HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 22, 2019 at 1:39 PM
    #1741
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Tough cookie! :p
    BassAckwards and 12TRDTacoma like this.
  2. Apr 22, 2019 at 1:40 PM
    #1742
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    If I truly plan on staying at a 2.7 pulley (once I get there), whether I stay with ovtune with a more custom tune OR end up with an HP tune......do I need these? Are my 455 TRD injectors suitable?.....do you need me to provide a mod list?
  3. Apr 22, 2019 at 1:43 PM
    #1743
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    More to come. I have to get away from the ABS pump. I am setting up a Tundra throttle body with a FJ K&N Tube into the firewall and then split 180* in the cavity to dual filters. A little more noise, but I am used to it and the SC drowns it out. I sound deadened everything on the backside.
    A little more fitting and trimming required. I am going to have to remove about two to three inches of each extension of the splitter.
  4. Apr 22, 2019 at 1:44 PM
    #1744
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you're going HP Tuners is the only way you can make different injectors work. Unless OV Tune can do it for you. But I'd say flow matched is the way to go for smoother performance and better tune overall.
    JustDSM likes this.
  5. Apr 22, 2019 at 2:01 PM
    #1745
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Is that really all the 1gr puts out? Fuck thats pathetic. Maybe i need boost on it more than i realized
  6. Apr 22, 2019 at 2:09 PM
    #1746
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    05Taco4x4, loginfailed and JustDSM like this.
  7. Apr 22, 2019 at 2:11 PM
    #1747
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Why do you think they are usually 400,000 mile engines they are super ball-less.
    Torspd and BassAckwards like this.
  8. Apr 22, 2019 at 2:36 PM
    #1748
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Interested in more pics of this as you progress along with it. :thumbsup:
    JustDSM and BillDaCat8 like this.
  9. Apr 22, 2019 at 2:36 PM
    #1749
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Can anyone post up the install instructions for the cam gears?
    BassAckwards and Norton like this.
  10. Apr 22, 2019 at 2:39 PM
    #1750
    ThomasMore66
    Dallas/Fort Worth & Durango
    What?! No boost? How did you get in here? :D
  11. Apr 22, 2019 at 2:41 PM
    #1751
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  12. Apr 22, 2019 at 2:43 PM
    #1752
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    You da man! Thank you
    BassAckwards[QUOTED] likes this.
  13. Apr 22, 2019 at 3:00 PM
    #1753
    Lthompson
    Lthompson Well-Known Member
    this is really kinda my question too. do I really "need" bigger injectors? other than the 455s.. will goin to 650s affect my fuel economy significantly? or does it even out through better efficiency.. I know nothing of all this
  14. Apr 22, 2019 at 3:02 PM
    #1754
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    12TRDTacoma likes this.
  15. Apr 22, 2019 at 3:05 PM
    #1755
    zippsub9
    Halfmoon, NY
    14 DCLB
    Any way to get rid of permanent codes on the ECU? I got a MIL for emissions and a P106B code DTC. It is undefined in my code reader. I took it out of the tune and rewrote the ECU. The MIL is off but the code reader still lost it as a permanent code. I am wondering if a long batter disconnect would get rid of it since it is no longer in the tune. I removed all SAI today unplugging both valves and the pump.
  16. Apr 22, 2019 at 3:07 PM
    #1756
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    All of the data to drool or pout over, is in my dyno thread. :D
  17. Apr 22, 2019 at 3:11 PM
    #1757
    JustDSM
    Justin
    Ogden, UT
    You looking to get in on the deal?
  18. Apr 22, 2019 at 3:16 PM
    #1758
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I didn’t get a clear answer but from what I’m gathering I/we do not. Keep in mind I’m staying extremely non aggressive in my approach to where I want my truck to be......these guys left me in the rear view lol
  19. Apr 22, 2019 at 3:27 PM
    #1759
    Lthompson
    that's where im at too.. not going to aggressive. The flow matching seems to be what the biggest part is.. I just don't know if I need 650s at all.. but it seems to be what everyone is going with.
  20. Apr 22, 2019 at 3:29 PM
    #1760
    Lthompson
    the tuning capabilities has just opened up a whole new world really
    12TRDTacoma and loginfailed like this.
