HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 14, 2019 at 6:12 PM
    #901
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  2. Apr 14, 2019 at 6:12 PM
    #902
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    It is really is true. All the secondary air stuff can be deleted as well. That is, of course, if you only ride off-road.
    I just remapped throttle response today, deleted a bunch of other items in the computer and the truck feels great. Very linear response where the pedal was once flat, you can see what the computer is seeing and change it to something different across just about any aspect.
    It won’t save you from yourself though, so you can lurk and learn from others or just wait and maybe chip in for one of these really smart guys to hook you up remotely.
  3. Apr 14, 2019 at 6:14 PM
    #903
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Are you N/A or SC?
  4. Apr 14, 2019 at 6:21 PM
    #904
    zippsub9
    Halfmoon, NY
    14 DCLB
    SC
    Someday I will get off my butt and put together a build page
    Biscuits, rmepilot and BassAckwards like this.
  5. Apr 14, 2019 at 6:29 PM
    #905
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Funded plenty of those in the past. Some people still argue the results, or don't have the thought to look for them. Always easiest to ride coat tails and complain. Sadly.
  6. Apr 14, 2019 at 6:30 PM
    #906
    ThomasMore66
    Dallas/Fort Worth & Durango
    I don’t need a bigger fuel pump? Or two?
  7. Apr 14, 2019 at 7:14 PM
    #907
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome work, fellas. My MPVI2 cable showed up yesterday evening. My wife needed the laptop all day and I had to put a new steering rack and front end parts on my buddy's 1st gen today so didn't get to do anything other than download the software. Looking forward to that tomorrow!! Happy to help fund a dyno day, especially if @JustDSM is willing to help me flash his NA tune.
  8. Apr 14, 2019 at 7:17 PM
    #908
    Lthompson
    Lthompson Well-Known Member
    I reckon I could go ahead and get the software, and do a stock tune from someone else, until I do upgrades....
  9. Apr 14, 2019 at 7:31 PM
    #909
    JustDSM
    Justin
    Ogden, UT
    Send me a PM with your mods and MPVI serial #. I’ll get you taken care of!
  10. Apr 14, 2019 at 10:01 PM
    #910
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Uhhh, yours ain't too shabby either.
  11. Apr 14, 2019 at 10:11 PM
    #911
    Roostfactor
    TX panhandle
    Another big wallet drain.
  12. Apr 14, 2019 at 10:20 PM
    #912
    Roostfactor
    TX panhandle
    Somebody was hooked up with a @JustDSM throttle map. Wait till you see what's coming!
  13. Apr 15, 2019 at 3:32 AM
    #913
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    :stirthepot:
    Roostfactor and Torspd[QUOTED] like this.
  14. Apr 15, 2019 at 5:04 AM
    #914
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Ok well tuner should be here today. Damn ups. Wife is home today to sign for it. And laptop will be here tomorrow. Just gotta get the truck put back together now...
  15. Apr 15, 2019 at 5:33 AM
    #915
    Hacktacular
    Robert
    Put back together?
    12TRDTacoma likes this.
  16. Apr 15, 2019 at 5:35 AM
    #916
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My truck is running much better than it was with the UCON or the plain TRD tune. Feeles much more responsive and powerful. Who is paying for the dyno to prove it?
  17. Apr 15, 2019 at 5:40 AM
    #917
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    got my throttle body off porting the opening of supercharger and still trying to install the rest of the meth kit and ice box
  18. Apr 15, 2019 at 5:54 AM
    #918
    Lthompson
    We can’t tell without a before and after.. jk.. but not really
  19. Apr 15, 2019 at 6:01 AM
    #919
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    KP Racing? PowerFab Automotive?
  20. Apr 15, 2019 at 6:07 AM
    #920
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Wouldnt be hard to make a comparison really.
    Dyno current tune
    Load TRD tune and dyno that
    Install stock ECU / UCON combo and dyno that
    So who wants proof bad enough to pay for it?
