HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 18, 2019 at 12:41 PM
    #1221
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Hell YES! In!!!
  2. Apr 18, 2019 at 12:49 PM
    #1222
    Roostfactor
    TX panhandle
    Thanks guys! I already bought an Ebzy female pigtail and have a maf extension harness that I will Frankenstein together.
    I also have an OEM maf coming and am probably going to buy a junkyard Tundra intake assembly to play with.
    Good times!
  3. Apr 18, 2019 at 12:51 PM
    #1223
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Hitachi is in bed with them haha
    Biscuits, BassAckwards and Torspd like this.
  4. Apr 18, 2019 at 12:55 PM
    #1224
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Me
    Roostfactor and JustDSM like this.
  5. Apr 18, 2019 at 1:05 PM
    #1225
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  6. Apr 18, 2019 at 1:11 PM
    #1226
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  7. Apr 18, 2019 at 1:18 PM
    #1227
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Do you have a ballpark price?
    loginfailed[QUOTED] likes this.
  8. Apr 18, 2019 at 1:28 PM
    #1228
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    This
    loginfailed likes this.
  9. Apr 18, 2019 at 1:31 PM
    #1229
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Aiming for less than $500
    05Taco4x4 likes this.
  10. Apr 18, 2019 at 1:33 PM
    #1230
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Gotta pay $780 to get a set of Tor-spec injectors. :D
    Roostfactor likes this.
  11. Apr 18, 2019 at 1:36 PM
    #1231
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only if prices have changed, or that is a group-buy price. If it is, holy schnikees! They were ~$1300.
  12. Apr 18, 2019 at 1:59 PM
    #1232
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Oh damn! I thought the 1050 and 1300 were the same price.
    $780 for the 1050x (6)
    $1350 for the 1300x (6)
  13. Apr 18, 2019 at 4:09 PM
    #1233
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Will this set of injectors work with a trd tune or only hp? Possibly in on this.
  14. Apr 18, 2019 at 4:13 PM
    #1234
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You'll need HPTuners or some other means to scale the injectors appropriately.
  15. Apr 18, 2019 at 4:28 PM
    #1235
    ThomasMore66
    Dallas/Fort Worth & Durango
    Don’t hate on me. Why would this be better than the ones I’m waiting on from URD?
  16. Apr 18, 2019 at 4:30 PM
    #1236
    ThomasMore66
    I wish you were closer.
  17. Apr 18, 2019 at 4:35 PM
    #1237
    JustDSM
    Justin
    Ogden, UT
    Precision and accuracy in their specification and properties.
    They’re matched by more than just flow rate, but by response time leading to even mixtures across all cylinders is the short answer.
    @loginfailed showed me this:
    https://youtu.be/8GhsxK9or0I
    Biscuits, Roostfactor, Norton and 5 others like this.
  18. Apr 18, 2019 at 4:54 PM
    #1238
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
  19. Apr 18, 2019 at 5:01 PM
    #1239
    12TRDTacoma
    Rob
    Concordia
    Boosted
  20. Apr 18, 2019 at 5:14 PM
    #1240
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
