HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 31, 2019 at 8:52 AM
    #81
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Exactly. While this software is still very much in it's infancy, it comes out of the box in working order. I'm positive this will be *THE* solution for tuning your truck in the times to come. Even for those who are not interested in learning to tune their own truck, you can simply buy the credits/tune from someone who is, and you don't have to buy the expensive hardware or worry about how to interpret the values/tables.
  2. Mar 31, 2019 at 8:58 AM
    #82
    JustDSM
    Justin
    Ogden, UT
    Anyone have connections with the moderation/admin staff? I'd like to propose the idea of adding the ability to upload the .hpt and .hpl file extensions so we can share datalogs and calibrations.
  3. Mar 31, 2019 at 9:04 AM
    #83
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Another factor for tuning to remember with the TRD calibration is the maf table limit of 322 g/s that will need to be overcome with some modification. My plan is the larger maf tube.
    Unless this hptuners software can do map speed density tuning instead of using the maf?
  4. Mar 31, 2019 at 9:07 AM
    #84
    JustDSM
    Justin
    Ogden, UT
    I really need to get my hands on a TRD calibration..
    The larger MAF Tube would certainly work. Recalibration of the MAF table will allow you to dial that in no problem. Currently, there isn't a supported speed density conversion for our trucks *yet*. As we all know, it's commonplace on the GM based applications. I suspect with enough requests, we could get HPTuners to address it.
    Hacktacular[OP] and loginfailed like this.
  5. Mar 31, 2019 at 9:53 AM
    #85
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Isnt it a limitation on the ecu like the lack of E85 support?
    @JustDSM....so a person can get their ecu flashed with another person's MPVI2 if they buy the 4 credits for $200? The credits I guess buy access to 1 ecu and the MPVI2 is the hardware to read/write to it.
  6. Mar 31, 2019 at 9:58 AM
    #86
    Roostfactor
    TX panhandle
  7. Mar 31, 2019 at 10:08 AM
    #87
    JustDSM
    Justin
    Ogden, UT
    I'm not quite following you on the limitation on the stock ECU regarding E85. Currently, flex-fuel isn't supported for our applications as we don't have an ethanol content analyzer. So our ECU isn't capable of detecting and therefor compensating for various amounts of alcohol content. However, we can convert over to E85 use through developing a tune specific for a given content of ethanol. Essentially you'd tune for whatever concentration is at your given pump. If that concentration drastically changes or you go to an area where it's not available, you can simply reflash a gasoline based tune for your setup. It was a common practice for my prior customers to have me tune their vehicle on 91 and E85 seperately. So they could simply swap tunes for the fuel they were running.
    I'd like to make it clear, those wishing to go to E85 could do so.
    The second part of your post.. Yes, I could tune your truck with my MPVI2. I just need credits. I'm happy to do that for anyone wishing for a more plug-n-play solution and not interested in tuning their own truck. Quite a bargan considering a simple fuel controller that modifies the MAF signal is in that price range and you can do much, much more for relatively the same entry fee.
  8. Mar 31, 2019 at 10:31 AM
    #88
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  9. Mar 31, 2019 at 12:28 PM
    #89
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Yeah I did both but it still not working. I have a feeling it’s due to it being a 2015 xrunner. I opened a ticket with hptuners I’m sure we’ll get it figured out.
    UltraBoost likes this.
  10. Mar 31, 2019 at 12:52 PM
    #90
    Roostfactor
    TX panhandle
    Sorry for the confusion. I didnt mean you couldn't tune for E85, I meant about the flex fuel part.
    I meant that even if we got the flex fuel analyzer from a Tundra or something, I dont know if it would work with our ecu if our ecu doesnt have the capability?
    That's awesome about the tunes! Then people may be able to get their tune tweaked (for a small fee) to match their mod progression!
    BassAckwards and TodayWasTHeDaY like this.
  11. Mar 31, 2019 at 1:00 PM
    #91
    Roostfactor
    TX panhandle
    This would also be amazing for those with Methanol injection as fuel/timing can be manipulated to optimize the tune for the meth.
  12. Mar 31, 2019 at 1:35 PM
    #92
    JustDSM
    Justin
    Ogden, UT
    Well keep us posted! I'm surprised as I have a '15 6spd TRD OR. I would have figured they had the '15's covered.. Hmm.
    No worries! I wanted to make sure I understood your reference. I see now what you were after.
    Our ECU has a fixed number of inputs which are all used by existing sensors/switches. So there's the first problem, we need a for the ECU to see the ethanol content. From here there are a few ways around the problem, none of which are currently doable or supported, but with enough support it's entirely possible that these options could be implemented with the HPTuners.
    One such way to get our trucks flex-fuel capable would be through the utilization of existing inputs on the ECU which are re-purposed from *deleted* SMOG equipment in your *strictly off-road truck*. Say.. Secondary Air Injection pump and associated hardware gets deleted in your off-road truck. You could potentially re-purpose an input from that 5v circuit and feed it a 5v signal from an ethanol content analyzer. Having the 5v signal from the ethanol content sensor in the ECU would allow someone with the coding ability to do some magic in the code of the calibration to modify the fuel/ignition/etc tables to compensate for the measured ethanol concentration.
    So as things stand it's currently "not possible", but it's not impossible..
    Highpockets57, TAC1, Torspd and 2 others like this.
  13. Mar 31, 2019 at 1:53 PM
    #93
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I'm just excited to turn off the SAI in my *strictly off-road truck*
  14. Mar 31, 2019 at 2:43 PM
    #94
    Roostfactor
    TX panhandle
    Me too! My truck is either up on ramps or strictly off road. :D
    TAC1, rmepilot, 05Taco4x4 and 4 others like this.
  15. Mar 31, 2019 at 2:46 PM
    #95
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Wait a second.. can this be used to disable the secondary air injection??
    Ginger-Vitis, tsb, TAC1 and 1 other person like this.
  16. Mar 31, 2019 at 2:54 PM
    #96
    JustDSM
    Justin
    Ogden, UT
    Yes, for *strictly off-road* use.
    eljedi68, GeneralTans20, TAC1 and 8 others like this.
  17. Mar 31, 2019 at 3:05 PM
    #97
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    New product/mod idea. SAI block off plates.
  18. Mar 31, 2019 at 3:06 PM
    #98
    BassAckwards
    Well now.. i just got much more interested in this
    TAC1, Biscuits and Roostfactor like this.
  19. Mar 31, 2019 at 3:07 PM
    #99
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Expanding on this. Maybe I need pre-SAI headers and a pre-SAI passenger side valve cover...
    TAC1, D2., trekker and 5 others like this.
  20. Mar 31, 2019 at 3:09 PM
    #100
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Or instead of pre-SAI headers, a @Torspd fab turbo kit.
