HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 19, 2019 at 6:26 AM
    #1341
    ThomasMore66
    Dallas/Fort Worth & Durango
    Installed! I don't need to be connected to the internet to read the vehicle, do I?
  2. Apr 19, 2019 at 6:27 AM
    #1342
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I have copies in hand, and plan on visiting a few shops with the CNC capability to reproduce. I should know more on that front next week. I plan on making probably 15-20 sets unless demand dictates more.
  3. Apr 19, 2019 at 6:28 AM
    #1343
    JustDSM
    Justin
    Ogden, UT
    Yes sir, you do. Also to write.
    You can datalog without the internet connection.
  4. Apr 19, 2019 at 6:28 AM
    #1344
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    maybe start a new thread and see if u can get a list going?
  5. Apr 19, 2019 at 6:30 AM
    #1345
    JustDSM
    Justin
    Ogden, UT
    Absolutely. I was going to keep it hush until I had the cost figures as that's the big question everyone has. But I'm happy to drum up some interest since I now have copies in hand.
  6. Apr 19, 2019 at 6:30 AM
    #1346
    ThomasMore66
    In for cam gears, uncertain on injectors. But I do have FOMO.
    loginfailed and JustDSM[QUOTED] like this.
  7. Apr 19, 2019 at 6:36 AM
    #1347
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    What degrees of alteration from stock will they be?
    JustDSM[QUOTED] likes this.
  8. Apr 19, 2019 at 6:37 AM
    #1348
    ThomasMore66
    How long can you datalog? Do you need the computer connected to datalog or can you just have the tuner plugged into the OBDII port? Again, all of this is new to me.
  9. Apr 19, 2019 at 6:40 AM
    #1349
    JustDSM
    Justin
    Ogden, UT
    For as long as you have the HD space to store it :) I routinely datalog for 30 min on my commute to work when I'm evaluating changes. But that's on the extreme end.
    You need the MPVI2 in the OBD2 port, and USB connected to the computer. With VCM Scanner open, hit the space bar and the software will connect and you'll see your data stream on the screen.
    No worries man! We're all here to help!
  10. Apr 19, 2019 at 6:42 AM
    #1350
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So 4 credits are needed for every single adjustment?
  11. Apr 19, 2019 at 6:42 AM
    #1351
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I wouldn't mind doing better injectors which are more balanced over the OE Denso's but California. :(
    I am currently running the stock airbox on my setup as well. Just reverted yesterday actually. I hit the 322 gm/s limit VERY quick on a few WOT runs yesterday and dropped to a maximum of 10 psi boost. I feel the restriction on mid to full throttle applications now. I actually would love to run a Tundra OE airbox especially if it can be retrofitted in such a way where it looks very OE. I doubt smog visual would ever even doubt it, but since those trucks are good right out of the gate to 500HP they would SURELY suffice our setup no problem and be a fantastic happy medium alternative to an aftermarket air intake.
    Missing my URD setup right about now but I'd rather be "OE."
    Not wanting to rush you @Roostfactor but hurry along with your work good sir! :)
  12. Apr 19, 2019 at 6:42 AM
    #1352
    JustDSM
    Justin
    Ogden, UT
    The gears will retard the exhaust cam by 3deg in relation to crank angle. (Same as APR/URD spec)
  13. Apr 19, 2019 at 6:43 AM
    #1353
    JustDSM
    Justin
    Ogden, UT
    No sir, One time licensing fee allowing unlimited number of uses after.
  14. Apr 19, 2019 at 6:43 AM
    #1354
    12TRDTacoma
    Rob
    Concordia
    Boosted
    4 credits is only needed once. It's a once and done transaction.
  15. Apr 19, 2019 at 6:44 AM
    #1355
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Paint your new injectors orange to pass the test!
  16. Apr 19, 2019 at 6:45 AM
    #1356
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Son of bitch. That is a very fair price. I cancelled last nights order and bought directly from hp just now.
  17. Apr 19, 2019 at 6:46 AM
    #1357
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :rofl:
    That's an option. A horrible one, but albeit an option nonetheless. Lol the things we do for HP eh?
    JustDSM likes this.
  18. Apr 19, 2019 at 6:48 AM
    #1358
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Well, just an idea on some way to alter them to look the part. 8 dollars in orange 3m wrap done correctly could be game changing.
    12TRDTacoma[QUOTED] and JustDSM like this.
  19. Apr 19, 2019 at 6:50 AM
    #1359
    ThomasMore66
    Credits purchased. Need to move some cars around so I can read my truck and be connected to the internet.
    JustDSM, Roostfactor and loginfailed like this.
  20. Apr 19, 2019 at 6:51 AM
    #1360
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So now I have the radiator, Johnson pump, more gauges, hp tuner, possible injectors and cam gears on deck. I guess the only logical next things are rods and a nitrous kit.
