HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 19, 2019 at 8:28 AM
    #1381
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Calibration id perhaps?
    Norton, Roostfactor and DocME like this.
  2. Apr 19, 2019 at 8:33 AM
    #1382
    ThomasMore66
    Dallas/Fort Worth & Durango
    Is that this? 3YWG41
    Norton, Roostfactor and loginfailed like this.
  3. Apr 19, 2019 at 8:35 AM
    #1383
    Lthompson
    Lthompson Well-Known Member
    What would cam gears really accomplish?
  4. Apr 19, 2019 at 8:38 AM
    #1384
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    The stock cam phasing allows for some of the spent exhaust to remain in the cylinder for the next cycle. This helps with emissions. However, it also heats up the incoming air/fuel charge and deprives the cylinder of 100% make up air. The cam gears alter the phasing to allow all the gasses out and should help with power. Many think this is where a good portion of UCON's power came from, but it also helps to prevent preignition.
  5. Apr 19, 2019 at 8:38 AM
    #1385
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    @JustDSM Id love some gears to go with my ucon to sell. Maybe the place you have doing it would take all the spare stockers lying around and repurpose them
    JustDSM, Roostfactor and DocME like this.
  6. Apr 19, 2019 at 8:39 AM
    #1386
    DocME
    California
    '07 FJ Cruiser
    That's what I've been threatening to do. Cut an offset keyway opposite the stock one! I'm going to do it....unless we get a good price on new ones.
    JustDSM, Roostfactor and GT7[QUOTED] like this.
  7. Apr 19, 2019 at 8:45 AM
    #1387
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    MORE POWER!
  8. Apr 19, 2019 at 8:46 AM
    #1388
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It means you’ve received a clean copy of the TRD flash from the HP Tuners server.
    You’re good to go.
    3WYG41 is the TRD flash calibration ID for your truck.
  9. Apr 19, 2019 at 8:52 AM
    #1389
    Lthompson
    So this turned from me getting a tuner... to now I gotta get injectors and cam gears.. and etc! I’m so lost
  10. Apr 19, 2019 at 8:54 AM
    #1390
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Data logging on my trip today.
  11. Apr 19, 2019 at 8:55 AM
    #1391
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Deep breaths! Lol
  12. Apr 19, 2019 at 8:56 AM
    #1392
    DocME
    California
    '07 FJ Cruiser
    Whoa, hold up now.....You don't need exhaust gears to have massive benefits from a tune. The ucon/X1 used them because they were pushing the limits with other blower/forced induction systems. Most guys in here want cam gears because their UCON, which they are transitioning from, is basically a brick with out them. You don't even need upgraded injectors, this is only for the folks that are going to push their tunes and setups beyond the 415hp range. I don't know what your goals would be, but you don't need to go crazy to benefit from the tuner.....
  13. Apr 19, 2019 at 9:08 AM
    #1393
    Lthompson
    I know... kinda. Lol. I’m just being facetious
    Roostfactor, Torspd and loginfailed like this.
  14. Apr 19, 2019 at 9:31 AM
    #1394
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Injectors are are necessary dependant upon brake HP. Currently. Basing future size mathematically off of future HP goals, datalogs, and having sufficient overhead percentage to not max them out. Boom boom.
  15. Apr 19, 2019 at 9:31 AM
    #1395
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You could get a brand new kit minus the shitty Bullydog tuner for $4200 or so.
  16. Apr 19, 2019 at 9:45 AM
    #1396
    Roostfactor
    TX panhandle
    Me too!
    JustDSM likes this.
  17. Apr 19, 2019 at 9:51 AM
    #1397
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Guys, I’ve just heard back from Fuel Injector Clinic. They are hooking us up on pricing. Waiting to hear back to get permission to post the prices publicly.
    Currently the list is 12 people. As long as we get at leas 10 we can get the highest discount level.
    :bananadance:
  18. Apr 19, 2019 at 9:55 AM
    #1398
    Lthompson
    Dang.. if only I had a supercharger
    loginfailed[QUOTED] likes this.
  19. Apr 19, 2019 at 10:02 AM
    #1399
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    :spending:
  20. Apr 19, 2019 at 10:02 AM
    #1400
    Lthompson
    I am planning to purchase a magnuson, headers, exhaust, and proper intake soon, and tuning stuff apparently. I’m still in planning stages though and y’all keep adding to my plans. But this is a dd truck, not a hot rod, so reliably and economy are still a priority.
