what someone can do with a stock n/a vehicle
  11. Apr 12, 2019 at 2:29 PM
    #791
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The stock ecu tune will definitely not work on a TRD SC cause of the size of primary injectors
    BassAckwards, Torspd and 12TRDTacoma like this.
  12. Apr 12, 2019 at 2:36 PM
    #792
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I’m going to get in on the action too. Ordered the MPVI2. Can’t wait to start tinkering. Now, I wish that I wouldn’t have bought a UCON a couple of years ago. Oh well.
  13. Apr 12, 2019 at 2:37 PM
    #793
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    A very talented individual that I know is working on that currently!
  14. Apr 12, 2019 at 2:37 PM
    #794
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Just when I was beginning to like you man! Now I have to second guess it....hahaha.
    not_nick, Roostfactor, Torspd and 4 others like this.
  15. Apr 12, 2019 at 2:38 PM
    #795
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm a mac guy, too! :brianr:
  16. Apr 12, 2019 at 2:54 PM
    #796
    Hacktacular
    Robert
    Yes, but you're my dog and you let me burry my bone in your back yard....:luvya:The irony of you needing a pc to tune your vehicle.... Mac that.. . :rofl:
  17. Apr 12, 2019 at 3:33 PM
    #797
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    :rofl:
    BassAckwards likes this.
  18. Apr 12, 2019 at 4:02 PM
    #798
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This Mac runs windows too! :headbang:
  19. Apr 12, 2019 at 5:26 PM
    #799
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Any computer nerd on here. Any recommendations for a cheap as hell laptop?
    garciav, BassAckwards and loginfailed like this.
  20. Apr 12, 2019 at 5:59 PM
    #800
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    E6410 is solid. I bought one from this seller 3 years ago and have been using it for work with the factory VW scan tool head and it’s still ticking. I did have to replace the battery but they’re cheap on Amazon.
    https://www.ebay.com/ulk/itm/223461879738
    Biscuits, BassAckwards and JustDSM like this.
