HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 13, 2019 at 7:48 AM
    #821
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    No sir, is this about those fancy coils? :D
    BassAckwards and 12TRDTacoma like this.
  2. Apr 13, 2019 at 7:59 AM
    #822
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I actually wonder if they have it in place to further grandma-sise the truck. Seeing as all the bushings they put in place are sloppy soft rubber. And the tranny settings for autos make it shift super soft.
    TodayWasTHeDaY likes this.
  3. Apr 13, 2019 at 8:03 AM
    #823
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Be good to have a true value, and thus understanding of their full HP potential. Before getting into those fancy ones.
  4. Apr 13, 2019 at 8:10 AM
    #824
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Awesome! Cant wait to get mine out of there
    Would've probably been easier to just swap out those headers for the pre 12-15 version though... :D
    loginfailed and JustDSM like this.
  5. Apr 13, 2019 at 8:11 AM
    #825
    BassAckwards
    The gift that keeps on giving
  6. Apr 13, 2019 at 8:14 AM
    #826
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    So is this going to eventually have pre-made tunes, or just a much more tuner friendly software?
    loginfailed likes this.
  7. Apr 13, 2019 at 8:27 AM
    #827
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Sounds like enough personal tunes will be done eventually that a person will be able to get a tune for a truck that has the same or similar setup. And the ability to personally setup your own if capable.
  8. Apr 13, 2019 at 8:50 AM
    #828
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Exactly. If someone has a similar setup to you, you’ll be able to open their tune as a compare file and copy/paste their tables into your tune.
  9. Apr 13, 2019 at 10:07 AM
    #829
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    And/or you can get a tune that's close, then take to a tuner for fine tuning. Much faster than if they are starting from scratch.
    I have a strong feeling that someone is already compiling tunes for all configurations available. It's quite possible in the near future to pay ?$ for a tune already dialed for your truck.
  10. Apr 13, 2019 at 10:11 AM
    #830
    Roostfactor
    TX panhandle
    Definitely not easier! The block offs are easy!
    If I ever remove the headers for any reason I may cut off the extra sai tube and weld it closed but that's not viable for many.
  11. Apr 13, 2019 at 10:11 AM
    #831
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    This is awesome. This is the route I’ll go because I don’t know crap out this. It’ll be a learning process for sure. Thanks to all the awesome people on here. And thanks to HPTuners also.
  12. Apr 13, 2019 at 10:31 AM
    #832
    BassAckwards
    Lol bad joke, i was just having flash backs to when we installed mine and it took a solid 8hrs
  13. Apr 13, 2019 at 11:13 AM
    #833
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yes!
    loginfailed[QUOTED] likes this.
  14. Apr 13, 2019 at 11:36 AM
    #834
    ThomasMore66
    So, to be clear, I have to buy credits to write anything to the computer...4 credits.
    Hacktacular[OP] and loginfailed like this.
  15. Apr 13, 2019 at 11:38 AM
    #835
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Correct.
  16. Apr 13, 2019 at 11:53 AM
    #836
    ThomasMore66
    Are the credits tied to the device or the computer? If I wanted to use a different computer or a buddy’s computer to make a change? Once I have credits is there a limit to how many changes I can make?
    loginfailed and JustDSM[QUOTED] like this.
  17. Apr 13, 2019 at 11:56 AM
    #837
    JustDSM
    Justin
    Ogden, UT
    Great question!
    They’re tied to the MPVI2, allowing you to use any PC.
    You can make unlimited changes at anytime with the credits used to originally license that ECU.
    Biscuits, Norton and loginfailed like this.
  18. Apr 13, 2019 at 12:09 PM
    #838
    Roostfactor
    TX panhandle
    To everyone that PM'ed me for block offs, they shipped today. If I didn't get a PM, I didn't ship.
    Please provide full name and address when you PM me so I don't have to dig for your address.
    Yes there are plenty more available!
    Roost
  19. Apr 14, 2019 at 9:26 AM
    #839
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Apr 14, 2019 at 9:35 AM
    #840
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Finally got the VCM suite setup and going to purchase credits. I have not scanned the truck yet but not yet sure exactly how to start just reading. I was going to plug in the scanner and then try Bluetooth connection to laptop.
    Been doing a lot of reading in the advanced tuning book. Very helpful and explains a lot.
