HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 23, 2019 at 5:36 PM
    #1921
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    pro allows you to log external sensors such as a wide band afr sensor or a boost gauge for instance.
    JustDSM likes this.
  2. Apr 23, 2019 at 5:37 PM
    #1922
    HPTuners
    HPTuners Well-Known Member
    Contact support, we may be able to help.
  3. Apr 23, 2019 at 5:39 PM
    #1923
    Lthompson
    Lthompson Well-Known Member
    I don't think I wanna spend another 240 bucks for pro features if I don't need it.. I don't even know what im doing
    Norton likes this.
  4. Apr 23, 2019 at 5:40 PM
    #1924
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    :thumbsup:
    Uh oh, the family already calls the wife's stock XT 'the red blurr'...
    DesertRatliff and JustDSM like this.
  5. Apr 23, 2019 at 6:45 PM
    #1925
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    There are ways around using the Pro version to log wideband data, but it's going to cost you something like an EGR input, or some other 5v input. You can log the analog output of your wideband through the vacant input. But the general populace wanting to log wideband data should just opt for the Pro feature set.
  6. Apr 23, 2019 at 6:51 PM
    #1926
    ThomasMore66
    Dallas/Fort Worth & Durango
  7. Apr 23, 2019 at 8:04 PM
    #1927
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Might that have something to do with you being supercharged?
    85* in 45 minutes of stop/go the most I’ve seen is 112*
    Roostfactor likes this.
  8. Apr 23, 2019 at 11:16 PM
    #1928
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Fact. I tested it.........accidentally!
    BassAckwards likes this.
  9. Apr 24, 2019 at 4:29 AM
    #1929
    ThomasMore66
    Did we adjust that on mine? Haven’t disconnected the vacuum yet.
    Roostfactor[QUOTED] and JustDSM like this.
  10. Apr 24, 2019 at 4:43 AM
    #1930
    JustDSM
    Justin
    Ogden, UT
    Yes sir! Yours is properly adjusted per the instructions above. :)
  11. Apr 24, 2019 at 5:25 AM
    #1931
    Lthompson
    I’m getting close.. had it in the cart last night. But didn’t quite commit. Still need a laptop too
  12. Apr 24, 2019 at 5:36 AM
    #1932
    ThomasMore66
    It may be the best addition I’ve purchased. It’s what was always needed to make all of these parts work together. I followed HPTuners on Instagram and it’s stunning how many cars this works on.
  13. Apr 24, 2019 at 5:56 AM
    #1933
    mightytacoman
    Kel
    4.5L 1grfe
    Is everyone disconnecting the battery in between flashes? Wondering how important that step actually is.
    loginfailed likes this.
  14. Apr 24, 2019 at 6:00 AM
    #1934
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's not important unless you are making changes which require a full reset of fuel trims. Straight from @JustDSM
  15. Apr 24, 2019 at 6:00 AM
    #1935
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I haven't done that once yet myself
    12TRDTacoma likes this.
  16. Apr 24, 2019 at 6:07 AM
    #1936
    JustDSM
    Justin
    Ogden, UT
    Caveat..
    I'd add, if you're not comfortable with assuming the risk, stick to the instructions/prompt. But from my testing, the truck can be flashed without disconnecting.
    I'd absolutely (100%) recommend anyone who has done changes which could alter the fueling (MAF/Intake/Injectors/Etc) reset the ECU between flashings so LTFT's aren't affecting open loop fueling with your new setup.
  17. Apr 24, 2019 at 6:13 AM
    #1937
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I remember back in the day when I was getting my GTO road tuned I had replaced the cam in it which totally threw the way the car ran off whack.. everything was off, fueling, timing, everything. He did a full tune including a change to SD (VE) tuning at the MAF eliminating it from the running equation and never once pulled the battery for it.
    I'd say we are safe, but I do agree, resetting the learning if you feel more comfortable with it is always a huge help.
  18. Apr 24, 2019 at 6:14 AM
    #1938
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I did it for the first few times, but the last few 137,856,017 times I have not.
  19. Apr 24, 2019 at 6:15 AM
    #1939
    JustDSM
    Justin
    Ogden, UT
    If I'm not mistaken, with many (if not all?) of the GM vehicles HPT can reset trims from the VCM Scanner. I could be mistaken but I think that is a thing.. And probably what they did there if I had to guess.. But good datapoint.
  20. Apr 24, 2019 at 6:25 AM
    #1940
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It is very possible. As much as I hate GM they are an absolute blessing when it comes to software capabilities and available data display on scanners and HP tuners. They are so ahead of the curve its wild.
    The only thing I miss about them actually, and big overwhelming N/A power, Lol.
