Husky Liners for extended cab? Rear mats source?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coldaccord, Dec 15, 2020.
  1. Dec 15, 2020 at 2:25 PM
    coldaccord
    coldaccord [OP] Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    Winter is near up here in Buffalo, NY.
    I've heard Husky Liners are preferred to Weather Tech, do you recommend the Classic or Heavy Duty?
    Also I have an xtracab, should I get fronts for a "standard cab" since that and "access cab" are the only option?
    Curious if anyone makes a rear all weather mat for the xtra cab
    Thanks in advance
    Black DOG Lila likes this.
  2. Dec 15, 2020 at 2:28 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Reg cab fit
    Walmart and cut to fit rear
  3. Dec 15, 2020 at 9:01 PM
    GMcGee
    GMcGee Well-Known Member
    San Diego, CA
    2004 Tacoma 4x4 with Supercharged 3.4
  4. Dec 15, 2020 at 10:58 PM
    MCJohnston
    MCJohnston Well-Known Member
    Matthew
    CT
    02 Tacoma SR5 TRD 3.4L 4x4 X-tra Cab
    X2 for the husky liners.
    I got the molded ones, they’re very comparable to the weather tech for a much better price.
    The backs I just used old rear mats from a coupe. No one ever sits back there anyways
    gliderpilot and Black DOG Lila like this.
  5. Dec 16, 2020 at 2:25 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    well I'll chime in with this, I purchased the weather techs on the last group buy, and to be honest, I'm not that impressed with them. They don't clean up all that well, and they've gotten scratched up quite easily. The sides are too flimsy where it meets up with the gas peddle, and aggravates the shit out of me, constantly trying to shift my foot around. So, if others here recommend the husky, and their cheaper, I say give them a try.
    TWJLee likes this.
  6. Dec 16, 2020 at 7:06 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    The husky liners fit great in an xtra cab. I have grey up front which matches the moon mist interior really well and black in rear to in theory camouflage black jackets/bags. The rear center piece does require cutting.
    rtwbound, TWJLee and coldaccord[OP] like this.
  7. Dec 16, 2020 at 7:24 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I got my WT off CL for ~$45 for the front set. drove about 30 mins to pick them up. Never had an issue with them curling or bunching or moving out of place. I rarely clean them off, mostly just brush out the loose debris and move on. I don't need sparkly clean floor mats, they're meant to be dirty :D
  8. Dec 16, 2020 at 9:26 AM
    coldaccord
    André
    Buffalo, NY
    That sold me on grey fronts, I have a grey interior too. Where did you get the rear portion? I haven't been able to find any online
  9. Dec 16, 2020 at 10:07 AM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
  10. Dec 16, 2020 at 10:10 AM
    eon_blue
    Azusa, CA
    The Weathertechs are great too, but for the price you can't beat the Husky liners. I've had the fronts for a couple years now and love them.
  11. Dec 16, 2020 at 10:36 AM
    coldaccord
    André
    Buffalo, NY
  12. Dec 16, 2020 at 11:06 AM
    warmingupmymind
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    Access cab mean xtracab typically as they replaced the xtracab with the access cab on the second gens but kept the regular and double cab.
  13. Dec 16, 2020 at 11:33 AM
    coldaccord
    André
    Buffalo, NY
    Excellent, thank you
    Is that to say “access cab” would be proper for the fronts as well? I’ve read the double cab had slightly different fronts due to to some hvac vents in the trans tunnel
  14. Dec 16, 2020 at 12:24 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    correct
  15. Dec 16, 2020 at 12:48 PM
    coldaccord
    André
    Buffalo, NY
    thanks, I’ll order an “access cab” set for my extended cab
  16. Dec 16, 2020 at 6:30 PM
    RapidRoy
    RapidRoy Well-Known Member
    1999 3.4L SR5 4WD MT
  17. Dec 17, 2020 at 6:35 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    if we want to "really" get technical, ours is called the Xtra Cab :D
    Access cab was for 2005 and on, not sure what other mfr call theirs
  18. Dec 25, 2020 at 8:54 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Because ours has no “access” without doors.
  19. Dec 25, 2020 at 3:37 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    kind of never thought of it that way but absolutely correct. even the Ranger I was considering in '04 had "access doors"
  20. Dec 25, 2020 at 4:48 PM
    Madjik_Man
    Colorado Front Range
    I have both Husky and WeatherTechs. They both suffer from the same issues you mention above.
    The Husky liners slide on the carpet too much for my liking. The WeatehrTechs at least incorporate the hook.
