HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 15, 2019 at 6:13 AM
    #921
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Nice!
  2. Apr 15, 2019 at 8:04 AM
    #922
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'll guess a 20 hp 20 tq increase but what I try to (with difficulty) explain to people is that max hp/tq numbers are fine and all but what happened to the middle of the rpm range at part throttle?
    You may gain 20 hp 20 torque with better fuel efficiency at 1/2 throttle and 2500 rpm. The dyno wont show this but you will most definitely feel it.
  3. Apr 15, 2019 at 8:08 AM
    #923
    Roostfactor
    TX panhandle
    I have the 255 and I'm still good. I think most of us are running it.
    If I were to do it again I'd get the 320 though.
    12TRDTacoma and BassAckwards like this.
  4. Apr 15, 2019 at 8:09 AM
    #924
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s fun to bench race with max MAF calculations. But who drives around at 5700 RPM the whole time? To me that’s not even fun.
  5. Apr 15, 2019 at 8:13 AM
    #925
    Roostfactor
    TX panhandle
    Curious if this statement will change once you get a good tune installed?
    12TRDTacoma and JustDSM like this.
  6. Apr 15, 2019 at 8:20 AM
    #926
    Roostfactor
    TX panhandle
    The man with all of the parts/tunes is answering the challenge. I know I dont need a dyno to tell me how my truck is running and I dont think @loginfailed needs one either.
    For those that want to know that bad, put up some funding! All the work with ecu changes and the vehicle is being offered.
    Now it's up to you to fund what you want see.
  7. Apr 15, 2019 at 8:23 AM
    #927
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Exactly. When I was ov tuned it only showed a 20 peak gain, but it felt a lot better through the whole rpm range.
  8. Apr 15, 2019 at 8:24 AM
    #928
    Roostfactor
    TX panhandle
    Unless at a track.
    loginfailed[QUOTED] likes this.
  9. Apr 15, 2019 at 8:28 AM
    #929
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    True.
    Amount of times a @loginfailed vehicle has been at the track = 0. :D
    TodayWasTHeDaY likes this.
  10. Apr 15, 2019 at 8:32 AM
    #930
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    THIS^.
    Numbers are fun goals to chase and great for shit talking. However, at the end of the day the OEM is trying to please the masses (i.e. all the weirdos who don’t Tacomaworld plus the cool people on Tacomaworld) therefore it isn’t really adjusting efficiency as much as it is just providing the end user better ergonomic connection with the machine through ECM manipulation. DYNO is just a machine that can’t articulate the human integration/feel. All those on the sideline will never know and can’t complain until they try it.
  11. Apr 15, 2019 at 8:35 AM
    #931
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I do at 6200rpm
  12. Apr 15, 2019 at 8:37 AM
    #932
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You are the exception to the rule.
  13. Apr 15, 2019 at 8:56 AM
    #933
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I got my tuner the day before I left on vacation so I'm sitting here in Mexico itching to check this thing out when I get back. Local tuner wants to dyno tune it by the end of the month
  14. Apr 15, 2019 at 9:25 AM
    #934
    Lthompson
    Lthompson Well-Known Member
    Area under the curve is what I look for. Torque in the middle
    Roostfactor likes this.
  15. Apr 15, 2019 at 9:32 AM
    #935
    Lthompson
    I think some of us kinda assume you who are more involved in tuning have easy access to a dyno, or your own shop. I know I did
    Biscuits and 12TRDTacoma like this.
  16. Apr 15, 2019 at 9:37 AM
    #936
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Start the Dyno at 2k. With a manual. Hard to do with the auto.
  17. Apr 15, 2019 at 9:41 AM
    #937
    Lthompson
    Another reason to street tune. My other truck was dyno tuned but I had to find someone else to fine tune how it drove.
    Roostfactor[QUOTED] likes this.
  18. Apr 15, 2019 at 9:43 AM
    #938
    Lucario Runner
    Robert
    06 Toyota 4Runner
    3 grand with auto in 4 with no speed limiter. 3rd w/speed limiter.
  19. Apr 15, 2019 at 9:54 AM
    #939
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I just spent a significant amount of time learning from others who knew more than I did. No shop.. I'm former USAF Military Police (SF)/Sniper turned Biologist. Started "tuning" when I was in the USAF in 2000 with a '93 Eagle Talon TSi AWD. First "mod" was a datalogger. I logged and logged and my analytic nature got me accustomed to making sense of lines/numbers and their relationships. A few years later I was introduced to a 2003 Subaru WRX as my first new car purchase and the first modification to that was a TurboXS UTEC which I helped TurobXS beta test firmware for future releases. The WRX was quickly replaced by my 2003 Mitsubishi EVO VIII. I fitted a GT3076R turbo to it, and adapted a 2G DSM ECU with DSMLink tuning software to run the car as the only tuning solutions were a Apexi SAFC or similar and full standalone ECUs. Using the DSM ECU in the EVO I was able to run a 11.9@119mph at Bandimere Speedway at over a mile ASL. The stock coils couldn't handle the cylinder pressures I was running so the car cut out on the top end. I'd guess with a better set of coils the car would have run low 11's even with my crappy driving. I took a little break from the tuning scene running around with a 2001 Subaru GC 2.5RS coupe, but when it was stolen I found myself back in the EVO game. Picked up a new 2006 EVO IX and went to work making a streetable sleeper. By this time the stock ECU's had been cracked, and opensource software to relash them had become widespread. I had a pretty good number of folks in the Denver area running my tunes and my own personal EVO made 430whp/430wtq on E85 with a stock framed turbo. Came back from Iraq in 2008 and sold the car/gave up the scene to focus on other areas and interests in life.
    Now this software comes out, and it's ignited a old flame you might say.. No shop/dyno of my own, but a bit of history making things "better". Now you all know a little about where I come from :)
  20. Apr 15, 2019 at 10:25 AM
    #940
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Makes for seamless freeway merging. :D Keep the flow moving. :cheers:
