HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 16, 2019 at 4:57 PM
    #1061
    ThomasMore66
    Dallas/Fort Worth & Durango
    FOMO!
    Torspd and loginfailed[QUOTED] like this.
  2. Apr 16, 2019 at 5:00 PM
    #1062
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The SAI valves are blocking things just fine. No fear! But I would like to track down the package because my Mongoose cable is also in there!
  3. Apr 16, 2019 at 5:11 PM
    #1063
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Ugh! That’s not cool!
  4. Apr 16, 2019 at 5:12 PM
    #1064
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
  5. Apr 16, 2019 at 5:32 PM
    #1065
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Noooooooo!
  6. Apr 16, 2019 at 6:14 PM
    #1066
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Oh damn!
  7. Apr 16, 2019 at 9:18 PM
    #1067
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    A quick one for the NA guys:
    As you guys know, @JustDSM said he would let me flash his NA tune. After a bit of a learning curve getting things squared away (haha!), I was able to write his NA tune to my almost entirely unmodded 1GR-FE. I'll do a more in depth review once I've logged more miles, but here are my initial impressions:
    -much more responsive throttle, especially off-idle from a stop. Not jerky, but truck seems alive, not asleep at the wheel.
    -4k-5k RPM at WOT felt pretty flat here at elevation in stock trim. With JustDSM's tune, it actually pulls those RPM's now.
    -tranny seems to hold 4th and 5th gear much better without immediately downshifting (something that drove me nuts on this, my first ever auto trans)
    -SAI is MIA!
    -Overall, to put it in my words, the truck feels like someone unloaded a few hundred pounds of bricks from the bed. It's a very noticeable difference.
    I'll keep you all posted with a more long-term eval, but I'm starting to feel like this is turning into the truck I originally wanted it to be, making it easier to let go of my tire smoking 1st gen.
    And I wouldn't have any of that if it weren't for JustDSM going above and beyond helping me get started. His efforts here are nothing short of heroic. I can't thank him enough for everything he's contributed to this forum and for all of the very personalized help he's given me, a guy he's only "met" on this thread a few days ago. Thank you buddy! I owe you bigtime!
    seedy_tea, deeezy, Biscuits and 14 others like this.
  8. Apr 17, 2019 at 2:54 AM
    #1068
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Joining this for 2tr-fe info. I'll more than likely be in the market for an aftermarket ecu.. What sai deletes are you guys using? I already made my block off plate on a buddies plasma table.
  9. Apr 17, 2019 at 3:30 AM
    #1069
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    For any of you A/T guys wanting to fiddle with shift scheduling. The stock TRD tune tables for my truck have it shifting 2-3 at 5100 and 3-4 at 5300. I bumped these up to have it shift at 5500.
    The values in the tables are for transmission output speed. So in order to calculate your desired shift RPM...
    Desired Shift RPM / Gear Ratio = Output Speed
    I went with these:
    (2-3 shift) 2700*2.0425 = 5514 RPM
    (3-4 shift) 3950*1.4006 = 5532 RPM
  10. Apr 17, 2019 at 5:30 AM
    #1070
    Lthompson
    Lthompson Well-Known Member
    Give us an economy report after a few days if possible.. awesome!
  11. Apr 17, 2019 at 5:44 AM
    #1071
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Will do. I'm interested in that aspect, too, but for "testing" purposes, my foot has kinda been in it a bit more than usual! :burnrubber:
    Roostfactor, Lthompson and JustDSM like this.
  12. Apr 17, 2019 at 5:51 AM
    #1072
    JustDSM
    Justin
    Ogden, UT
    Nice work! I'm excited to see where things go with the trans tuning :D
    With all things being equal, if you were to drive exactly the same, in the same conditions, with each tune, the "JustDSM N/A tune" would get better mileage. Simple fact is I'm not using as much fuel under load as the stock tune. But let the truck tell it's story, it wont lie :)
  13. Apr 17, 2019 at 6:36 AM
    #1073
    Lthompson
    I’m almost convinced.. just wish I could fix other issues first
    12TRDTacoma likes this.
  14. Apr 17, 2019 at 6:58 AM
    #1074
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I’m convinced, just have money going to other places than this for now. Some actual dyno charts would be nice as well other than the butt dyno reviews.
  15. Apr 17, 2019 at 7:01 AM
    #1075
    JustDSM
    Justin
    Ogden, UT
    Update on the early (2005-2011) vs late (2012+) throttle mapping chatter from 20/30 pages back :D
    Thanks to @DesertRatliff who supplied me with a 2006 calibration to compare! Thanks man!
    I can definitively say, the throttle mapping of the early trucks is in fact more aggressive than the later models. That would definitely explain some of the differences you guys are feeling. The changes are somewhat minor, and not as bold as my throttle mapping but would be great for someone wanting a little more but still needing the ultimate in throttle control for off-road use.
    Here are the differences. This map is not the stock values, but the differences in throttle angle degrees.
  16. Apr 17, 2019 at 7:06 AM
    #1076
    Lthompson
    Mines a 2011.. what does that mean
  17. Apr 17, 2019 at 7:13 AM
    #1077
    Lthompson
    Hard to buy a laptop for no other reason.
    Biscuits likes this.
  18. Apr 17, 2019 at 7:16 AM
    #1078
    JustDSM
    Justin
    Ogden, UT
    No worries.. I'll remove it. I think the point is people want dyno proof should fund it.
  19. Apr 17, 2019 at 7:21 AM
    #1079
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Genuine question as I know nothing about tuning, is that how much Dyno tuning usually costs? I don't even know where the closest dyno is since I live in the woods :anonymous:
  20. Apr 17, 2019 at 7:21 AM
    #1080
    JustDSM
    Justin
    Ogden, UT
    2011's share the more aggressive mapping, 2012 is when they neutered the throttle even more.
    Roostfactor likes this.
