Hurricane Florence
Discussion in 'Off-Topic Discussion' started by Yukon, Sep 11, 2018.
  1. Sep 12, 2018 at 4:59 PM
    #261
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    That.
    And this...
    F115A7D4-36F1-4D25-803E-9B92E2E7F34B.jpg 2CF6FB27-0DA8-4FA6-BE4D-B5935F1CF8D8.jpg
  2. Sep 12, 2018 at 5:04 PM
    #262
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    @jpneely since you’re right around the corner, make sure you let me know if you need anything before/during/after the storm. I’ll PM you my number and address. If there are no comms and you need anything, just make your way over.
    TacoTRD78, OCD 08 and jpneely like this.
  3. Sep 12, 2018 at 5:10 PM
    #263
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    Do you have a walkie talkies? I don't have a CB so I can't communicate that way.
    dan0mite[QUOTED] likes this.
  4. Sep 12, 2018 at 5:12 PM
    #264
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    I do have some. I’ll make sure they’re charged and we can meet up tomorrow so I can hand one off to you.
    TacoTRD78 and OCD 08 like this.
  5. Sep 12, 2018 at 5:14 PM
    #265
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you sticking it out in SC too?
    If so be safe a button up tight!
    scottalot[QUOTED] likes this.
  6. Sep 12, 2018 at 5:14 PM
    #266
    jpneely
    Charleston, SC
    I've got a couple .I was going see what channel we could be on . I think mine are constantly on 3 .Not really sure if the channels span brands or not . I don't know much on communications
    scottalot likes this.
  7. Sep 12, 2018 at 5:15 PM
    #267
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    I’ll go dig mine out now and we can test them before TSHTF.
    scottalot, OCD 08 and Sandman614 like this.
  8. Sep 12, 2018 at 5:16 PM
    #268
    jpneely
    Charleston, SC
    I doubt they'll reach all the way to your place but it'll get us closer than without them
    scottalot and OCD 08 like this.
  9. Sep 12, 2018 at 5:21 PM
    #269
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Very nice, I only see one issue, cooling for the gens as they are air cooled. After Irma, I had mine in the back of my truck, under a carport, with all 3 windows open, and worked fine when the wind was 50mph-60mph. After the wind calmed down, the gens got hot and the gas tanks pressurized, so they wouldn't siphon gas, and shut down. Placed them on the ground chained to a trailer, and they ran fine for another day and a half, then the power came back on. Only used 8.5 gals for 2.5 days around the clock, running a window ac unit, well pump, and the rest of the house that was 120v. I would test it out in the heat of the day.
    Added: I know with the tailgate and topper closed trying to secure them, and the exhaust not piped out to the outside, this all contributed to the heat under the topper. With your setup I'd add exhaust extensions going through the vents, yes they're made, and I would add fans on the intake vents of both, might cool them enough to keep it all closed up in the rain and all.
  10. Sep 12, 2018 at 5:29 PM
    #270
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Be safe and Godspeed my brothers and sisters.
  11. Sep 12, 2018 at 5:37 PM
    #271
    Subway4X4
    Lloyd
    NY/NJ
    Hmmmm... I’ve not had an issue with the two gennys overheating, even inside my homemade enclosure (with the doors wide open.)
    I do a monthly 10 minute run and a yearly long term run test between 4-7 days.
    My last long test was early summer, six straight days at different/fluctuating/ alternating load levels using a window AC, two large fridge/freezer units, 1100 watt microwave, coffee maker and select outlets running small electronics.
    I used 17 gallons of stabilized, premium, ethanol free fuel, in eco mode.
    I should move my yearly long term runtime test to mid-summer to stress the system.
  12. Sep 12, 2018 at 5:57 PM
    #272
    DrummyTaco
    DrummyTaco Feeeesh
    Outer Banks
    2017 Tundra Platnium, 2017 SR5 DCLB 4x4 (rip), 1996 reg cab 4x4, 1997 xtra cab 4x4
    They're about as hard headed as they come, a bunch of old time commercial fisherman who've "seen it all". I have a couple friends down there, I can't attest to 200 people, but I know quite a few have stayed to ride it out.
  13. Sep 12, 2018 at 6:06 PM
    #273
    Yukon
    Yukon [OP] Well-Known Member
    2009 Magnetic Grey SR5
    20:00 update
    voz and scottalot like this.
  14. Sep 12, 2018 at 6:22 PM
    #274
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Sub’d, watching closely in Beaufort, SC
    Yukon[OP] and scottalot like this.
  15. Sep 12, 2018 at 6:29 PM
    #275
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Nuts. I hate to write this but I have seen some people say that the nhc is propping this up this storm because they don't know where it's going. They think only sustained 90 to 100 with some higher gust around the center. I hope they are right but if they are wrong...
  16. Sep 12, 2018 at 6:32 PM
    #276
    Killowatt
    I was thinking of using your setup with the doors closed for security, thus the fans. In 92 with Andrew, people in Homestead had to guard their gen sets armed, or they sprouted legs. And these little 50# units would be gone quickly.
    One thing I like about these gen sets is, the carbs are the easiest I've ever cleaned after leaving gas in there too long. After a youtube video, 1 can of carb cleaner, I cleaned mine and they started right up and ran great.
    Subway4X4[QUOTED] and scottalot like this.
  17. Sep 12, 2018 at 6:33 PM
    #277
    remery829
    remery829 Well-Known Member
    Eastern NC
    '14 DCSB TRD Offroad
    Some stupid expensive stuff
    Comparing this to the satellite view of it gives it real scale. Crazy how much of the storm is north of the eye.
    Yukon[QUOTED][OP] and scottalot like this.
  18. Sep 12, 2018 at 6:37 PM
    #278
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
    I wish everyone the best, and if you haven't left the expect area of impact, you probably should. Harvey decided to go back to the coast ONE county South of us last year, and we are very grateful. You would not believe what an impact a slow storm will have. We got 11" in one day, we are not flood prone, but 40 miles away..... Take good care.
  19. Sep 12, 2018 at 7:21 PM
    #279
    remery829
    Eastern NC
    This is what I mean, the actual cloud image if the storm overplayed on the projected path. Gonna be wet
  20. Sep 13, 2018 at 2:41 AM
    #280
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    5 am update. Looking huge. TS warmings extended to inland NC counties as well. Downgraded to a Cat 2 but will still bring an avalanche of water.
