hub or lug centric??
Discussion in 'Wheels & Tires' started by dabighi, Nov 16, 2008.
  1. Nov 16, 2008 at 11:40 AM
    dabighi
    dabighi [OP] Well-Known Member
    hey guys trying to order my wheels. gonna go with the procomp 7089..black six spoke..with the 17x9 with 4.75 backspacing and -6mm offset do i need the ones that say hub centric or the ones that say hub cntric:no(which im assuming is lug centric) please help.
    also im adding 3 inches of lift and wanna use either toyo open country all terrain 285/70/17 or the prcomp xtreme all terrain 305/65/17. which do you recommend?
  2. Nov 16, 2008 at 1:03 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    hub centric
    either tire size is fine
  3. Nov 16, 2008 at 1:09 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Same as above. make sure to take some pics when its all installed.
  4. Nov 16, 2008 at 1:19 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    This is model# for 16's i know you want 17's but 16's will fit too PXA7089-6883
  5. Nov 16, 2008 at 4:33 PM
    dabighi
    i was told that in order to clear the calipers i had to run 17s.would rather use 16s cause tires are cheaper.anyone runnin the 7089 16s?
  6. Nov 16, 2008 at 5:55 PM
    CAMZTRD
    CAMZTRD Well-Known Member
    steve
    hampton, va
    2006 DC TRD Off-Road 4x4
    billy 5100's @ 2.5 w/ 1/4 spacers, toytec aal, LR UCA's, revotec headlights,revotec taillights, lamin-x fogs, color matched grille and rear bumper, undercover, bed-extender, black nerf bars, scan gaugeII , afe drop in, 50 series flowmaster, 6000k bi-xenon hids, more to come.......
    you want LUG CENTRIC...I just orderd the 7089's from tirepackage.com . HUB CENTRIC will not fit over our hubs..
  7. Nov 16, 2008 at 6:22 PM
    Anthony
    sorry but the wheels on these trucks are centered by the hub, not the lugs, hence they are hub centric. the wheels need to have the big bore in the center to clear the hub.
    106mm i believe i want to say, not 100% sure though. if the bore is too large, you can get adapter rings to make it correct.
  8. Nov 16, 2008 at 8:05 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Just to add to the confusion, according to this TN thread, they need to be lug-centric because the hub-centric bore is too small.
    http://www.toyotanation.com/forum/showthread.php?p=2317298
    Also, Mjp2 has the 16s on his. You might PM him as to whether or not their lug-centric or hub-centric.
  9. Nov 17, 2008 at 10:49 AM
    dabighi
    thanks. ya just called pro comp wheel and tire and they said lug centric..last 2#s 83. only problem is i have to move up to a 17inch wheel.not to bad really cause the tires i wanna run only come in either 285/70/17 or 305/65/17. so thanks for the help you guys.lift, wheels and tires should be in and on the truck within a month so pics will be up soon. FINALLY
