HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 22, 2019 at 9:43 AM
    #1701
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Payment sent
    JustDSM[QUOTED] likes this.
  2. Apr 22, 2019 at 9:45 AM
    #1702
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Money on the way. My PCS movers show up on 20 MAY. Not sure if I will be at this address long enough to get them and don’t have my new home address yet. Can I wait to send shipping address?
  3. Apr 22, 2019 at 9:45 AM
    #1703
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Ahhhh ok this makes sense! Thanks for clearing things up!
    LOL, id never get it from you! It would mysteriously vanish.
  4. Apr 22, 2019 at 9:47 AM
    #1704
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    I’m in for a set!
  5. Apr 22, 2019 at 9:48 AM
    #1705
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Got you down as paid too! Thanks for your order and payment!
    Absolutely! I'll happily hold you a set if you can get your deposit in.
  6. Apr 22, 2019 at 9:56 AM
    #1706
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No
  7. Apr 22, 2019 at 9:57 AM
    #1707
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Just the install ;)
    BassAckwards and JustDSM like this.
  8. Apr 22, 2019 at 10:00 AM
    #1708
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'd want to do the math to determine the pressure differential between intake and exhaust. Taking into account the turbine housing A/R. Then you would know if the exhaust pressure would push back into the cylinders or not.
    With a s/c for down low, a larger turbine housing would be most beneficial. On the fly though. Which would reduce exhaust pressure. Likely making the addition of cams gears beneficial in that setup.
    Math would still need to be thoroughly performed, and a built engine would be highly recommended.
  9. Apr 22, 2019 at 10:05 AM
    #1709
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks a bunch for the info! Will definitely be looking into building the motor before doing anything like this. Just starting to do some research for when the time comes to go crazy
  10. Apr 22, 2019 at 10:08 AM
    #1710
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I'm in on this!
  11. Apr 22, 2019 at 10:19 AM
    #1711
    JustDSM
    Justin
    Ogden, UT
    Get 'em while they're hot! :D
    Thanks for the order!
  12. Apr 22, 2019 at 10:25 AM
    #1712
    BillDaCat8
    Jake
    PHX
    You've been paypaled.
    Now I gotta go spend even more moneys on injectors. Damn tacomaworld. :spending:
  13. Apr 22, 2019 at 10:33 AM
    #1713
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    @Torspd, or anyone else, any idea what can really be gained for NA? You know, numbers. I do realize it's just a WAG, Wild Ass Guess, but would like some "Almost Scientific" WAGs,,, AS-WAGs. :D
    BTW, y'awl are killing me. :thumbsup:
    JustDSM likes this.
  14. Apr 22, 2019 at 10:38 AM
    #1714
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    When I was researching running the UCON on NA engines, I was told/read of *up to* 50hp with FBO mods, and the cam gears. So ymmv. Irrc there's a few Dyno results floating around xru with the UCON/APR x-1 and fbo.
    Actually @Torspd started an NA Dyno result thread here back in 2012 starting with before dyno results and results after bolt ons.
    Torspd likes this.
  15. Apr 22, 2019 at 10:41 AM
    #1715
    JustDSM
    Justin
    Ogden, UT
    From URD's site:
  16. Apr 22, 2019 at 10:43 AM
    #1716
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    FBO? I've missed/not seen that one. Also, 50hp on NA does seem like a stretch, not discounting what you've said, but hard to believe that much was left on the table unless the tuning is truly on the ragged edge.
    Thx for the info.
  17. Apr 22, 2019 at 10:45 AM
    #1717
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Full bolt on's, ie: intake, headers, exhaust etc in conjunction with the UCON...
    Lurkin[QUOTED] likes this.
  18. Apr 22, 2019 at 10:46 AM
    #1718
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Got it, thx again.
  19. Apr 22, 2019 at 11:32 AM
    #1719
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Can someone tell me which page the “how to install” videos are on?
  20. Apr 22, 2019 at 11:34 AM
    #1720
    JustDSM
    Justin
    Ogden, UT
    Those where how to "read" and "write" once you have it all installed. I don't believe there were videos on how to install. But, generally people here have had the best luck installing the full version, then installing the Beta over it. Then attempting the read/write processes.
    5thGearPinned[QUOTED] and Norton like this.
