HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 20, 2019 at 6:15 AM
    #1481
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    There are PIDs that show up in the scan tool that show up for O2 temp. Not sure if those are calculated from one of those tables or if the data comes from the sensors themselves.
    Torspd and JustDSM[QUOTED] like this.
  2. Apr 20, 2019 at 6:22 AM
    #1482
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Dollars to donuts that if you were able to watch those values on the scan tool, they'd correlate with the values in the component temp table. There isn't a thermocouple or anything actively measuring temperatures in the exhaust so I bet those tables are what is being reported by that PID.
    Hell we can log them in HPT.. Standby.. I've got some data on this..
  3. Apr 20, 2019 at 6:47 AM
    #1483
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    @JustDSM . I am going to log another 2 hours or so today. What is the best way for you to gain access to these files? Email or Team Viewer?
  4. Apr 20, 2019 at 6:54 AM
    #1484
    JustDSM
    Justin
    Ogden, UT
    Ok.. Not perfect world example as this was a log taken during a 7 min drive I took testing out some N/A tuning. For some background, the component protection circuit of this ECU offsets the base temperature maps with adder and "subtractor" maps that modify the temperature used in the Compoenet predicted temp. maps. These offsets are for timing retard (which adds temperature) and vehicle speed (which reduces temperature) for obvious reasons. So these temperatures adder and subtractor maps are enabled and in play in this particular log, so they're not going to perfectly align. Also there is some noise in this since I was driving and the dynamic nature of things will sometimes throw things off a little, but try your best to filter that out..
    A test could be done to zero out the adder and subtractor tables, to reduce external variables but I think this pretty well makes the point that the PID is reporting the values in this table after applying the different adders and subtracors.
    *NOTE* there are other temp maps, so this may not be the B1S1 cat temp map that was logged above. Component 0 & 2 map shown for reference.
  5. Apr 20, 2019 at 6:56 AM
    #1485
    JustDSM
    Justin
    Ogden, UT
    I can do team viewer, but if you'd like to email the logs I can make some suggestions. I'll be largely available today since the machine shops in the area are closed and I can't get rolling with the cam gears with it being Easter weekend :)
  6. Apr 20, 2019 at 7:21 AM
    #1486
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
  7. Apr 20, 2019 at 7:45 AM
    #1487
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Well I have a similar issue to someone else in this thread in that it states I need 6 credits to write data. How have others handled this situation? Already put a ticket in to @HPTuners
  8. Apr 20, 2019 at 7:54 AM
    #1488
    JustDSM
    Justin
    Ogden, UT
    Did you by chance read the truck initially with the Full-Version of the VCM Editor?
  9. Apr 20, 2019 at 8:04 AM
    #1489
    mightytacoman
    Kel
    4.5L 1grfe
    The beta version wouldn't read it all for me. What would you suggest? Uninstall/reinstall?
  10. Apr 20, 2019 at 8:09 AM
    #1490
    JustDSM
    Justin
    Ogden, UT
    Odd.. I'm not able to really get into the details on this aspect of the software, as it's a little outside of my wheelhouse, but @HPTuners would be the one to do so.
    The commonality here, is that you are being prompted for 6 credits, as was someone else here who used the Full Version to read the truck. Have you paid for the additional credits? I'd hold off if you haven't as the Toyota applications only require 4.
  11. Apr 20, 2019 at 8:20 AM
    #1491
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It works.
  12. Apr 20, 2019 at 8:34 AM
    #1492
    ThomasMore66
    Dallas/Fort Worth & Durango
    Where have you been? We’re all buying injectors.
    Torspd and loginfailed like this.
  13. Apr 20, 2019 at 9:26 AM
    #1493
    ThomasMore66
  14. Apr 20, 2019 at 9:33 AM
    #1494
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I just did the write to my truck and needed four creds.
    First time on trd tune from ovtune. First impression is afr's are ridiculously rich and truck doesn't feel as smooth. Gonna add Roush tensioner and 2.3 pulley and redo FPR mod in next couple of weeks and then get properly tuned. Can't wait for better throttle response especially and better mpg!
  15. Apr 20, 2019 at 9:36 AM
    #1495
    JustDSM
    Justin
    Ogden, UT
    What are your mods now? You don't have to wait until you upgrade pulleys to get a better baseline. Headers? FPR Mod?
  16. Apr 20, 2019 at 9:37 AM
    #1496
    JustDSM
    Justin
    Ogden, UT
    Glad you're up and running!
    12TRDTacoma likes this.
  17. Apr 20, 2019 at 9:37 AM
    #1497
    zippsub9
    Halfmoon, NY
    14 DCLB
  18. Apr 20, 2019 at 9:38 AM
    #1498
    zippsub9
    Halfmoon, NY
    14 DCLB
    I will get with you later tonight to help build your file repository for stock exhaust data with S/C
    JustDSM likes this.
  19. Apr 20, 2019 at 9:39 AM
    #1499
    ThomasMore66
    I need to do some logging.
  20. Apr 20, 2019 at 9:43 AM
    #1500
    TodayWasTHeDaY
    Russ
    Calgary
    PM sent
