HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 19, 2019 at 5:43 AM
    #1321
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'd also like to know.. Asking for a friend..
  2. Apr 19, 2019 at 5:45 AM
    #1322
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’d be in, but I already have the URD ones installed.
    05Taco4x4, 5thGearPinned and JustDSM like this.
  3. Apr 19, 2019 at 5:46 AM
    #1323
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I'm in for cam gears. Hp tuner pro version arriving today. Also I have tables set up using the maf calibrator that dialed in my rich trd tune. Willing to share said tables if they will translate well into the hp tuning
  4. Apr 19, 2019 at 5:49 AM
    #1324
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I hit the 322 g/s MAF ceiling this morning on the way to work. With the restrictive stock air box, stock throttle body and 2.5” exhaust!
    Hurry up and test that Tundra MAF, @Roostfactor !
  5. Apr 19, 2019 at 5:49 AM
    #1325
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    but you can sell the ucon with the new cam gears. no one will want it with out them. but i dunno who wants ucon now anyways
    Roostfactor and JustDSM like this.
  6. Apr 19, 2019 at 5:51 AM
    #1326
    JustDSM
    Justin
    Ogden, UT
    What were the axes on the tables in the R4 Software? RPM/MAF Volts?
  7. Apr 19, 2019 at 5:52 AM
    #1327
    JustDSM
    Justin
    Ogden, UT
    How's that new timing map feel?
  8. Apr 19, 2019 at 5:54 AM
    #1328
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im keeping mine lol worked too hard to get it running right to jump ship now:anonymous:
    Roostfactor likes this.
  9. Apr 19, 2019 at 5:55 AM
    #1329
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I’ll have a set
    JustDSM likes this.
  10. Apr 19, 2019 at 5:57 AM
    #1330
    JustDSM
    Justin
    Ogden, UT
    #Spoileralert
    I'm working on reproducing gears that will use the same cam timing specifications that the APR/URD gears utilized. So those that may want gears can get them. Those with UCON's can unload them if they wish (with gears) and still have the option to run the retarded exhaust cam timing.
  11. Apr 19, 2019 at 5:59 AM
    #1331
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    billet gears? lol
    12TRDTacoma likes this.
  12. Apr 19, 2019 at 5:59 AM
    #1332
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    From the short distance I’ve driven it, it’s feeling very smooth!
  13. Apr 19, 2019 at 6:00 AM
    #1333
    mightytacoman
    Kel
    4.5L 1grfe
    Yes to all the above. R4 software. rpm in 500 increments. maf voltage in 0.1 volt increments
    12TRDTacoma and JustDSM[QUOTED] like this.
  14. Apr 19, 2019 at 6:02 AM
    #1334
    JustDSM
    Justin
    Ogden, UT
    You could use them in the HPTuners software but that wouldn't be the best way to approach properly fueling the motor when you now have access to the tables/maps that actually make the fueling decisions, instead of manipulation of external sensors to get the ECU to fuel the motor the way you want.
  15. Apr 19, 2019 at 6:12 AM
    #1335
    ThomasMore66
    Dallas/Fort Worth & Durango
    So, I've installed the software that came on the flashdrive. Do I need to get a different version off of the HP Tuners website?
    loginfailed likes this.
  16. Apr 19, 2019 at 6:13 AM
    #1336
    JustDSM
    Justin
    Ogden, UT
    From working with another, I'd STRONGLY encourage folks to download the latest beta release off HPTuners web site. I have a feeling the USB contains the full version, which at current time, will lead to some headaches if you attempt to use it on the Tacoma platform.
    Biscuits, Norton, 05Taco4x4 and 4 others like this.
  17. Apr 19, 2019 at 6:15 AM
    #1337
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I didn’t even know what that thumb drive was for. I think everybody is using the Beta VCM Suite. I recommend you remove all other software and then download only the beta version from the HP website. There should be a small set of instructions with the tuner telling you the sequence to download the suite then plug in your device for verification and sync.
    Norton, JustDSM and BassAckwards like this.
  18. Apr 19, 2019 at 6:21 AM
    #1338
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I would be happy to learn what you know.
    mightytacoman[QUOTED] likes this.
  19. Apr 19, 2019 at 6:24 AM
    #1339
    JustDSM
    Justin
    Ogden, UT
    MMhmmmm :)
  20. Apr 19, 2019 at 6:25 AM
    #1340
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    any idea on cost?
    JustDSM[QUOTED] likes this.
