HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 22, 2019 at 3:30 PM
    #1761
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    In your case the 500+cc/min would be *MoNeY*
    12TRDTacoma likes this.
  2. Apr 22, 2019 at 3:34 PM
    #1762
    Lthompson
    Lthompson Well-Known Member
    so maybe stick to the 525 offering?
  3. Apr 22, 2019 at 3:36 PM
    #1763
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :anonymous: waiting for the whipple
    Ive read through it before but its been a while. Dilemma does the gto get go fast goodies or tacoma get some actual umph?
    loginfailed and Lthompson like this.
  4. Apr 22, 2019 at 3:36 PM
    #1764
    JustDSM
    Justin
    Ogden, UT
    If you're not going to or intend to really push the boundaries of the TRD/Magnusson blower, (2.5" or > w/ FPR mod) then the 525's will be a great choice for gas applications. They'll give you a little extra headroom over the TRD 455cc/min and add that safety margin.
    12TRDTacoma, loginfailed and Norton like this.
  5. Apr 22, 2019 at 3:44 PM
    #1765
    Lthompson
    I found the little calculator on their website.. it helped understand a little. seems the 525s would push anything I would need, even if a whipple kit comes out.. If I had 350 at the wheels eventually, id be pretty happy. I just don't really know the stock internal capabilities of these motors and I don't wanna push it to the edge.. I think the 525s will suite my needs plenty.. And hopefully work a little better overall than something offered with the kits.. the tuneability is the important component
    loginfailed likes this.
  6. Apr 22, 2019 at 3:45 PM
    #1766
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    With my TRD injectors, AFe intake, long tube headers, JFR y-pipe and 3" exhaust my injector duty cycle was 95% at WOT. The UCON was commanding 11.5 AFR and the injectors were only able to get me to 12.5 AFR. I was not running FPR mod, so that may have helped.
    Long story short, I went with larger injectors for a bit of cushion, because the last thing I want is one of the injectors to go tits up when I'm at 5700 RPM 10+psi boost. The rods might not like that.
    With a 2.7 pulley, you're probably fine with the TRD injectors.
  7. Apr 22, 2019 at 3:45 PM
    #1767
    JustDSM
    Justin
    Ogden, UT
    With FIC's precision matching, the 525's will purr like a kitten I'm certain of it.
  8. Apr 22, 2019 at 3:49 PM
    #1768
    Lthompson
    im kinda looking to take that route too.. I like whipple. the 2.3 on my chevy is nice and quiet too. is the 4 runner motor not the same motor the Tacoma has? don't see why it shouldn't fit
  9. Apr 22, 2019 at 3:57 PM
    #1769
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Alright. Just read the cam gear install instructions. Thanks for posting, Bassackwards. Aside from breaking the cam gear bolt loose without damaging the chain, it seems straight forward enough.
    I'm staying NA at this point. Lots of positives on the cam gears, even for NA. Are there any drawbacks outside of a higher emissions?
    50hp for $160 is a huge value unless there's some reliability/longevity drawback I'm not aware of. @JustDSM @Torspd @loginfailed @Roostfactor what else do I need to know?
    JustDSM likes this.
  10. Apr 22, 2019 at 3:58 PM
    #1770
    JustDSM
    Justin
    Ogden, UT
    These gears alone won't give you 50. But they make it possible for the other N/A mods (Intake/header/exhaust) to get you that 50hp.
  11. Apr 22, 2019 at 3:59 PM
    #1771
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    That 50hp figure also included full headers/exhaust an intake and engine management system... So more like @$3,350 unless you already have that....
  12. Apr 22, 2019 at 3:59 PM
    #1772
    JustDSM
    Justin
    Ogden, UT
    It's a dual VVTi variant of the single VVTi 1GR in our truck. Different motor.
  13. Apr 22, 2019 at 4:03 PM
    #1773
    DocME
    California
    '07 FJ Cruiser
    But when you think of it, that's stock supercharger power range for less $ per HP.... It's not a bad route to go if you want to stay N/A.
  14. Apr 22, 2019 at 4:11 PM
    #1774
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I'll be TIGing up my own y-pipe and exhaust this summer, maybe score some used headers and will call on you guys and my MVPI2 for engine management, so I'll be close at a fraction of that. Gonna mull it over but cam gears sound like a win.
    JustDSM likes this.
  15. Apr 22, 2019 at 4:15 PM
    #1775
    Sacrifice
    KS
    DCSB OR 4X4 LT
    i thought the same. im guessing the lower manifold half is the main problem and they dont share the same bolt pattern. another issue could be pulley spacing but i think that would be easy enough to accomplish.
  16. Apr 22, 2019 at 4:16 PM
    #1776
    JustDSM
    Justin
    Ogden, UT
    I think you'll be there, and I appreciate your gear purchase :D
  17. Apr 22, 2019 at 4:31 PM
    #1777
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    It's still considered a 1gr-fe but starting in 2009 the t4r and fj received dual vvti, and the Tacoma got left with just single vvti.
  18. Apr 22, 2019 at 4:38 PM
    #1778
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Arm. Twisted. I'm in and 3 degrees more retarded. Thx JustDSM!
  19. Apr 22, 2019 at 5:07 PM
    #1779
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It isn't so easy as simply a clear answer. You have to look at the dyno sheets and what mods people had. You'll then have an outline of what all mods make what HP levels. Then you determine how far that you want to grow your output. Next, you use the injector flow to horsepower formula, to determine which size injectors that you specifically need.
    That is the "riding the coat tails" method. Easy
  20. Apr 22, 2019 at 5:08 PM
    #1780
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which is still used everywhere else in the world to this day.
