HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 21, 2019 at 3:56 PM
    #1641
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  2. Apr 21, 2019 at 3:59 PM
    #1642
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Makes perfect sense! Thanks for detailed explanations both of you!!! I assume its perfectly safe for regular 87 octane as well, and probably has the same ignition table changes for premium 91+ based on knock sensor readings.
    Lastly... do we know if the JustDSM base tune will pass smog? (unfortunatly gotta deal with that here in CA... i mean i guess i could flash stock at the time, then flash back... but im curious)
    PLEASE come back with results (tag me in them would be awesome! as this thread is moving quick!) As one of my main things would be for a more efficient setup (better mpgs) and 500ish bucks in gas savings over a year is pretty damned impressive assuming not crazy miles driven per year. (not to mention a truck with a lil more pep in its step!)
  3. Apr 21, 2019 at 4:17 PM
    #1643
    Lthompson
    Lthompson Well-Known Member
    Intriguing! May have to hold out for a whipple instead of a magnuson
  4. Apr 21, 2019 at 4:47 PM
    #1644
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'd love to know that as well. I'm confident that it would have no problems passing but to verify, I'll cover costs of testing if you'd like to put it to the test.
    BassAckwards likes this.
  5. Apr 21, 2019 at 6:07 PM
    #1645
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I don’t see a 76mm throttle body. :boink:
  6. Apr 21, 2019 at 6:08 PM
    #1646
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id have one but urd has been out of stock on their 65-76mm adapter plates for a while now.. have one you want to sell?:D
  7. Apr 21, 2019 at 6:09 PM
    #1647
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Haha sure don’t. Just ported mine a little larger.
  8. Apr 21, 2019 at 6:09 PM
    #1648
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I saw that too!
  9. Apr 21, 2019 at 6:42 PM
    #1649
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    I’m still way back at page 14 but wanted to jump ahead and say thanks to @BassAckwards I’ll be joining in with an NA ‘08 Auto. Kinda curious to see where we can take it. I’ve got some catching up to do but I’m pretty encouraged with the knowledge and teamwork going on in this thread.
  10. Apr 21, 2019 at 6:47 PM
    #1650
    BassAckwards
    Glad to see you join in on the madness:thumbsup:
    JustDSM and DiamondW[QUOTED] like this.
  11. Apr 21, 2019 at 6:51 PM
    #1651
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  12. Apr 21, 2019 at 6:55 PM
    #1652
    ThomasMore66
    Dallas/Fort Worth & Durango
    Finally. I didn’t want to bug you about this, but it’s awesome.
  13. Apr 21, 2019 at 6:56 PM
    #1653
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Never a bother. I’ve been catching up on this
  14. Apr 21, 2019 at 6:57 PM
    #1654
    ThomasMore66
    I was skeptical that it could make such a big difference, but it pulls way better.
    JustDSM likes this.
  15. Apr 21, 2019 at 7:08 PM
    #1655
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I believe ya. I haven’t seen 1 person disappointed yet. I really do dig bassackwards new engine bay. I’m trying to find a shop near me that deal with hp. This shit is way over my head for me to be messing with. I also went back and forth with ov today. He says he’s still supporting the few that want it. So for at least the immediate future I want to see what he can do for me in regards to a more custom tune.
  16. Apr 21, 2019 at 7:19 PM
    #1656
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Was he referring to 2nd or 3rd gen Tacomas?
  17. Apr 21, 2019 at 7:24 PM
    #1657
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    2nd gens....who gives a crap about third gens!! Lol.
    bobsuruncle, Torspd and Norton like this.
  18. Apr 21, 2019 at 7:28 PM
    #1658
    Jesse
    Poulsbo
    15' DCSB OR S/C
    He does. Reason his attention vanished from 2nd gens. I'm selling my ovtune if you know anyone:)
    bobsuruncle, 1slow4.0 and JustDSM like this.
  19. Apr 21, 2019 at 7:33 PM
    #1659
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Lol yeah your right.
  20. Apr 21, 2019 at 8:57 PM
    #1660
    nd4spdbh
    SoCal
    Once we get some empirical mpg numbers back.... and maybe even a dyno back to back stock vs the basline NA tune (that would be awesome, but wishful thinking), Ill likely jump in on this bandwagon, seems like real positive results even from us Stock everything NA'd crowd. I have yet to need to take my truck to get smogged... but i have a hunch this go around (6 years old) lovely CA will require it (this will occur sometime before november). Worst case scenario, it doesnt pass, ill make sure to go to a place that allows a free retest.
    But honestly given how they do the testing under such light loads (15 and 25mph constant)... i doubt there will be a single issue.
    JustDSM[QUOTED] and snowsk8air2 like this.
