HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 14, 2019 at 2:27 PM
    #861
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Looks like the tune is a little rich. Needs moar boost.
    BassAckwards likes this.
  2. Apr 14, 2019 at 2:42 PM
    #862
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    he is just playing buddy. This thread, the supercharger tips and tricks, and the Roostfactor y-pipe thread don't have anyone giving anyone serious heartache. There is plenty of sarcastic ribbing though so a little thick skin and friendly payback is welcomed!
  3. Apr 14, 2019 at 2:44 PM
    #863
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Ugh the HAI though
  4. Apr 14, 2019 at 3:02 PM
    #864
    Roostfactor
    TX panhandle
    I agree with the reliability part but not the rest of it.
    First off I can now finally say from experience that the original TRD tune was far from perfect, even for a stock truck! Yes Toyota richened the crap out of the tune for exactly the reason you stated "reliability at the cost of performance" but, it was by no means perfect. Not even close! @JustDSM could elaborate more on this because he is "NEO" but basically Toyota went way too far to save the reliability so by returning the engine parameters closer to optimal will increase power, economy, and most likely engine life because cylinder lubrication isn't being washed with excess fuel.
    Besides that, there is the variable cam timing which has (in testing infancy) shown serious promise for our future!
    TLDR: The engine can make more power, be just as reliable if not more, and be more efficient (better fuel economy) all at the same time! That is what you pay for when you want an extremely refined tune! one that maximizes EVERY available parameter. This is extremely time consuming and requires serious understanding of how to interpret and manipulate data as well as extreme understanding of engine fundamental operation.
    Biscuits, elnip, Torspd and 4 others like this.
  5. Apr 14, 2019 at 3:08 PM
    #865
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    There's much more going on in this pic than you know about, but I'll let @Roostfactor speak about it.
    BassAckwards and Roostfactor like this.
  6. Apr 14, 2019 at 3:09 PM
    #866
    Roostfactor
    TX panhandle
    Agreed. This is a temp setup to test and calibrate this intake so we don't have to recalibrate for it later.
    If you are new here you haven't seen what my plan with this intake is.
    I am going to relocate my battery to the passenger side, cut off the supercharger intake at the 180 degree elbow, move the throttle body (it will be near the brake booster), route new intake where filter is behind front headlight, and build enclosure for new intake location for cold air supply.
    My theory is for those of us really pushing the sc, that we are starving the sc of air at higher air loads so I am going to remove that restriction.
  7. Apr 14, 2019 at 3:10 PM
    #867
    Roostfactor
    TX panhandle
    HAHA, just did. You are awesome D!!!
  8. Apr 14, 2019 at 3:19 PM
    #868
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I've had a design I've been meaning to try at some point...Take the URD intake, cut the elbow turning towards the front of the truck to make it a Y, add a snorkel to it, put an inline filter under the fender maybe, that way cold air from in front of truck and ram air would both come in. Add an exhaust type cutout to the front section for any sort of water crossings/high dust areas. Had a bunch of aluminum parts saved for a while to try it, but never got around to it.
  9. Apr 14, 2019 at 3:35 PM
    #869
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    How could I forget the OP, @Hacktacular!!
  10. Apr 14, 2019 at 4:06 PM
    #870
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    That is one bad Tacoma!
  11. Apr 14, 2019 at 4:11 PM
    #871
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Precisely my thought to that question.
  12. Apr 14, 2019 at 4:13 PM
    #872
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :evil:
    loginfailed likes this.
  13. Apr 14, 2019 at 4:13 PM
    #873
    Hacktacular
    Robert
    I don't see any hard evidence that any of this is true. In this case, pictures or dyno numbers, or it did not happen!
    Roostfactor and Torspd[QUOTED] like this.
  14. Apr 14, 2019 at 4:16 PM
    #874
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    10-20 HP gain to be had by cam phase improvements.
  15. Apr 14, 2019 at 4:17 PM
    #875
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    True story. So new, the data truly isn't there. The speculation, is discussed in detail. The devil is in the details. As they say....
  16. Apr 14, 2019 at 4:20 PM
    #876
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I’m going to see if I can get it on the dyno this week.
    I’m curious what numbers would impress on a nearly stock truck with tuning? Legit question. Give me a figure, I’m curious to see if it’s got it in it.
  17. Apr 14, 2019 at 4:22 PM
    #877
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Stock unmolested, around ~195 whp and ~236 wtq.
    Biscuits, loginfailed and JustDSM like this.
  18. Apr 14, 2019 at 4:25 PM
    #878
    JustDSM
    Justin
    Ogden, UT
    If I can find a dyno in south DFW I’ll take time off work and get it done. This community has asked and I’d like to deliver.
    Know of any place in south DFW? I’m relatively new to the area..
    Biscuits, 05Taco4x4 and loginfailed like this.
  19. Apr 14, 2019 at 4:27 PM
    #879
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  20. Apr 14, 2019 at 4:28 PM
    #880
    JustDSM
    Justin
    Ogden, UT
    @ThomasMore66 let me know! I’ll do it tomorrow if they can get me in! :D
