HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 18, 2019 at 7:11 PM
    #1261
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    loginfailed[QUOTED] likes this.
  2. Apr 18, 2019 at 7:17 PM
    #1262
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  3. Apr 18, 2019 at 7:17 PM
    #1263
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Apr 18, 2019 at 7:20 PM
    #1264
    Jesse
    Poulsbo
    15' DCSB OR S/C
  5. Apr 18, 2019 at 7:20 PM
    #1265
    Jesse
    Poulsbo
    15' DCSB OR S/C
  6. Apr 18, 2019 at 7:21 PM
    #1266
    Lthompson
    Lthompson Well-Known Member
    Is there really a reason for different injectors other than supplied if not going more than 8-9 psi boost?
    loginfailed and Norton like this.
  7. Apr 18, 2019 at 7:23 PM
    #1267
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  8. Apr 18, 2019 at 7:24 PM
    #1268
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Apr 18, 2019 at 7:24 PM
    #1269
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks! Why is the Amazon link for hp so much less? Is that price without credits?
    Is that a correct link to by one?
    loginfailed likes this.
  10. Apr 18, 2019 at 7:25 PM
    #1270
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You can order the HP Tuners MPVI2 from their website or some of the guys have found deals on Amazon for a little bit cheaper.
  11. Apr 18, 2019 at 7:31 PM
    #1271
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Still nicer than the Timex. Both way nicer than the Fossils I’m currently running.
  12. Apr 18, 2019 at 7:36 PM
    #1272
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I haven’t looked in Amazon.
    For just the hardware cost is $299 for basic or $549 for pro. Then you need 4 credits separately. Credits normally run $50 each.
  13. Apr 18, 2019 at 7:36 PM
    #1273
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The correct base model is 550.00 does that sound right?
  14. Apr 18, 2019 at 7:37 PM
    #1274
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I don’t recall any deal on Amazon with credits. Each credit is 49.99 and four credits gives you unlimited access to your own ECU read and write.
    Amazon deal was 278.00 for just the device, add $200 bought from HP Tuner separate and you are good to go for a basic setup. You can go PRO later for the same price just buy through HP and they will upgrade your hardware through a download.
    Norton likes this.
  15. Apr 18, 2019 at 7:37 PM
    #1275
    Jesse
    Poulsbo
    15' DCSB OR S/C
    The Amazon link at the bottom of this thread. I'd prefer buying though them.
  16. Apr 18, 2019 at 7:39 PM
    #1276
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just the hardware. Unless it's a bad deal not to buy from hp direct.
  17. Apr 18, 2019 at 7:39 PM
    #1277
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I edited the post you quoted, I had the numbers wrong.
  18. Apr 18, 2019 at 7:39 PM
    #1278
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I’d be in for these also.
  19. Apr 18, 2019 at 7:41 PM
    #1279
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    05Taco4x4 likes this.
  20. Apr 18, 2019 at 7:44 PM
    #1280
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So hp wont give me a hard time for purchasing from one of their retailers?
