HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 19, 2019 at 6:53 AM
    #1361
    ThomasMore66
    Dallas/Fort Worth & Durango
    What is the connector on the side of the tuner for?
  2. Apr 19, 2019 at 6:58 AM
    #1362
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    The pro expansion module i believe
    Roostfactor, JustDSM and 12TRDTacoma like this.
  3. Apr 19, 2019 at 6:58 AM
    #1363
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  4. Apr 19, 2019 at 7:02 AM
    #1364
    ThomasMore66
    I still laugh at Johnson pump...
  5. Apr 19, 2019 at 7:02 AM
    #1365
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got a Johnson pump also.
    Er... yeah. Disregard that.
  6. Apr 19, 2019 at 7:03 AM
    #1366
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thread is moving fast this morning!
    If you go straight for the beta without ever installing the full version, there is an error that will occur with certain builds of Windows. @Roostfactor experienced it and I experienced it on one of my laptops.
    Having gone through that once and finding the solution via google, I’d suggest installing the full version and then install the beta over top of it.
  7. Apr 19, 2019 at 7:06 AM
    #1367
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The errors associated to just installing the beta version alone usually involve a continue or quit text box. Just hit continue and move forward, as the error in no way has affected my functionality, of course my setup is simple as I only use read/ write and logging modes.
    loginfailed and JustDSM like this.
  8. Apr 19, 2019 at 7:09 AM
    #1368
    ThomasMore66
    Oh good grief. I installed the version on the flash drive, then uninstalled it. Then I downloaded the beta version and installed that. So far it seems to work. Been looking through sample files. There are settings in here that I have no clue what they are. Still haven’t scanned my truck.
  9. Apr 19, 2019 at 7:12 AM
    #1369
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spray all the visible injectors down with a thin film of oil, then drive through a very dusty terrain. Accelerate dirt collection on your engine. Hide the mods with an ugly engine bay. :D
  10. Apr 19, 2019 at 7:15 AM
    #1370
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Better get pistons if adding nitrous. Your current skinny ring lands just don't have the muscle to handle it.
  11. Apr 19, 2019 at 7:25 AM
    #1371
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you can see stuff and no error pops up when you first open the editor, you don’t have that issue. You’re good to go.
    Norton, JustDSM and Roostfactor like this.
  12. Apr 19, 2019 at 7:38 AM
    #1372
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sooo.... are there benefits for a stock NAd truck here? Is there a safe setup? How much $$ we talking here.
    JustDSM likes this.
  13. Apr 19, 2019 at 7:38 AM
    #1373
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes. But they'll answer in detail.
  14. Apr 19, 2019 at 7:47 AM
    #1374
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yes and you should buy me one too for my bday.
    It’s what we were all hoping ovtune would be and more, but they dropped the ball. And from a much more established company
  15. Apr 19, 2019 at 7:51 AM
    #1375
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    One unit can be used multiple times with only the purchase of credits.....Most here are buying one so they can tinker, but I would think that if I was n/a, I'd be asking @JustDSM to load up a tune. I think he offered it for $250...
  16. Apr 19, 2019 at 7:51 AM
    #1376
    nd4spdbh
    SoCal
    Just SO many pages here. I see JustDSM made an NA tune... where can i download this, have the differences to a stock tune been mentioned?
    My Bday is a week after yours sir! Is it possible to share an HP tuner?
  17. Apr 19, 2019 at 7:53 AM
    #1377
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Is this true? Haven’t heard this yet.
    See above post. If true we could split for about $500 a piece
    Edit: you could buy it, get your tune dialed in over summer. Then I pick up the unit in July from you and can get mine dialed in.
    Double edit:
    Since the actual unit could be shared and each person would just need to purchase credits for their tune, @XPOTRPR @GT7 and any other AZ peeps care to split a purchase?
  18. Apr 19, 2019 at 8:09 AM
    #1378
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    really hoping to have this tuning stuff figured out this year. love to spend a day at the dyno and adjusting timing and ignition at high rpms and have the meth comes on.
    meth kit is cheaper then bigger injectors. just saying
    TodayWasTHeDaY and JustDSM like this.
  19. Apr 19, 2019 at 8:11 AM
    #1379
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Each ecu needs 4 credit. One module can be shared though
  20. Apr 19, 2019 at 8:16 AM
    #1380
    ThomasMore66
    So, I've read my truck and I received the message that it didn't pull the file from my truck, I received a stock file. Since I have the TRD tune, did I receive a TRD tune file? How do I verify that?
    Roostfactor and loginfailed like this.
