HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 23, 2019 at 1:45 PM
    #1861
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Wideband doesn't go through the ecu so has to be some sort of external input to the mvpi2 I'm guessing.
    - pro version?
    Also curious about this
  2. Apr 23, 2019 at 1:49 PM
    #1862
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    I was at work until today, lots of hotel time. I’m still revisiting a few things while I wait for delivery though. There is so much great info I’m here, my little pea brain needs time to soak it in.
  3. Apr 23, 2019 at 1:53 PM
    #1863
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Yes pro version (although clearly I'm not a pro as I can't figure this out):annoyed:
  4. Apr 23, 2019 at 1:55 PM
    #1864
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You're going to have to redefine the input on the gauge.. It would be easier for me to explain this on the phone. I'll PM you my number.
    Roostfactor and loginfailed like this.
  5. Apr 23, 2019 at 2:02 PM
    #1865
    TodayWasTHeDaY
    Russ
    Calgary
    @JustDSM is there any way to get the ecu rescaled to utilize a Wideband input directly? I'm assuming a shit ton of tables would have to be reworked lol.
  6. Apr 23, 2019 at 2:14 PM
    #1866
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    arent the stock o2 sensors a wideband? They support measuring afrs down to at least 10.8ish (what i have seen them report)
  7. Apr 23, 2019 at 2:14 PM
    #1867
    ThomasMore66
    Dallas/Fort Worth & Durango
    @JustDSM gets fired from regular job for always being on TacomaWorld...opens speed shop charges lots of money...
  8. Apr 23, 2019 at 2:18 PM
    #1868
    JustDSM
    Justin
    Ogden, UT
    LOL you guys joke! But I’m gonna have to be a little less blatant!
  9. Apr 23, 2019 at 2:18 PM
    #1869
    12TRDTacoma
    Rob
    Concordia
    Boosted
    11.9 is the most that OE goes to.
    BillDaCat8 likes this.
  10. Apr 23, 2019 at 2:19 PM
    #1870
    JustDSM
    Justin
    Ogden, UT
    11.96
    loginfailed and 12TRDTacoma like this.
  11. Apr 23, 2019 at 2:20 PM
    #1871
    TodayWasTHeDaY
    Russ
    Calgary
    11.960000000000000001
  12. Apr 23, 2019 at 2:24 PM
    #1872
    nd4spdbh
    SoCal
    haha well that answers that.....
    loginfailed and JustDSM like this.
  13. Apr 23, 2019 at 2:36 PM
    #1873
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Right click
    Gauges layout
    Click add round gauge
    Click parameter
    External inputs
    MPVI2
    ProLink
    I’ve seen IAT north of 150 in traffic on a 100*+ day.
  14. Apr 23, 2019 at 2:47 PM
    #1874
    mightytacoman
    Kel
    4.5L 1grfe
    @JustDSM helped me out on this one too. The above doesn't work (for me anyways) and its what I was trying. I had to go into the Gauge layout> Add gauge> Fx transforms folder > oxygen sensors> afr> then the wideband I transformed to get it to work..
    JustDSM and loginfailed[QUOTED] like this.
  15. Apr 23, 2019 at 2:48 PM
    #1875
    DiamondW
    Kent
    Gonzales Co. TX
    Because Texas :thumbsup:
  16. Apr 23, 2019 at 2:59 PM
    #1876
    HPTuners
    HPTuners Well-Known Member
    Did you raise a ticket for this? Do you want to change the IAT sensor or trying to achieve soemthing else?
  17. Apr 23, 2019 at 3:06 PM
    #1877
    HPTuners
    Unfortunately I have 3YWK0100/300/400 but not 200.
    DocME[QUOTED] likes this.
  18. Apr 23, 2019 at 3:08 PM
    #1878
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Roostfactor likes this.
  19. Apr 23, 2019 at 3:08 PM
    #1879
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yes, this is true. Can not sell. Ever. Would have to part out if I needed to.
  20. Apr 23, 2019 at 3:10 PM
    #1880
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Do you guys have any plans to support older Tundra’s with the 1GR-FE? I have a 2005, not sure on the ecu calibration but my ovtuner may be able to read that for me.
