HVAC LEDs out!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ross137, Nov 22, 2008.
  1. Nov 23, 2009 at 11:20 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    hah im going through the same thing a slight punch on the knob turns the light back on ....
  2. Nov 23, 2009 at 2:04 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    They don't make the best contact. I would pull the HVAC controls out, unscrew the bulb, and bend the wire from the bulb up. I could show u so quick, but hard to explain. It makes the wire that is touching the contacts slightly spring loaded. Much better contact. I can find/take pics if u need them to better illustrate what i am saying.
  3. Nov 23, 2009 at 6:11 PM
    Taco Ron
    Taco Ron Male Member
  4. Nov 26, 2010 at 11:11 AM
    pgn21540
    pgn21540 New Member
    Phil
    wisconsin
    07 Tacoma 4x4 SR5
    How do you remove the assembly that holds the heater and air conditioning controls?
  5. Nov 26, 2010 at 11:00 PM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    Butter or putty knife. They just "pop" in and out. Light prying on top should pop them out.
  6. Nov 27, 2010 at 6:06 AM
    pgn21540
    pgn21540 New Member
    Phil
    wisconsin
    07 Tacoma 4x4 SR5
    Thanks. That was easy.
  7. Dec 5, 2011 at 4:29 PM
    nb_tacoma
    nb_tacoma Well-Known Member
    nick
    Thunder Bay, ON
    2006 SR5 access cab 4x4
    2.5 inch toytec lift /w rear block 255/85/16 cooper discoverer st's Westin light bar with 2 hella 500's Satoshi grille mod BHLM bumper valence painted with rocker guard relocated the horns tail gate anti-theft mod added a trailer hitch relocated 7 pin in bumper rear diff breather mod Magnaflow muffler kenwood KDC-X895 deck
    where are the fuses for the AC unit located ?
  8. Dec 6, 2011 at 10:34 AM
    Ross137
    Ross137 [OP] Member
    Anoka, MN
    05 Tacoma 4x4 Trd Sport
    Probably under the dash or under the hood in the fuse compartment. It's in the manual. It's been a few years... I was amazed this thread is still alive!
    I doubt it's your fuse though if only half the lights are out. Just pop the controls off and then swap the bulbs. See earlier pic, they just unscrew, no need to disassemble. Then you'll know if you have a connection issue or bad bulb. Good luck.
  9. May 15, 2012 at 8:25 AM
    PursuitTacoma909
    PursuitTacoma909 Member
    Will
    Fort Knox, KY
    07 Prerunner Black
    Prerunner Bumpers Hella 700ff HID Unique 16" Alloys Smoked Headlights HID Smoked Tail Lights HID Reverse Lights 4 Corner Strobes LED Cupholder MOD 2 10" JL Subwoofers JL StealthBox Alpine 500 mono Alpine HU
    Fuse for A/C is located under the hood, should be a 10a fuse furthest row on the right if your leaning on the drivers side fender. Literally JUST replaced mine
  10. Jan 2, 2013 at 4:45 PM
    ekapec
    ekapec Well-Known Member
    Erik
    AZ
    08 sr5 prerunner
    ultragauge, Cupholders painted black, Pop & Lock, N-Fab Light bar, Aux backup lights, kc daylighters, hella 500ff driving lights, fog lights. Leer cap w/roof rack and rocket box. Pioneer avh1400 dvd. Backup camera.
    last thread that came up on my search for this issue.....many seem to have this issue so im reviving it again. My lights worked yesterday, but not tonight. I did use a fuse tap to the ac fuse under the hood for some aux lights, hopefully it just blew. The aux lights still work though, as does the heat, and the leds for the ac button and recirc.....I hope I don't need to buy anything. lame. but this thread helped, too bad its balls cold out or id get out there now....
  11. Jan 1, 2015 at 10:39 AM
    8mountainstream
    8mountainstream New Member
    Phil
    Lawrence
    SR5
    Can you purchase the two led lights on the circuit board from any Toyota dealer? Can they be re soldered easily?
  12. Jan 1, 2015 at 5:59 PM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    2 years!! Holy thread revival. You have a 2006, they are not LED. They are incandescent bulbs. You can purchase them and replace them. I think they sell LED replacements at Oznium.com
