HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 16, 2019 at 8:57 AM
    #1041
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Glad you're happy with the little bit of work we've done so far. Your setup was unique for me, in that I've not done a small pulley with stock manifolds yet. I'll be standing by for the latest log.
  2. Apr 16, 2019 at 9:41 AM
    #1042
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    That was a day, only the hardcore need apply... @BassAckwards , @loginfailed @Roostfactor :thumbsup:
    Back on topic, this needs dual VVT-I support....
  3. Apr 16, 2019 at 10:09 AM
    #1043
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    Yes my 4runner Pro needs some love
    BassAckwards and elnip[QUOTED] like this.
  4. Apr 16, 2019 at 10:12 AM
    #1044
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    That makes two of us! I'm impressed by the reports, to date, as I eagerly spectate with my 2.7" pulley, stock manifolds, and 6MT...
  5. Apr 16, 2019 at 10:55 AM
    #1045
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Any chance of traction control being disabled by default when truck is started? Or a simple on/off switch being used. Hate long pressing the button to disable it.
  6. Apr 16, 2019 at 11:25 AM
    #1046
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    No ABS support yet that I know of. Only engine and transmission. (so far)
  7. Apr 16, 2019 at 2:08 PM
    #1047
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I totally understand. I can't see why they wouldn't credit you your money back.
  8. Apr 16, 2019 at 2:10 PM
    #1048
    ThomasMore66
    Dallas/Fort Worth & Durango
    61 lb injectors and harness purchased! I'm tired of being behind on this forum. So much stuff happening.
  9. Apr 16, 2019 at 2:12 PM
    #1049
    ThomasMore66
    You still running the fpr mod?
    12TRDTacoma[QUOTED] likes this.
  10. Apr 16, 2019 at 2:16 PM
    #1050
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are a saint @JustDSM ... let it be known that I love this man!
    He cleaned my tune up so much over OE that I can now run my 2.3 with zero pinging throughout the RPM range and I notice a much harder and consistent pull throughout the band range. Easily 20-30 HP as stated. Pedal response is so crisp and feels like an old school throttle cable style.
    There isn't enough I can translate to into words so I will post a video either later today or tomorrow in regards to the improvements. This is EXACTLY what the boosted Toyota crowd needed! Thank you thank you thank you!
    To take all this a step further I will begin investigation into GM's lean cruise feature in their PCM's which allow a leaner burn on highway cruising which allows better fuel economy. If it is worth investing time and energy into I will update and let you guys know.
    Yes I am.
  11. Apr 16, 2019 at 2:19 PM
    #1051
    ThomasMore66
    Do you get the error code for MAF high-flow over 322 g/s?
  12. Apr 16, 2019 at 2:29 PM
    #1052
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Jump to the forefront! Be warned. It's lonely out there for a while.
  13. Apr 16, 2019 at 2:31 PM
    #1053
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That all on Cali gas.
  14. Apr 16, 2019 at 2:32 PM
    #1054
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I used to, yeah. I haven't for a while now. Then again I have not been gunning my truck much recently up until now.
    I run out of real estate too quick now on the roads.
    Timing to properly calibrated fuel delivery is everything. He only further solidified those thoughts after this V2 fine tuning of this tune I am currently running.
    Roostfactor and JustDSM like this.
  15. Apr 16, 2019 at 2:49 PM
    #1055
    JustDSM
    Justin
    Ogden, UT
    I sincerely appreciate the honest (yet glowing) review!
    I’d have liked to have nailed it on the first go around but I’ll take what we have achieved.
    I appreciate you giving me the opportunity!
  16. Apr 16, 2019 at 2:56 PM
    #1056
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  17. Apr 16, 2019 at 3:00 PM
    #1057
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Aww yeah!
    BassAckwards likes this.
  18. Apr 16, 2019 at 3:09 PM
    #1058
    JustDSM
    Justin
    Ogden, UT
    Since we’re all posting unboxing pics.. Huge shout-out to @Roostfactor for the kick ass plates. From concept to delivered in <week! Stellar!
  19. Apr 16, 2019 at 3:12 PM
    #1059
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is how the rabbit hole begins.
    Hahaha. You will be highly pleased with the SAI delete as a whole.
  20. Apr 16, 2019 at 4:55 PM
    #1060
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Still don't have mine because USPS lost them. USPS sucks.
    ebuyaer2002 likes this.
