HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 20, 2019 at 9:53 AM
    #1501
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Mark me down as interested in a set of cam gears!
    JustDSM[QUOTED] likes this.
  2. Apr 20, 2019 at 10:00 AM
    #1502
    ThomasMore66
    Dallas/Fort Worth & Durango
    Who wants to drive exuberantly side by side on a closed course?
  3. Apr 20, 2019 at 10:09 AM
    #1503
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    If I was in your neck of the woods I'd be all over it!
  4. Apr 20, 2019 at 10:14 AM
    #1504
    ThomasMore66
    I can’t believe @JustDSM smoothed everything out so much. I like the no-drama go. I always had a little “glitch” at points when I shifted down at moderate speed that almost felt like a flat spot from my carburetor days. I haven't felt that with this tune.
  5. Apr 20, 2019 at 10:19 AM
    #1505
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Very cool! I love hearing your guys feedback on stuff (whether good or bad) as it allows me to create a personalized product for each of you, depending on your needs, and vehicle specs.
    You know how to reach me for your next round of updates should you choose @ThomasMore66!
  6. Apr 20, 2019 at 10:36 AM
    #1506
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    Just loaded JustDSM’s aggressive throttle tune! Very excited on this! Also wanted to thank Loginfailed for posting the shift calculation for us AT guys!
    Happy tuning to all today!
  7. Apr 20, 2019 at 10:38 AM
    #1507
    JustDSM
    Justin
    Ogden, UT
    I think you're the first to run that map more than a trip around the block ;) It's definitely not for everyone, but.. It just may be for you! :)
  8. Apr 20, 2019 at 1:00 PM
    #1508
    12TRDTacoma
    Rob
    Concordia
    Boosted
    All of TW has now become (even just a little) proficient in HPTuners.
    I love it.
  9. Apr 20, 2019 at 1:01 PM
    #1509
    JustDSM
    Justin
    Ogden, UT
    It's going to be nuts when they release support for the 2GR.. It's confirmed.
  10. Apr 20, 2019 at 1:02 PM
    #1510
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Those poor bastards need the support more than we do with their trannys that can't even go up an incline without dropping gears all day long. Hahahaha.
  11. Apr 20, 2019 at 2:12 PM
    #1511
    ThomasMore66
    So I just went on a 40 mile, moderate speed with my wife and got some stunning gas mileage.
  12. Apr 20, 2019 at 2:22 PM
    #1512
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    A few questions.
    Are you using OEM injectors and having them flow matched to the requested size?
    Will the reflowed injectors come with all the required data on a data sheet?
    Can we get an example of the process or what all will be received with the injectors?
    Will the oem connector now fit again if using oem injector bodies?
  13. Apr 20, 2019 at 2:40 PM
    #1513
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Missin out apparently. I don't check TW much anymore. Larger injectors really necessary?
    Norton likes this.
  14. Apr 20, 2019 at 2:45 PM
    #1514
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Depends if u wanna :burnrubber:
  15. Apr 20, 2019 at 2:47 PM
    #1515
    ThomasMore66
    You know you’re one of us.
  16. Apr 20, 2019 at 2:54 PM
    #1516
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    These start as brand new Bosch injectors in whichever flow rate you choose. They are new, not re-flowed. 525cc, 650cc, 775cc, 1000cc etc. The plug is different. The set comes with wiring pigtails (free) that you can solder in. There is an option for plug and play adapter harnesses (add’l cost) if you choose to go that route. The injector set comes with a detailed data sheet for you to use for HP Tuners or whatever tuning solution you’re using.
    Some of this info is touched on in this video:
  17. Apr 20, 2019 at 3:25 PM
    #1517
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’d just like to say a big thanks to @JustDSM for remotely tuning my truck. It feels much more smooth running and more powerful than it ever did with the UCON.
  18. Apr 20, 2019 at 3:42 PM
    #1518
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    12TRDTacoma likes this.
  19. Apr 20, 2019 at 3:45 PM
    #1519
    BillDaCat8
    Jake
    PHX
    ooh? I'm interested
  20. Apr 20, 2019 at 3:51 PM
    #1520
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hell yeah brother get in on this. The beamer will have to wait :thumbsup:
    BillDaCat8[QUOTED] likes this.
