HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 22, 2019 at 8:55 AM
    #1681
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    "The exhaust cam gears retard the exhaust gear timing by 3° in relation to crank angle. Allowing the cylinders to empty more completely on the exhaust stroke. On the intake stroke the cylinders will fill with more air and fuel increasing the overall volumetric efficiency of the engine. There will also be less hot exhaust gas left heating the incoming air and fuel and reducing it's knock potential. This is very advantageous with forced induction conversions."
  2. Apr 22, 2019 at 8:55 AM
    #1682
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not chastising the man, just giving him a hard time, you know, rustling his jimmies a little.
    BassAckwards likes this.
  3. Apr 22, 2019 at 9:00 AM
    #1683
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    :fistbump::thumbsup:
    12TRDTacoma[QUOTED] likes this.
  4. Apr 22, 2019 at 9:01 AM
    #1684
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    12TRDTacoma, JustDSM and BassAckwards like this.
  5. Apr 22, 2019 at 9:02 AM
    #1685
    JustDSM
    Justin
    Ogden, UT
    I do believe the N/A applications would benefit, but probably not to the degree the S/C folks would.
  6. Apr 22, 2019 at 9:04 AM
    #1686
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct. Smaller percentage for N/A. Advantageous for both N/A and S/C applications. Not turbo.
  7. Apr 22, 2019 at 9:04 AM
    #1687
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I'll take a set of cam gears.
    BassAckwards and JustDSM like this.
  8. Apr 22, 2019 at 9:04 AM
    #1688
    ThomasMore66
    Dallas/Fort Worth & Durango
    Me too.
    Edit: Money sent.
  9. Apr 22, 2019 at 9:12 AM
    #1689
    JustDSM
    Justin
    Ogden, UT
    Thanks everyone for the gear orders. I'm just as excited as you probably all are.
    12TRDTacoma and BassAckwards like this.
  10. Apr 22, 2019 at 9:14 AM
    #1690
    BassAckwards
    Could you elaborate as to why these wouldnt be advantageous with a turbo setup? Just curious and looking to learn..
  11. Apr 22, 2019 at 9:31 AM
    #1691
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Put me down for a set.
    JustDSM[QUOTED] likes this.
  12. Apr 22, 2019 at 9:33 AM
    #1692
    JustDSM
    Justin
    Ogden, UT
    You got it!
  13. Apr 22, 2019 at 9:37 AM
    #1693
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Basically exhaust gas reversion. Helping to induce knock by way of higher cylinder temperatures.
  14. Apr 22, 2019 at 9:39 AM
    #1694
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Me count me in
  15. Apr 22, 2019 at 9:39 AM
    #1695
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Can someone school me on credit purchases?
    Getting the MPVI2 here in CA is a little bit of a harder thing to do... thanks CARB. Can i buy just the unit say from a person on ebay, then buy universal credits through say the deal below?
    Norton and JustDSM like this.
  16. Apr 22, 2019 at 9:40 AM
    #1696
    JustDSM
    Justin
    Ogden, UT
    You're added!
  17. Apr 22, 2019 at 9:42 AM
    #1697
    JustDSM
    Justin
    Ogden, UT
    You can buy the unit new or used from any source and utilize it. The credits (its my recommendation to get them direct from HPT for immediate use) can be purchased from a 3rd party like the source you referenced, or The Tuning School, Etc. Getting them from HPT directly though is my preferred method, as it gives me immediate access to that purchase. And that's usually when I'm sitting in the vehicle I want to flash with the laptop.. :D
  18. Apr 22, 2019 at 9:42 AM
    #1698
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Could always have it shipped to me this week and I can bring it when I’m out next weekend. Just make sure it gets her by Thursday.
  19. Apr 22, 2019 at 9:43 AM
    #1699
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Are there any drawbacks to the cam gears with SC? I live in Canada so we occasionally get -40 deg weather
  20. Apr 22, 2019 at 9:43 AM
    #1700
    BassAckwards
    So if one was planning to run a s/c and a turbo together, would it be best to go back to stock cam gears? wondering how it'd work with both..
